What to use to paint frame after drilling?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iJDub, Oct 7, 2013.
  1. Oct 7, 2013 at 9:20 PM
    iJDub
    iJDub [OP] Well-Known Member
    What should I use to cover up the bare metal after I drill holes in the frame to keep it from rusting? What matches the frame color best?
  2. Oct 7, 2013 at 9:27 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    flat black rustoleum works for me
  3. Oct 7, 2013 at 9:28 PM
    Foxone
    Foxone Well-Known Member
    I like duplicolor engine paint.
  4. Oct 7, 2013 at 9:29 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    x2
    I did that on mine and it hasn't flaked or shown any signs of wear at all after several months.
  5. Oct 7, 2013 at 9:29 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    POR15 on mine.
  6. Oct 7, 2013 at 9:34 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Your best bet is to use a self etching primer first so the paint truly sticks to the bare metal. Get some rattle can self etching primer and spray it into the cap or plastic cup to make a small puddle and then brush on the primer with a Qtip inside the hole you drilled. Do a couple coats to make sure you have it covered well.
    As far as color matching the problem is that most paints are glossy so look for a flat or satin finish. Some of the engine, chassis and exhaust paints come pretty close.
  7. Oct 8, 2013 at 6:32 AM
    Rokon
    Rokon Active Member
    Robert
    Arkansas
    2011 TRD OR DC - Stock
    Locktite Duro Extend - this is a conversion coating so you need to let it flash rust then apply. The product combines with the iron oxide and creates a black coating that is very durable. You need either a second coat of extend or a top coat of something else to complete the process. I was able to completely kill all of the rust on my FJ40 and it did not return. I also used on river intake structures to successfully hold back rust when I was responsible for paint protection systems at a large industrial facility (it was sold under DuPont label at the time).
  8. Oct 9, 2013 at 2:42 AM
    iJDub
    Why does it say it will cause rust if applied to non rusted surface?
  9. Oct 9, 2013 at 2:48 AM
    Yotafish
    Yotafish Well-Known Member
    Paul
    Wilmington, NC
    2017 TRD OR 4WD DC
    Same basic shit everybody else had 5 years ago.
    Rustoleum professional works good......big silver can.
