What to do with 9 month old gas
Discussion in 'Performance and Tuning' started by Rujack, Apr 2, 2018.
  1. Apr 2, 2018 at 9:22 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I've got ten gal of gas from back in July 2017 that's been in Wavian cans, which are well sealed. I didn't add stabilizer. Should I take it the hazmat disposal, or can I still use it? Maybe I could get away with a few gal splashed in with fill ups?
  2. Apr 2, 2018 at 9:31 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    A really big fire...
    J/k if it was a little bit I’d just mix it into a lawnmower or something. That amount if probably just take to hazmat if it’s clear it has separated. Not really sure, haven’t been in that situation before.
  3. Apr 2, 2018 at 9:34 PM
    Rujack
    Clear has separated? What does that mean and how would I know?
  4. Apr 2, 2018 at 9:35 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Pour it in the truck, you’ll be fine.
    WOODEX M.E. and jsi like this.
  5. Apr 6, 2018 at 8:24 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Dump it!!! Bring it to a hazardous waste station. Untreated gas is good for 3 to 5 months maybe 6. It’s not worth taking a chance. It will make your vehicle run like crap if it runs at all.
    When the prior poster refers to separation he is referring to phase separation. It occurs when you have an ethanol blended gasoline and water enters the tank (can be through condensation). The water and ethanol separate forming a layer in the tank of water/ethanol.
  6. Apr 11, 2018 at 7:19 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    Use it for lawn equipment or add a few gallons every fill up.
    I've had many things sit with gas in the tank longer than that and start up just fine. Lawn mowers sitting for 2-3 years, leaf blowers, trimmers, cars. Our snowblower sits in the garage from March until December every year. Sometimes we remember to add fuel stabilizer to the tank, most of the time not though. 10 gal is kind of a lot. Only $25 now, but I'd feel silly just giving it to the waste disposal plant when it would burn just fine.
    jsi, lynyrd3, Hemibee and 1 other person like this.
  7. Apr 19, 2018 at 11:23 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    If you see separation meaning water and gas. You could drain the water and you’ll be left with pure gasoline. Ethanol attracts moisture, water and gas don’t mix. This is what I do to my lawnmower. 5 gallons of gas to 32oz of water. Water draws out the ethanol but separates from the gas. It’s best to find a container that drains from the bottom. Makes it a lot easier to drain the water...sorry got a little off topic.
    fast5speed likes this.
  8. Apr 19, 2018 at 11:35 AM
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    Use it, i regulary use gas sorted for years in my Tacoma. I have Forty gallons emergency stock and I rotate it every three or four years. Stored in Rubbermaid plastic gas cans no stabilizer. 87 octane 10%entanol.
    jsi and Rujack[OP] like this.
  9. Apr 21, 2018 at 4:17 AM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Next time i recommend adding Stabil if your not going to use the gas immediately.
    fast5speed and lynyrd3 like this.
  10. Apr 21, 2018 at 4:23 AM
    lynyrd3
    Bill
    East Central Upstate NY
    You could use it in mowers and stuff ,add some Seafoam to it !
