What tools do I NEED to install my lift??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JReaperz, Jun 9, 2017.
  1. Jun 9, 2017 at 2:11 PM
    JReaperz
    JReaperz [OP] Well-Known Member
    JR
    Indiana
    2012 NatBlue DCLB SR5
    I have all the parts to lift my 2012 double cab 4x4 (billies 5100 all 4, ome 885s, 1.5 in rear blocks, uniball ucas, driver lean spacer, and new wheels/tires). Im not a mechanic by any means but I am somewhat handy with tools and tend to fix my own stuff around the house or at least I try too. I plan on using the floor jack method to take off/on the stock springs/shocks but im not sure what else I NEED to have handy to complete the job. Just wanna make sure I have all the tools needed as im not sure I will be able to make multiple runs to the parts shop if my truck is on jack stands. Thanks in advance for the replies.....and yes I realize aal would be better than blocks but its just for the meantime until I can get some Dakkars.
  2. Jun 9, 2017 at 2:34 PM
    MO Tacoma
    MO Tacoma Well-Known Member
    Castle Rock, CO
    2014 DCLB with a couple mods
    ADS extended travel, 14" 700 lb springs, Total Chaos UCA/LCA, Dakars. 37/12.50r17 Pitbull Radial Rocker. SCS 17" SR8. 4.56s with f&r ARB lockers. Relentless sliders, full skids, debadged. 35% tint on all windows. Katzkin leather w/ heated seats
    You need a socket set 12-19, wrench set, jack, jack stand, pliers, big screwdriver or pry bar and last but not least..... bfh. You will/might need deep and long sockets. For the front replace the uca first and bolt it in then undo the sway bar link and lower control arm bolts to drop the coilover. You will have to loosen the lca cam bolts too so it can swing down. I know it's tempting but do not try to do all of this with the uca off. You will have problems with the abs and brake lines not being long enough. The rear is straight forward. I jack the back up high, put jack stands under the frame and use the jack to raise and lower whatever side I'm doing. These are all just recommendations. There is more than one way to do it. It's good to have a buddy there too. A extra hand is nice in some parts of the install but not necessary. Have fun!
    ChemDawg and JReaperz[OP] like this.
  3. Jun 9, 2017 at 2:36 PM
    JReaperz
    JR
    Indiana
    Thanks!
  4. Jun 9, 2017 at 2:37 PM
    MO Tacoma
    Castle Rock, CO
    NP. Let me know if you have any more questions.
  5. Jun 9, 2017 at 2:40 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
  6. Jun 9, 2017 at 2:40 PM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Oh, and beer. enough for you and your buddy. And buy his brand.
    JReaperz[OP] and outlawtacoma like this.
  7. Jun 9, 2017 at 2:47 PM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    JReaperz[OP] likes this.
  8. Jun 9, 2017 at 3:18 PM
    JReaperz
    JR
    Indiana
  9. Jun 9, 2017 at 3:56 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    You might want to consider New U bolts and Center pins for the rear.
  10. Jun 9, 2017 at 4:06 PM
    JReaperz
    JR
    Indiana
    I did get new u bolts to accommodate the spacer block but not a pin?
  11. Jun 9, 2017 at 4:08 PM
    MO Tacoma
    Castle Rock, CO
    Some blocks have spot for the spring pin to go and a pin for the axle. If you have that you are covered.
  12. Jun 9, 2017 at 4:09 PM
    Chase8059
    Chase
    ESVA
    The only reason I say this is because I ended up just cutting my old pin off. Then when I put the new on, I tightened the nut and then hammered the bolt end so it would never come off.
    Just something to consider. And new pins are a few bucks.
    JReaperz[QUOTED][OP] likes this.
  13. Jun 9, 2017 at 4:10 PM
    JReaperz
    JR
    Indiana
    I will pick some up just incase, thanks.
