What to get for more lift?
Discussion in 'Suspension' started by 503TRD, Apr 21, 2011.
  1. Apr 21, 2011 at 8:47 AM
    503TRD
    503TRD [OP] Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    So, I have Bilstein 5100's set at 1.75" up front, and the Rear Leaf TSB done for the back. I love how it rides and I liked how lifted it looked, but I just got the N-Fab nerf steps, and I want to lift the truck some more now. Like a 3" lift, I don't wanna cause any problems. It's my daily driver and I don't want to lose any ride quality, I want it to be good on and off road(though I don't wheel much, but when I do I'd want it to do fine). So what can I do to lift it some more? Can I just get some front coils, and another rear leaf for each side? What will that do and how high will the total lift be? Should I get OME or Eibach coils?
    Thanks for any help
  2. Apr 21, 2011 at 8:52 AM
    503TRD
    503TRD [OP] Trucker
    Chad
    Tualatin, Oregon
    Ugh..I could set the billies to .85 when I do the install, how would that ride with the eibachs? And how much of a lift for the front would that give me? I don't have rear 5100's, just stock TRD sport bilsteins. What AAL would I need to level it with the front after the eibachs?
  3. Apr 21, 2011 at 9:08 AM
    503TRD
    503TRD [OP] Trucker
    Chad
    Tualatin, Oregon
    Well why don't I set the 5100's back to 0 then do Eibachs? Is that different or better than having it at .85? And will I need new rear shocks or u bolts if I get an AAL?
  4. Apr 21, 2011 at 9:12 AM
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    i have eibachis and bilsteins at .85. Im sitting at about 2.5". Rides great, and not as stiff as my friends with OME 884 springs.
  5. Apr 21, 2011 at 9:21 AM
    jerretxx
    Jerret
    North Carolina
    I recommend getting the 1/4 top plate spacers, or 3/4 is our a DC. it will make it sit more level. I didn't get it and my rear is sitting a little higher than front. The Eibach is a very good spring, i believe they are rated at 640LBS compared to the Stock one which is 300-400LBS not exactly sure. (spoke to relentless and he said his OME 885 started to sag, thats why he stacked his with a spacer) Just an FYI
  6. Apr 21, 2011 at 9:23 AM
    503TRD
    503TRD [OP] Trucker
    Chad
    Tualatin, Oregon
    Okay, and then can I just get the 1.5" rear AAL from toytec for the tsb pack and be good to go? And rear 5100's maybe..
  7. Apr 21, 2011 at 9:23 AM
    jerretxx
    Jerret
    North Carolina
    i feel confident you need rear shocks, because every lift comes with them, from cheap to inexpensive. U-bolts have to be replaced if you have TSB, because there aren't many thread left on stock TSB leafs, not sure on regular leaf though
  8. Apr 21, 2011 at 9:26 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I just installed the full OME lift on Wed , 885's no top spacer , OME shocks front and back and Dakars netted me a 2 3/4" gain all around on my DCLB 4x4 .
  9. Apr 21, 2011 at 9:27 AM
    jerretxx
    Jerret
    North Carolina
    also, with Eibach and 5100 at .85, no need for UCA. however, if you went any higher, i would suspect you will need them. Im thinking hard about turning my 5100's up to 1.75 and stacking with Eibach, from what i have read and searched, no one has done it. but, i will def need UCA's first. I will have a similar set up to Relentless, but he will have OME and mine will be Eibach. but, ill be sitting around 3.25 - 3.30 somewhere in there.
  10. Apr 21, 2011 at 9:28 AM
    OZ-T
    Peter North
    British Columbia
    The old 885's sagged , the new ones are 885X , they aren't supposed to sag .
  11. Apr 21, 2011 at 9:32 AM
    jerretxx
    Jerret
    North Carolina
    I will definitely do it. it will be a little while, tried turning them up last night, but the dang Upper ball joint would come apart from spindle, and i got pissed off and put it back together. It will be a few weeks, ill definitely have a thread about it and hopefully answer many many questions about this setup.
  12. Apr 21, 2011 at 9:42 AM
    jerretxx
    Jerret
    North Carolina
    oh yeah, they def do haha.
