What tools for Beginners?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toastedtaco, Jun 3, 2024.
  1. Sep 2, 2024 at 2:27 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    True Story
    Buddies and I are walking autoX track
    I see something chrome, socket shaped on a corner.
    15ft away, tried to make a bet with the 4 buddies that the socket was a a 10mm
    Not one wanted that action
    And it was a 10mm
    here is my must have tool:
  2. Sep 2, 2024 at 2:36 PM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    Winner... someone send this guy a free calender or something.....
    I'm convinced my son has a secret stash of these in his room somewhere. But no.... I think I have 2 missing in my engine bay as I type this
  3. Sep 3, 2024 at 11:40 AM
    xtrchessreal
    xtrchessreal Active Member
    2003 Taco 4x4 XC 5VZ-FE TRD
    every time I am at harbor freight I buy a 10mm something box/open wrench, socket, hex etc.
    saw a video comparing Pittsburgh, Icon, to Craftsman and Snap-on. No, Pittsburgh wrenches didn't win but they still do 130% over asme tests which is some ridiculous torque spec. Who is going to use 100 ft-lbs or more with an open end a hand wrench? That is breaker bar time for me to come off and torque wrench to go on. I generally break all bolts or unseat them with a 1/2" drive socket or breaker bar first then switch to 3/8" ratchet driver.
    MadNachos likes this.
  4. Sep 3, 2024 at 12:25 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    I love the electric 3/8" drivers...one of those and a few 10's and you are good. I have been beating on one of these for about a year and it's been great:
    KIMO Cordless Electric Ratchet Wrench Set, 40 Ft-lbs, 400 RPM, 12V Cordless Ratchet Wrench 3/8" w/ 60-Min Charger, 7 Sockets, 1/4" adapter, 2-Pack 2000mAh Lithium-Ion Batteries, Variable Speed Trigger https://www.amazon.com/dp/B07X37XMX3
    JustADriver and xtrchessreal like this.
  5. Sep 3, 2024 at 2:22 PM
    xtrchessreal
    That is something I might just get, there are even cheaper ones on Amazon. $43 for two batteries and the tool. I'm just DIY so only need it for skid plate for fluids change maybe a belt change. That is less than a set of wrenches, who cares if it breaks down after a year or so, get a new one.
    MadNachos[QUOTED] likes this.
  6. Sep 3, 2024 at 2:47 PM
    MadNachos
    Laxtoy and Black97v6MT like this.
  7. Sep 3, 2024 at 3:00 PM
    Glamisman
    Glamisman Well-Known Member
    Tools are one thing... knowing when to stop or not start is just as important. Even a relativley simple job like changing motor oil can go to crap, the drain plug can strip, the oil filter can be on so tight that you have to drive a screwdriver through it to get it to loosen.
    Information is the most important tool... I had a buddy whos windshield wiper motor was non op on his 05 Ram truck. He replaced it and it still didnt work. He called me and I asked him if he put a scan tool on it and his reply was, its only a windshield wiper motor. I said go put your scan tool on it. He called back and said damn... there is a code for it. He replaced a good part for no reason.
    zank90805, ControlCar and Stuck in VT like this.
  8. Sep 3, 2024 at 4:39 PM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    I just used a 24mm :eek: socket on my new specialty engine oil drain plug
  9. Sep 4, 2024 at 4:34 PM
    zank90805
    zank90805 New Member
    I've had my tacoma for about 15 years, all I had was a breaker bar, 1/2 socket set, adjustable crescent, 1 jackstand, plyer, and screwdriver. Most of the time it was just doing breaks, oil, and the regular fluid. But I did cheat and borrow an extension to reach a bolt to replace a cracked radiator.
