What to do?
Discussion in 'Suspension' started by raswank, Oct 19, 2010.
  1. Oct 19, 2010 at 3:47 PM
    raswank
    raswank [OP] Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    So I just received my 5100's and bushings. I want the most out of the front I can get without any issues. I was thinking the Eibachs in front with the 5100's and top spacer on the driver's side. Do i need the diff drop with this set up? Or not? I have the TSB in the back, so I figure the Toytec 1.5 AAL in the rear. Like I said i want the best set up with less problems. I know you get 2.5 or more up front with the 5100's and Eibachs. But don't want any c.v. angle problems or alignment issues/ Thanks for anyone's time on this.
  2. Oct 19, 2010 at 4:10 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Just run the 5100s. They will give 2.5" of lift. If you want a full 3" then use a 10mm kit with them, and just re-use your factory coils.
  3. Oct 20, 2010 at 5:45 AM
    raswank
    Rick
    Auburn,Ma
    Thanks I have heard and read on this site the many problems people have had at 2.5
  4. Oct 20, 2010 at 5:48 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    alignment troubles.....try 1.75 with a-a-l 1.5
  5. Oct 20, 2010 at 6:00 AM
    raswank
    Rick
    Auburn,Ma
    I have the TSB already. So 1.75 as many people say will level it out. If I put a 1.5 AAL in the back it will have that ugly rake again. That is why I asked if it was better to put them at .85 with the Eibach's, and then the 1.5 AAL in the back. You get more front lift this way I believe without the alignment issues if I am correct from reading posts on here
  6. Oct 20, 2010 at 9:10 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Any 2.5- 3" suspension lift is going to cause the caster in the alignment to be low, no matter what combination of parts you use. However, lifts that are all top-spacer do tend to cause ball-joint problems as well.
