What to look for when buy used LT kit?
Discussion in 'Long Travel Suspension' started by Sunner, Jan 29, 2012.
  1. Jan 30, 2012 at 11:50 AM
    97yota4wd Well-Known Member
    Aug 26, 2010
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    a mid travel front and LT rear is the best/cheapest option personally.
    and they dont come with bumps but you can modify your stock ones to work or buy hydro bumps which i recommend.
    both kits come with the same thing.
    camburg- $2895
    • Upper and lower uni-ball A-arms
    • lower Uni-ball spindle adapter
    • brake lines
    • limit straps
    • steering extensions, coilover mounts
    • hardware.
    • Heim Steering upgrade $495.00
    • Heim joint upper arm pivot upgrade $249.00
    total chaos- price?? close to camburg
    [FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Parts Included:
    [/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Upper A-Arms W/ Bushings, Uniballs, & Clips[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Lower A-Arms W/ Bushings, Shock Mounts[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Tie-Rod Extensions[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Tapered Spindle Sleeves[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Braided Stainless Brake Lines D.O.T. Approved[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Bolt-on Upper Shock Mounts - Specify Brand[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Hardware[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Adjustable Limit Straps & Mounts[/FONT][FONT=Arial, Helvetica, Geneva, Swiss, SunSans-Regular]Plated Upper A-Arm End Washers[/FONT][FONT=Arial, Helvetica, Geneva, Swiss, SunSans-Regular]Weld-on Bump Stop Spacers[/FONT][FONT=Arial, Helvetica, Geneva, Swiss, SunSans-Regular]Lower Uniball Conversion[/FONT]
