What to look before purchase?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sweet88gt, May 27, 2019.
  1. May 27, 2019 at 2:33 AM
    Sweet88gt
    Sweet88gt [OP] Member
    Found the website while looking for information on Tacoma’s. Have been looking for a 4th vehicle for about 2 months. Don’t need it until August but searching now.
    Have my mind set on a Tacoma or 4Runner.
    Friend of mine has a 07 single cab 4wd 5 speed sitting in a garage. Took a quick look yesterday but couldn’t get around it for a good inspection. Been sitting for awhile.
    What should someone who knows little about the Toyota brand be looking for ?
    My first guess is timing belt maintenance. What else should I be on the lookout for ?
  2. May 27, 2019 at 2:37 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    NO timing belt. Check for frame rust.
    TRDSport10 likes this.
  3. May 27, 2019 at 2:42 AM
    Sweet88gt
    Any specific areas the frame would rust ? Florida truck that was driven on the highway.
  4. May 27, 2019 at 3:38 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Here are the inspection instructions.
  5. May 27, 2019 at 8:33 AM
    Sweet88gt
    I read through the frame issues. The replacement process in fairly involved. I doubt this truck has any but I’ll check it out.
    Any other items to look for ?
    Looking for common issues. Valve cover leaking, transfer case problems ?
  6. May 27, 2019 at 9:19 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Just buy the damned truck!
  7. May 27, 2019 at 9:23 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Everywhere on the frame,Florida trucks rust due to the Ocean air.
  8. May 27, 2019 at 9:57 AM
    Sweet88gt
    Got to get it moved out of a garage first. Been sitting for a bit.
  9. May 27, 2019 at 10:14 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    FRAME RUST
  10. May 27, 2019 at 10:19 AM
    DirtTaco
    DirtTaco Well-Known Member
    Frame rust biggest issue. Highway driven is good.
  11. May 27, 2019 at 10:25 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Maint. records. The truck is a lot like your fox body. No real common issues. I've got 104,000 hard miles on mine and it runs like new. You'll see that's the norm here. 05 had some head gasket issues, frame rust like everyone else says. That's it. If it's a V6 you'll hear a VVT tap which is normal. Tons of info on here. Search and read..
    Sweet88gt[OP] likes this.
  12. May 27, 2019 at 10:45 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Frame rust, motor mounts, 4WD actuator (make sure all drive modes work), ebrake casing cracks by rear wheels backplate (where it goes into rear brakes), rear leaf anti friction pads and condition of leafs, clutch pedal bushing squeaks.
  13. Jun 1, 2019 at 9:47 AM
    Sweet88gt
    So need some more advice.
    Truck is a 06 4cylinder 4wd single cab with 176k miles.
    Got it out of the lady’s garage today. Has been sitting for the majority of 2 years w around the block driving only. Was last registered in 2017. Jumped it off and no issues.
    Frame looked good. Ac worked but sounded like blower motor on high made noise.
    Biggest issue was it was leaking oil. It’s either the rear main seal. Maybe valve cover as the underside was very wet. Wasn’t leaving a puddle before we moved it.
    It’s not advertised for sale. She is going to give me a number in the next few days.
  14. Jun 1, 2019 at 10:16 AM
    Sweet88gt
    I forgot but it’s a stick trans as well.
    Skyway likes this.
  15. Jun 1, 2019 at 10:45 AM
    lynlan1819
    Tacoma
    Lifted
    All depends on the price.
  16. Jun 1, 2019 at 12:22 PM
    Skyway
    Ande'
    St.Pete
    If you don't buy it.... Let me know.
    :thumbsup:
