What to look for when buying a Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SnowroxKT, Dec 15, 2011.
  1. Dec 15, 2011 at 9:24 AM
    SnowroxKT
    SnowroxKT [OP] Well-Known Member
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    SAS, dents, & scratches
    Hi everyone! Noob here trying to buy a Tacoma, looking for a reliable truck that I can have at college for up here in Alaska. What should I specifically look for that is a common problem? Engine recommendations? I like manual trannys but are the autos and manuals both good? I understand the head gasket issue was solved after 1995 so I am looking at 1996 and up.
    Any help appreciated or links to if this was brought up before. :)
  2. Dec 15, 2011 at 9:28 AM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    Make sure it's 4x4, 4 door, extended cab, or regular cab.
  3. Dec 15, 2011 at 9:30 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    Isn't that just like saying a 4x4 because the 4 door, ext. cab or regular cab are all the cab options?
  4. Dec 15, 2011 at 10:15 AM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
  5. Dec 15, 2011 at 10:18 AM
    Madjik_Man
    Boulder, CO
    The way I read that is he's suggesting to just get a 4x4 regardless of what cab you choose
  6. Dec 15, 2011 at 12:08 PM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    Look for the "Toyota" emblem...
  7. Dec 15, 2011 at 4:08 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Make sure the previous owner got the frame insured. If not, dont buy.
  8. Dec 15, 2011 at 6:28 PM
    DNG
    DNG Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    V6. 4 bangers are powerless, especially if you get a 4 door.
  9. Dec 15, 2011 at 6:29 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Get the 4x4 V6 and just check maintenance and the frame.
  10. Dec 15, 2011 at 6:40 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    make sure its a 1st gen 01-04, extra cab, low miles, and doesn't have much rust on the frame.
  11. Dec 15, 2011 at 6:41 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    check underneth for rust and visable oil leaks
  12. Dec 15, 2011 at 6:43 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    Like others said check for frame rust. Other than that you can't really go wrong. Just note that all of the double cabs have an auto tranny
  13. Dec 16, 2011 at 8:17 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    Frame insured? how does that work? Through Toyota???
  14. Dec 16, 2011 at 8:18 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    Is that true with 1st and 2nd Gens?
  15. Dec 16, 2011 at 9:07 AM
    96Taco
    96Taco Well-Known Member
    Alberta
    '04 V8 4Runner
    ..stay tuned
    Check for leaks behind backing plate, axle seals up front, front and rear diff, transfer case and transmission, along drive shaft, rack and pinion/steering box. If you see grease or oil inspect closely.
    Look for any signs of n * g g e r rigging or backyard mechanic work.
  16. Dec 16, 2011 at 9:46 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    Thanks for all the help guys! Way friendlier than some other forums...
  17. Dec 16, 2011 at 9:59 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Welcome...Check the frame for rust... mainly 1st gen. But second gens depending where your at rust from the salt too.
