What # to torque wheel lugs too?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RockTock, Oct 20, 2013.
  1. Oct 20, 2013 at 11:06 PM
    RockTock
    RockTock [OP] Well-Known Member
    Colorado
    1999 2.4 4 Banger SR5
    Just reading about rotor/brake issue,and it is recommended you torque the lugs. I have a 99 4 banger SR-5, what # should they be torqued too?? thanks!
  2. Oct 20, 2013 at 11:12 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    This, i was told just to torque them to 80-85.
    Or just get them tight with a lug wrench (mechanical, not electric), i've found that me pulling pretty hard gets them to ~80.
  3. Oct 20, 2013 at 11:20 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    My Pro Comp wheels came with instructions for 80-85ft-lbs
  4. Oct 21, 2013 at 9:06 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I've found that if I tork 'em to the official 80 foot pounds, then I would not be able to remove them, if I got a flat tire while on the trail. :eek: Way too tight.
    I use the 'old man' one-grunt method. :D
    I snug 'em up while off the ground, lower the jack, and tighten em with a star wrench to what I call 'one grunt'. Worked fine for 20 years now. I always carry that star wrench in the back. I think whats important is to tork all six to the same. These are not head bolts that have to be exactly tork'd.
    I think shops over-tork them (to spec) because of potential law-suits. When I get new tires, as soon as I get back to my garage, I always break out my breaker-bar to loosen the nuts and re-tork down to 'one-grunt'. Hate to be stuck out on the trail and not be able to get them off after trashing a tire.
    YMMV
    CementTRDOffRoad likes this.
  5. Oct 21, 2013 at 9:11 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    ^^ I agree with above. If you torque them with an air gun too much then they are a bear to take off on the side of the road. I usually tighten them while still in the air by hand to seat the lug nuts and then drop the jack. Ill go all the way around with the socket and breaker bar until snug and then do the star pattern with an extra quarter turn. This is usually adequate.
  6. Oct 21, 2013 at 11:11 AM
    RockTock
    Colorado
    I have a big ass 3.5 foot breaker bar. I just ask because there seems to be alot of rotor-warp going on, and this may help solve it. So will the new rotors I'm looking at.
  7. Oct 21, 2013 at 11:19 AM
    2006TRDSPORT
    2006TRDSPORT 2006TRDSPORT
    Felton, Delaware
    2004 4Runner SR5 4WD
    When I remove/replace tires, I torque them until they feel good & tight using the star pattern & never had any problems. I guess after 20+ years of driving I'm doing it wrong, lol.
  8. Oct 21, 2013 at 11:28 AM
    Large
    Large Red
    Don't use a breaker bar on your lug nuts.
  9. Oct 21, 2013 at 5:09 PM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Why not?
  10. Oct 21, 2013 at 6:48 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    83 ft lbs!! Criss cross pattern when tightening them, double check afterwards.
    A lot of shops use torque sticks, which have a preset torque for an impact gun, but are designed for a certain air pressure, shops always use a pressure way higher so lug nuts are way over tightened. I worked at toyota and used an 80lb torque stick which actually tightened lugs to about 120 or so.. Get a torque wrench (not harbor freight) and evenly tighten your lugs, will help prevent rotor runout
  11. Oct 21, 2013 at 6:53 PM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    If you can't loosen a lug nut tightened to 80rlft-lbs maybe next time you get a flat call AAA. that's what my wife does.
  12. Oct 22, 2013 at 5:43 AM
    offrdmania
    Templeton, Ca
    There is a difference between 80lbs on an alloy wheel and 80lbs on a steel wheel. Steel wheels can be harder to take off because a layer of rust will set in where the lug has worn away the paint of the wheel
  13. Oct 22, 2013 at 6:21 AM
    BamaToy1997
    Bill
    Navarre, FL
    It is important to get the correct torque for all of the lug nuts. Having one or more that are at a different torque can, and many times has, caused rotor warping.
    Technically, yes you have. 20+ years ago it was not such a big deal. With today's automobiles torque spec, including wheel lug nuts, are much less tolerable to variances. Sure, you have not had any trouble with the way you have been doing it, but yes, you have been doing it wrong. Not being a smart ass, but just stating the facts. Rotors warp all the time due to incorrectly torqued lug nuts.
    If you look at the air pressure specs for the torque sticks it lists a MINIMUM spec. The metal of the torque stick is designed to not allow anything past the rated torque to transfer, even with different pressures. You know, if you have worked in shops before, that impact guns vary from brand to brand, and type to type. If air pressure or air flow were an issue with torque sticks, then they would have limitations on the guns as well. If you had a stick that was over torquing, then the stick itself has lost its metal elasticity properties.
  14. Oct 22, 2013 at 2:25 PM
    2006TRDSPORT
    Felton, Delaware
    Well mine have not warped so I'm pretty sure my method works just fine.
  15. Oct 22, 2013 at 6:30 PM
    BamaToy1997
    Bill
    Navarre, FL
    And like I said, it does not always happen, but it is very common that the rotors warp due to incorrect torquing of the lug nuts. My intention is not so much to say your method does not work for YOU, but that it is not the correct method to do it, and may cause someone ELSE a problem if they do not get them to the proper torque. I always do my best to provide people with the correct information, not "What has worked for me".
  16. Oct 24, 2013 at 3:03 PM
    2006TRDSPORT
    Felton, Delaware
    Gotcha, not meaning to disrespect you I just know that there are a lot of know-it-all's on here that think their way/opinion is always best. I have never had issues thus far doing it the way I always have, but I know some things change & certain things need special attention to prevent damage. Thanks for the heads up!
