what to do
Discussion in 'Wheels & Tires' started by TRD desert man, Sep 12, 2010.
  1. Sep 12, 2010 at 2:09 PM
    TRD desert man
    TRD desert man [OP] Well-Known Member
    tucson
    tacoma 4wd longbed
    tc ucas, icon ext c/o ,rear remote res, aal, banks cat back muffler,aem cold air intake, bed mat,
    tires rub on lower control arm let me know
  2. Sep 12, 2010 at 2:11 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    get different wheels or buy new tires...idk post a pic and more details such as wheel and tire sizes..offset? bs?
  3. Sep 12, 2010 at 2:30 PM
    TRD desert man
    tucson
    tacoma 4wd longbed
    like the wheels 17/9 12 mm offset5.4 backspace 285/70/17 the truck only has the rev tec level kit with add a leaf
  4. Sep 12, 2010 at 2:33 PM
    08pretaco
    az
    Hmm 17x9 wheels with 4.5 bs. I think the 4.5 only works for an 8" rim and if you go 9" wide then you need more bs. Someone hopefully will chime in soon to add some input
    was that 5.4 or 4.5?
    Actually it might be the offset. You start with 4.5 bs then with the offset you lose ~ 1/2" which might be the issue.
  5. Sep 12, 2010 at 2:40 PM
    08pretaco
    az
    This might help lol
    under truck l..............l = 9" rim
    under truck l........L.....l = 9" rim with 4.5 bs
    under truck l......L.......l = 9" rim with 4.5 bs with 12 mm offset
    L represents where the lugs attached wheel to the hub
  6. Sep 12, 2010 at 2:48 PM
    TRD desert man
    tucson
    tacoma 4wd longbed
    my bad it was 4.53 bs
  7. Sep 12, 2010 at 2:50 PM
    08pretaco
    az
    in any case wouldnt change the measurements too much from what i posted above
  8. Sep 12, 2010 at 2:52 PM
    TRD desert man
    tucson
    tacoma 4wd longbed
    what about spacers?
  9. Sep 12, 2010 at 2:53 PM
    08pretaco
    az
    spacers would help if its rubbing the lca at full turn. another thing to think if its only full lock then i wouldnt worry about it lol
  10. Sep 12, 2010 at 2:53 PM
    TRD desert man
    tucson
    tacoma 4wd longbed
    going to get good coil overs and uca
  11. Sep 12, 2010 at 2:55 PM
    TRD desert man
    tucson
    tacoma 4wd longbed
    yea thats what i was thinking the arms are strong wont hurt them, what about grinding them down a bit?
  12. Sep 12, 2010 at 2:55 PM
    08pretaco
    az
    well coilovers arent going to do anything for lca clearance (i dont think). new uca's will just allow a little more travel and alignment spec over 2.5".
    I am trying to think if coilovers would do anything but i dont think so. You raise the truck but the wheels will suck in a little bit...ya i dont see that helping the lca rubbing issue
  13. Sep 12, 2010 at 2:57 PM
    08pretaco
    az
    can you post a pic to show where they are rubbing?
  14. Sep 12, 2010 at 3:03 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I'm sorry but this is completely wrong. Backspacing is calculated by using rim width and offset. They are not independent of one another.
    If you have 9" wide rims with +12mm offset, then you have 5.5" Backspacing.
    If you have 9" width rims with -12mm offset, then you have 4.5" backspacing.
    Here's a chart that will help you convert offset and rim width to backspacing and visa versa
    https://www.rsracing.com/tech-wheel.html
    The fact that you are rubbing is not surprising. In order to fit the 285's, you need 4.5" backspacing or less, and you need to trim some plastic and possibly cut the body mount.
  15. Sep 12, 2010 at 3:06 PM
    08pretaco
    az
    Thats for that so I was right but with the wrong mentality. From what I posted...OOPS I just noticed for the last one I accidentaly went the wrong way...the L should be to the outside not inside.
    Thanks for clarifying Kieth, I made a booboo with the last one. sorry
    With what I posted Kieth I MEANT to show that the offset takes away from (adds positive to) the BS meaning that the BS is actually that much more.
  16. Sep 12, 2010 at 3:07 PM
    TexasTacoma37
    Actually the L on the the last two should not move. Both of those wheels are 9" wide and have 4.5" backspacing, so they are identical. However, the last one shoudl say -12mm offset, not +12.
  17. Sep 12, 2010 at 3:09 PM
    08pretaco
    az
    Why wouldnt the mounting point move between the last 2 if the mounting point is offset 12 mm to the front of the rim?
  18. Sep 12, 2010 at 3:11 PM
    08pretaco
    az
    That link you posted btw is Awesome!
  19. Sep 12, 2010 at 3:14 PM
    TexasTacoma37
    Yeah it's a little confusing, but the deal is that "backspacing" is just a term that is calculated by using rim width and offset.
    Example: a 9" wide rim with +12mm offset, by default has a backspacing of 5.5".
    That same rim, in order to have 4.5" backspacing, would need to have a -12mm offset.
    So the third scenario you posted is impossible, because a 9" rim with +12mm offset doesn't have 4.5" Backspacing, it has 5.5" BS.
  20. Sep 12, 2010 at 3:15 PM
    TexasTacoma37
    I know isn't it sweet?....I studied it for days before buying my rims, because mine are an odd size, 18x9, +10mm offset, and I couldn't find anyone else running that combo of specs.