    But if you want to make life easier, get a Jack stand, floor jack, breaker bar, 3/8 ratchet and socket set, 1/2 torque wrenches, socket adapter, pry bar, set of combination wrenches, needle nose pliers, screw driver, and if you decide to Treat yourself, get a cordless impact wrench with a set of impact sockets. Impact wrench made my breaker bar obsolete.
    xtrchessreal and MadNachos like this.
  10. Sep 4, 2024 at 4:44 PM
    MadNachos
    A nice cordless impact with some of the swiveling impact sockets is a great investment. And some of the better electric impacts are able to be delicate enough for general use.
  11. Sep 4, 2024 at 5:33 PM
    AW11
    AW11 Well-Known Member
    Frank
    2002 Dbl Cab 4x4 3.4l
    A good floor jack/6-ton stands and oil filter wrench.
    xtrchessreal and ControlCar like this.
  12. Sep 5, 2024 at 4:56 AM
    xtrchessreal
    I actually have this...well pittsburgh harbor freight equivalent. I use it on my skid plate bolts with a deep socket its a 1/2 drive so like a mini breaker if I need it.
    Gorilla ramps are nice and recently bought that cheap $34 harbor freight member deal Pittsburgh creeper, its a bit weird getting used to it, wrenching with it and getting out of it with my fat belly lol its almost a work out. But it is nice to roll easy to the point of target and get that skid plate off, oil plug etc.
    My 2003 XtrCab has 129k miles 21 years old, I'm gonna make it my last vehicle I ever own. Doing Door dash for extra cash to maintain it and add new things for the expenses write off. I did more in DIY repair than I did mileage so actually broke even, doing the same this year. New Tires and rims... Letting uncle sam pay for my repairs is great. I had 5mm on my pads but changed the rotors and switched to ceramic. Still need new LCA bushings and maybe ball joints haven't tested them yet. I don't want to replace the LCA just for bushings but I've seen the youtube vids and its a serious operation. Could take me weeks to do on my own. I only use it for Dashing so nearly 100% expense write off way better than taking the mileage deduction. Next year I'll be done dashing and use my truck for anything. Hell it is just now breaking in. Best Taco year ever.
    Maybe I'll buy a Scamp and go see some friends, camp, fish, either way its gonna get all purdy first. Lite Pod mod er mhhhm front light repair. :oldglory:
  13. Sep 6, 2024 at 10:25 AM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    My little Dewalt 891B impact wrench was one of the best tool buys I ever made. Enough power for everything except a couple spots where bushings absorb the impact and I need a breaker bar and jack.
  14. Sep 6, 2024 at 11:11 AM
    MadNachos
    Yeah, those are great. I am old school and it took me a while to go electric but I have ramped it up in the past couple years. I quite like the 1/2" impact I have, it bangs. Oh...the DeWalt gyro electric screwdriver is a great addition. Plenty of torque and it has very fine control, you just rotate it for the direction, and more rotation makes it speed up. It was a lifesaver when I removed my dash for the heater core. A bit spendy but it's really slick.
    https://a.co/d/cuZrGTF
  15. Sep 8, 2024 at 1:46 PM
    #35
    Black97v6MT
    iMA0
    tacoLand USA
    Get JIS..
  16. Sep 8, 2024 at 2:30 PM
    #36
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    First thing I thought of/came to mind is: Genuine ViceGrips: I have two different sizes and types of the normal ones (large and medium) and one of the smaller needle-nose ones. I have used them on all sorts of jobs and they show it. One is very old, heavy duty and has a trigger-type release. They get the most use.
    A good torque-wrench. I have the turn-the-dial on the handle "Click" type. (3/8ths)
    A good multi-meter.
    Cotter pin/hitch-pin clip removal tool
    Straight/Curved needle-nosed pliers in various sizes.
    Finally: I also have a 6-ton 50 year-old vintage Sears floor-jack my Dad gave me when I got my license. It's heavy, awesome and you can tell by the look of it that it has had a lot of use over the years. It doesn't lose pressure/leak down after it is raised or leak any oil. . :proposetoast:
