what to use to protect paint under the doors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KingMoo, Mar 2, 2012.
  1. Mar 2, 2012 at 8:02 AM
    KingMoo
    KingMoo [OP] Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    What product are people using to protect the paint underneath their doors from rock chips? I guess sliders would work to a degree but I on't have the cash for them yet. Does 3M adhere well to the rockguard that they have down there?
  2. Mar 2, 2012 at 8:05 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I don't have a need for sliders so I went with side steps and kept the mud flaps in place. The paint seems to be holding up pretty well so far. If you want a coating, I'd look into bedliner. Line-X has a color matched bedliner so it wouldn't look too bad and would provide great protection.
  3. Mar 2, 2012 at 8:05 AM
    SuperTacoma
    SuperTacoma Well-Known Member
    Clint
    Tennessee
    11 Toyota Prerunner TRD PKG
    Factory Mods Ventshades Bug Deflector Magnaflow Muffler Solid Fold Extang Cover Pop Lock Helix Power Tower Westin Brush Guard Westin Nerf Bars color match Scoop Hood
    I am using Mud Flaps and Nerf Bars and seems to be working.
  4. Mar 2, 2012 at 9:35 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    The Line-X website is not very informative.
    Do they carry a clear-coat spray for this type of application? Are these sprays in the bedliner section?
  5. Mar 2, 2012 at 9:46 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    yeah, my nerf bars seem do be doing the trick..
  6. Mar 2, 2012 at 10:01 AM
    Pugga
    Massachusetts
    F-150 Mod
    Line-x has a UV additive to prevent it from fading. It's basically a thick paint, it cures itself if it gets dinged (to an extent, obviously there are limits to this). Line-X is most commonly known as a bedliner. There are other options but as far as I know, Line-X is the only one that color matches.
    I'll post back with pictures of someone who coated their entire truck with the stuff.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/117358-line-x-body-bed-headache-rack.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/153615-line-x-rocker-panels-2.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/104293-ive-had-im-line-xing-my-truck.html
  7. Mar 2, 2012 at 10:03 AM
    crazyrzr85
    crazyrzr85 So many b!tches, so little time...now back to TW!!
    ErIc
    W.PA
    10 Tacoma TRD DBL Cab(Totaled) 09 DCSB OR BSP
    Rugged Ridge front mats and Husky rear mat, bed mat, vent visors, bug shield, pine scented tree on mirror
    False...there is a spray shop near me that does Rhino linings and they can do color match as well...
  8. Mar 2, 2012 at 10:11 AM
    Pugga
    Massachusetts
    F-150 Mod
    I stand corrected! I didn't know anyone else was was color matching. Good to see Line-X has some competition now!
  9. Mar 2, 2012 at 10:14 AM
    crazyrzr85
    ErIc
    W.PA
    good product, there is another spray shop local that does color match too, with more of a rubbery feel, the line-x i had in a previous truck was rough stuff, but a good product none the less!!! actually been thinking about getting my BSP lined along the bottom.
  10. Mar 2, 2012 at 10:29 AM
    WVTacoma08
    WVTacoma08 Well-Known Member
    West Virginia
    '16 TRD Off Road
    Factory nerf bars...doin' a heck of a job.
    My '05 did not have & the underside had horrible road rash!
  11. Mar 2, 2012 at 10:47 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    so you have to color match this Line-X stuff and then apply a clear coat over it?
  12. Mar 2, 2012 at 10:52 AM
    Pugga
    Massachusetts
    F-150 Mod
    You can't do Line-x yourself, a dealer will have to apply it for you. No clear coat, it's a 2-part coating that cures hard and durable. There's an option to get a UV protectent which I'm not sure if it's mixed in with the color or if it's sprayed on top. Even without the UV protectant, Line-X is very tough stuff.
    Also, you don't have to color match it. You can get one of their standard colors. Color matching would be more expensive but, if you want to keep the stock look but have something durable, I was throwing it out there as an option.
  13. Mar 2, 2012 at 11:05 AM
    MotorsportsAustin
    MotorsportsAustin Well-Known Member
    Austin
    Belmont, CA
    2012 Off Road 6spd
    Another option is helicopter tape
    http://www.racerstape.com/heli.html
    I've used it for all kinds of applications (including the door sills). It's transparent and available in different thicknesses. Apply it on a dry day with an ambient temp greater than 50 so it's more pliable and sticks. You need to press it and get it to adhere. The good news is you can cut it with scissors to any size or shape for corners, etc.
  14. Mar 2, 2012 at 12:44 PM
    KingMoo
    Calgary
    Tacoma TRD Sport
    quoted $1300 for Line-X application. wowzers! :eek:
    I like the tape idea. I wonder how well it seals to an uneven surface like the rock guard.
  15. Mar 2, 2012 at 1:36 PM
    MotorsportsAustin
    Austin
    Belmont, CA
    2012 Off Road 6spd
    Good question. I'll give it a test and report, then there's also the question about how it'll hold up over 4 seasons. More news as I test it.
    On a flat surface... I have some on one my cars and it's held up for 2 years.
  16. Mar 2, 2012 at 1:41 PM
    Pugga
    Massachusetts
    F-150 Mod
    $1,300 for just the rocker panels???? :eek:
    Me thinks the guy you talked to was being lazy and miquoted you... that sounds pretty ridiculous!
  17. Mar 2, 2012 at 1:47 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    Linex here quoted $1000 to go all the way around, I little less for just rocker panels and $150-250 to do sliders ( said they'd have to see them ) I said never mind
  18. Mar 2, 2012 at 1:48 PM
    fastguy95
    fastguy95 A man knows nothing
    SF Bay Area
    02 DC 4wd
    All Pro front/rear bumpers, OME 883's with Bilstein 5100 all around, Deaver J59 springs, TRD E locker, E locker Guard, Red Line hood struts, Weathertech floor mats, SS brake lines, EBC Rotors and green pads, Debadged, Line X, BAMF brake relocator bracket, Beefed Taco cb drop, Magnaflow muffler, Scuba Mod, live power outlet mod, disable door buzzer mod, tinted windows, light blinker conversion, Alpine HU, Infinity Kappa 600w amp, JL Audio 1000w amp for sub, JL Audio W3V4 12" sub, JL Audio 6x9's, Retrofit projectors bixenon 55w, Dynamat on all doors, and light bar.
    Wow, $1300 is a lot!
    I got my bed sprayed with Line-X for $450 out the door. I'm also in So Cal too, so not sure if that is why I got a decent deal.
  19. Mar 2, 2012 at 2:01 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    1300 is crazy, even for CAD. should be closer to 600 CAD I would think. even then its really expensive. Id rather get sliders at that cost!
  20. Mar 17, 2012 at 1:20 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
