What to grease and change 100k
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Missouriprerunner, Dec 22, 2015.
  1. Dec 22, 2015 at 10:58 AM
    Missouriprerunner
    Missouriprerunner [OP] Well-Known Member
    Adam
    STL MO
    2018 dbl cab sr5
    2009 TRD OR dbcab prerunner. My baby just hit 100k on the trip back from arkansas to Missouri and I'm new with trucks. I've learned a bunch over the last year but let's face it: I'm no mechanic.
    So here it is:
    Automatic transmission, do I change the Trans fluid?
    I'll do a radiator flush
    Inspect the belt and decide if I need to replace it now or later
    Change the diff fluid
    Grease all the parts that need it
    So I have no clue where or what to use in terms of grease. What needs greased and what do I grease? I have greased excavation equipment and farm stuff but not a truck ever.
    Change the diff fluid, please enlighten me on what to buy for fluid and how to do it.
    Radiator fluid, I'll use the Toyota stuff.
  2. Dec 22, 2015 at 11:02 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Good luck finding any grease zerks on your Prerunner...
  3. Dec 22, 2015 at 12:04 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Yea I looked and didn't see any but I didn't spend much time looking. I have a bad disc in my back from an accident in October and working on the truck doesn't feel very good now.
  4. Dec 22, 2015 at 12:17 PM
    Jcollins
    Jcollins Well-Known Member
    Justin
    Browns summit north carolina
    2013 grey tacoma trd
    Light bar and pods with strobe back up camera any time mod 886 backup lights and a Detroit true track posi
    The drive shafts is the only thing that has grease fittings on my 2013 trd sport. And my diff I just replaced called for about 3 qts of 85w-140 non synthetic gear oil. 24mm bolt on bottom of diff housing and fill to the bottom of the fill plug (in the middle on the back)of housing. If it's the same rear end as my 2013. Is yours the trd sport?
  5. Dec 22, 2015 at 1:44 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    TRD off road. 2009
    I'll check what I need to replace the diff fluid with
  6. Dec 22, 2015 at 2:17 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    09+ prerunners SHOULD have zerk fittings on the rear driveshaft U joint bearing caps. Grease those fuckers good, and then continue to grease em every 5k miles when you are under there doing your oil change.
    For all 09+ trucks you do not need any special diff fluid as they have gone away with the mechanical LSD founds in the trd sports and some sr5 rigs. any 75/80w-90 gear oil will work... i run mobile 1 full synthetic and it just so happens to have the LSD additive already in it (which wont hurt anything).... if you have not changed your diff oil... DO IT AS SOON AS YOU CAN.... at 100k on stock oil you are probably already wearing pinion bearings... when that happens you may as well replace ring and pinion gears along with all the bearings in the axle (moms 07 4 runner had to have this done at 110k), i changed my rear diff oil in my 2013 at 6k miles, it was NASTY.
    Replace that serpentine belt regardless of what it looks like... keep the old one behind the seats just in case.
    For the transmission there is a good writeup on how to go about changing out all 11 or 13 quarts of fluid properly, do it and your auto trans will last for ever.
    Flush brake fluid with new clean stuff, this will keep things proper.
    And lastly yup, change out that coolant, flush with distilled water and refill with proper coolant.
    Missouriprerunner[OP] likes this.
  7. Dec 22, 2015 at 2:31 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    What brake pads do you recommend I just left the dealership and I'm close to needing new pads. I do light trails a bunch for camping and hiking trips. Are new rotors worth it?
  8. Dec 22, 2015 at 2:31 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Thanks your the man
  9. Dec 23, 2015 at 2:42 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    I normally just use NAPA pads, and they have been great for me. Also, any NAPA should be able to turn your rotors. Unless they're warped or worn down THAT low, you should just be able to turn them and call them good.
    There are some guys on here who have upgraded to 'performance brakes' - i.e. slotted rotors and such. I don't really think it's necessary, but I don't do heavy towing or any racing or anything that would require something like that. What you get is up to you!
    Just my two cents!
  10. Dec 23, 2015 at 3:28 AM
    Wolverinesam
    Wolverinesam Well-Known Member
    New York State
    2013 Tacoma Prerunner 2.7L
    M
    My '13 dcsb 2wd PreRunner has 3 zerks, all on the propeller shaft. I am planning a diff drain and fill with Valvoline 75W-90 synthetic in the spring at 50k. many TW members swear by Amsoil and Redline. You will have a hard time finding the 75W-85 Toyota wants. The other is fine. Good luck.
  11. Dec 23, 2015 at 3:33 AM
    Wolverinesam
    New York State
    BTW if your LSD is "automatic", you don't need the friction additive. There is a thread here that tells you how to determine if yours needs it. Try searching for differential drain and fill in the title on the 2nd generation forum.
    Edit: here's the thread:
    Changing differential fluid - A step by step "HOW TO"
  12. Dec 23, 2015 at 9:16 AM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Yea I've made a check list of everything I'm doing and what to buy. The mobile 1 stuff is what I'll use.
  13. Dec 23, 2015 at 9:20 AM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Also I've seen on here that I'll need 3 gallons of the pink stuff from the dealership to do a full fluid flush on my radiator, is that true? The guy at the dealership told me I didn't need to do a full flush and just ONE gallon should do it. He confused me.
    Plus I didn't have the cash on me to spend 66 buck on fluid yesterday so I just waited on that since I had to get my Safety and Emissions done on the truck and re license it.
  14. Jan 3, 2016 at 8:04 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Did the tire rotation and changed the diff fluid out today. Doing the oil change later this week and then hopefully the radiator flush too.
  15. Jan 3, 2016 at 8:09 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Diff fluid came out looking brand friggin new today. The heads of the bolts had a bit of wear on them so I suspect the previous owner serviced it or the dealership did. But yea it had a decent amount of goop on the magnet but the fluid looked beautiful.
