What to look out for when buying a used second gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EastWaTaco, May 6, 2016.
  1. May 6, 2016 at 2:00 PM
    EastWaTaco
    EastWaTaco [OP] Well-Known Member
    Angelo
    82 4x4 with a 3rz
    Don't come in to the section of the forms very much :spy:... But once spring quarter is over I will be selling my first Gen to use as a down payment on a second gen Tacoma! I'm looking to spend around 17 grand which, after looking at what's for sale, seems reasonable. I'm doing quite a bit of research but I have a few questions. I have been sort of avoiding the 2005's and 2006s because new truck models tend to have problems (2016s :eek:).. Any ideas on what I should stay away from? I was really hoping to get a manual but after reading about some of the problems I'm not so sure, especially with the earlier 2nd gens. Any help would be appriceated!
    Here's one for sale about five minutes away for me, I'm planning on buying one private party, though. They're asking 15999
    It's a 2007 with 156k on it which is a little high for me.. It's also a 6 speed.
  2. May 6, 2016 at 2:10 PM
    Flamtap
    Flamtap Well-Known Member
    Calgary, AB
    2011 TRD Sport DCSB 6MT
    Full OME Kit (885s, Dakar Leaf Pack, Nitrochargers F + R)
  3. May 6, 2016 at 2:16 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Rust.
  4. May 6, 2016 at 2:20 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Frame rust.
  5. May 6, 2016 at 2:32 PM
    EastWaTaco
    Angelo
    82 4x4 with a 3rz
    Damn, that's still a big problem on the second Gens?? I knew a few of them rotted out but I didn't think it was as bad compared to the first generations.. Thanks.
  6. May 6, 2016 at 2:42 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    rust, radiator hoses, all fluids and the last time they were changed, serpentine belt for wear, bearings, and rear brakes. Its ten years old and nobody does maintenance besides oil changes these days.
  7. May 6, 2016 at 2:46 PM
    EastWaTaco
    Angelo
    82 4x4 with a 3rz
    So is my fear of an early model (2005) second-generation Tacoma irrational?
    Because something like this would be nice..
    https://spokane.craigslist.org/cto/5553770334.html
    Right now I'm in a 1995 Tacoma, and before that I had an early 90s Toyota pick up and an 80s Chevy Silverado so age doesn't scare me too much as long as it's been taken care of, Miles are the main thing. I really don't care if it has all the bells and whistles, since having power windows or door locks would be an upgrade for me
  8. May 6, 2016 at 2:47 PM
    smuggiesrider
    smuggiesrider Well-Known Member
    Vermont
    2021 Army Green TRD Off-Road DCSB AT
    TRD 2" Lift kit w/ PRO Grille swap package ARE CX Classic Cap Sumitomo Encounter AT 265/75/16 tires TRD Pro wheels Predator steps Frame salt protection spray Weather Tech floor Mats and rainguards Wet Okole Seat Covers Bedmat Black exhaust tip Bed light LED kit Tailgate mat Eyecatcher tailgate letters Yoda cover for tow hitch and steering wheel Decals for grille, glove box, badges $$$$$$
    Frame rust recall goes up to the 09.
    I have a 2010 and they supposedly had upgraded? I also had my frame sprayed with protection sealer at purchase new.
    Manuals had throw out bearing issues and you will hear a slight squeezing until you depress the clutch.
    Mine was replaced under warranty but it's a major job as the Tranny needs to come out to fix.
    Don't sweat suspension as you can buy someone's trd takeoffs here cheap.
    There is a leaf spring recall as well as they rust out fast.
    Make sure the rear diff isn't rusted too bad.
    That's a good sign if the diff has little rust.
    Records of all fluid changes are big.
    Nothing else comes to mind as I think these 2nd Gen tacomas are pretty bullet proof.
    Good luck with the purchase
  9. May 6, 2016 at 3:08 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    I feel your pain. I just bought a 2006 and shopping for one was brutal. I waited it out and finally landed my dclb trd sport with just 69,000 miles for $16,700 here in southern California. Good deals are hard to come by. Look for rust on the frame and look at the interior. If it was treated like crap, most likely they didn't maintain it properly.
  10. May 6, 2016 at 3:10 PM
    EastWaTaco
    Angelo
    82 4x4 with a 3rz
    Sounds like you did pretty good though, especially for California
    dirtnsmores[QUOTED] likes this.
  11. May 6, 2016 at 3:11 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  12. May 6, 2016 at 3:13 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    I wouldn't hesitate to buy an early 2nd gen if the frame was either free of rust or had a minimal amount of rust that could be corrected (phosphoric acid/naval jelly and chassis black) and had good maintenance records. A confidence building bonus would be if you were to find that all the recalls and any necessary TSBs were corrected. A VIN number search in the internet can help you confirm that on the spot. If not, just use the information as a negotiating tool and be sure to have pockets full of $100 bills to close the deal.
  13. May 6, 2016 at 4:07 PM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
  14. May 6, 2016 at 4:12 PM
    O906
    O906 Well-Known Member
    They want 16k for that? I just paid 10.5k for a 2006 TRD 4x4 6 speed access cab with only 140k and it's a 8/10 condition wise...
  15. May 6, 2016 at 4:14 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    HAVE A QUALIFIED TRUSTED MECHANIC LOOK AT IT.
    It may cost you $200 but it may save you on buying a piece of flying shit.
    Jester243, dirtnsmores and big_jarv like this.
  16. May 6, 2016 at 6:07 PM
    03maurderman
    03maurderman Well-Known Member
    I bought my 14 Taco new....I didn't see anything on the frame that would convince me Toyota did anything to preserve the frame??? - Does anyone know differently?
  17. May 6, 2016 at 6:19 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Nothing to look at tell one from the other. It had to do with the frame prep and coating used and a new "good one" frame looks the same as an "old bad one" frame that isn't rusty.
  18. May 6, 2016 at 6:46 PM
    03maurderman
    So the frames rusted out due to poor prep prior to being painted? - The recall goes up to 2009, so from that point they correct the issue?...uummm still not convinced. I have only 500 miles on it, as I use a company vehicle thus its never been out in the rain for the reason of not getting the undercarriage dirty... I'm planning to lift the bed & treat the undercarriage/frame...however have not decided on a product to use.....Showing my age here, I bought a brand new F250 4X4 in 1972 & Painted the undercarriage with Rustoleum damp proof red primer & then the frame black but under the cab & bed silver aluminum....Till this day not an ounce of rust....
  19. May 7, 2016 at 12:50 AM
    EastWaTaco
    Angelo
    82 4x4 with a 3rz
    Out of curiosity, is there a thread already out there for this subject? One thread covering the general things you gotta look out for when buying a second gen? I'm sure there probably
    Is.. But if not I feel like this thread could be pretty helpfu..
    Yeah this one was a little steep.. I'm just trying to get an idea of how much I'm gunna spend. I'm more than willing to bike to work for a while if it
    Means I get a better deal.
  20. May 7, 2016 at 5:23 AM
    O906
    I think 10.5k is on the low end and I only got a good deal because the guy really needed cash right then to pay off some over due bills. I think 11.5-13k is what my original budget for a early 2nd gen was.
