What Toyota motors will attach to the automatic A340E?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JP2, Aug 26, 2017.
  1. Aug 26, 2017 at 2:20 PM
    JP2
    JP2 [OP] Member
    Edit mistake:
    A340E (30-40LE)?
    I have a 2000 Toyota Tacoma with 3RZ-fE and automatic transmission. I want a Toyota motor swap that will connect to the automatic transmission. I'm seeking Toyota motors that will attach with either a bell-housing or an adapter but does not require a new driveshaft. Any motor other than the 3.4 L 5VZ-FE V6 because it is my last choice.
  2. Aug 26, 2017 at 2:30 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    2tr-fe about all I can think of.
  3. Aug 26, 2017 at 4:43 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Fwiw, w59 is the manual transmission behind the 2/3rz. A340 is the auto behind the 2/3rz, 5vz, and 2uz.
    vern650 likes this.
  4. Aug 27, 2017 at 2:39 PM
    JP2
    JP2 [OP] Member
    Thank you, I could not locate the code for the automatic.
  5. Aug 27, 2017 at 2:52 PM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Why is the 5VZ-FE your last choice?
  6. Aug 27, 2017 at 3:01 PM
    JP2
    JP2 [OP] Member
    I was curious about the motors producing 250 or more horsepower and which would attach to the A340.
  7. Aug 27, 2017 at 3:03 PM
    TacomaJunkie8691
    WA State
    Dear JP2,
    Are you more inclined to go with the second generation Tacoma 4.0 V6. I doubt that will bolt up to your existing transmission.
    Good Luck,
    Paul
  8. Aug 27, 2017 at 3:05 PM
    JP2
    JP2 [OP] Member
    My intent is to only pay for the installation of a motor that will bolt up using a bell housing and produce 250 horsepower or more.
  9. Aug 27, 2017 at 3:08 PM
    TacomaJunkie8691
    WA State
    Jp2,
    So you have a 2000 Toyota Tacoma with the 3RZ motor, and the A340 automatic transmission. I hate to be the one to tell you, but you have limited engine choices if you want to continue to use your existing transmission.
    Take it easy,
    Paul
  10. Aug 27, 2017 at 3:12 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Forget it. Only motor that checks some of those boxes is the early non vvti 2uzfe but it will require moving back your trans (amongst a million other things) to fit in. Look into boost instead
    Running Board Man likes this.
  11. Aug 27, 2017 at 3:12 PM
    JP2
    JP2 [OP] Member
    It appears like the following would work with the corresponding bell housing.
    "A340E (30-40LE)
    The detachable bell housing, which attaches the main transmission case to the engine, has an engine-specific bolt pattern, which appears on its upper surface as cast-in letters. "J" indicates the straight-6 1/2-JZ engine, "U" the V8 UZ engine.
    Applications:
    1 2 3 4 Rev
    2.804 1.531 1 0.705 2.393
    https://en.wikipedia.org/wiki/Toyota_A_transmission#A30
  12. Aug 28, 2017 at 9:49 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Well if you're really into it, Chrysler used the A340 series trannies as AX-4s in Cherokees too. But I think you're barking up the wrong tree here. The motors producing more than 240HP don't commonly use the A340. The Tundy did for a bit but that's really about it and you'll still spend twice the cost of a new transmission in fabrication of motor mounts, tranny cross members, and new drivelines. Not to mention the wiring and work to adapt a different evaporative emissions system (needed to pass vehicle registration in many states) Believe me there is NO easy drop in and mate it up solution to your question. It isn't even easy to swap an auto 4cyl to a manual because so much of the frame structure and wiring changes on a year by year basis. I'm doing a body, engine, tranny, wiring swap right now... there is no easy peasy cheap way to do it. It will cost thousands if you don't already have a few free donor trucks and all the new expendable shit like gaskets and various parts the give you trouble.
    TacomaJunkie8691 likes this.
  13. Aug 28, 2017 at 10:49 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    If you can find an early 03-04 4.0L from a 4Runner they had the A340 bolted to it. Not sure of HP specs tho.
  14. Aug 28, 2017 at 11:54 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    if you're doing an engine swap having to lenghten/shorten the driveshafts is a pretty small thing compared to all of the other work required.
  15. Aug 28, 2017 at 11:57 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Which does open up possibilities of sbm v8s v6s etc. Among other brands
  16. Aug 28, 2017 at 12:00 PM
    jmaack
    Justin
    Helena Alabama
    Mmm 4.0 ho Tacoma......one can dream.
  17. Jan 28, 2019 at 1:05 AM
    BatteredTaco
    BatteredTaco Well-Known Member
    J Lo
    SoCal
    02 3rz stick 4wd ext
    JDM 3rz@300k Yota1 cylhead@400k ARB-OME 880/5100s
    Can one swap a 3vz, backed by an a340e, with a 3rz. Easier than a 5vz?
  18. Jan 28, 2019 at 1:20 AM
    Speedytech7
    It won't be easier that's for sure. The a340e isn't exactly desirable to keep either, or the hydro t case. The 5vz bolts right in place of a 3vz though. The 3rz mounts are different both engine mount wise and bell housing wise
  19. Jan 28, 2019 at 1:25 AM
    BatteredTaco
    J Lo
    SoCal
    I was day dreaming of a turbo 1 ton Dually, the U-Haul.
  20. Jan 28, 2019 at 1:34 AM
    BatteredTaco
    J Lo
    SoCal
    Diggin your 95.5 build!
    Speedytech7[QUOTED] likes this.
