What TPS - Throttle position sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zer0, May 15, 2014.
  1. May 15, 2014 at 5:46 PM
    Zer0
    Zer0 [OP] Well-Known Member
    SGV, California
    99 PreRunner
    What is TPS and what does it do? How can you tell if TPS is bad? I have sluggish acceleration only from a dead stop. A little sluggish acceleration is only between 1-2K rpm. After that truck is normal it seems. Thanks
  2. May 15, 2014 at 10:20 PM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    When mine went on my 3.4 it would stall when in traffic. It would stumble and idle rough when sitting still in gear (auto trans). Then when traffic would start moving it would stumble and stall as I have it throttle. Half the time it would stall the other half it wouldn't.
  3. May 15, 2014 at 10:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It is a variable resistor attached to the throttle butterfly that tells the injection system how far down the accelerator is depressed.
    When it goes bad, it will tend to go "open" and tell the ECU that the throttle is closed, so you go lean and stumble.
  4. May 15, 2014 at 10:28 PM
    Trapperr
    Reno, NV
    Is it weird to not get a CEL when it goes bad? I don't recall it ever coming on in my 01 when it went bad.
  5. May 15, 2014 at 10:56 PM
    Zer0
    SGV, California
    99 PreRunner
    Thanks for the replies. Could this be related to a sluggish acceleration issue from a dead stop? The sluggish acceleration only happens before 2k. After that, the acceleration is fine.
    I also have this weird issue with gas pedal. Sometimes, not all the time, when I press on the gas pedal from a dead stop, it feels like its stuck and doesnt want to go down. Almost to point where I have press on it hard for it to finally go down. And when I press on it hard, it will finally go down and the car accelerates fast because of it. Any ideas? Would this this be related to a TPS or something else? Thanks
  6. May 15, 2014 at 11:14 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Sounds like you have another issue.
  7. May 16, 2014 at 4:46 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Sluggish Acceleration can usually be solved in 2 ways. The TPS can be replaced in 1 min, a $50 item that has 2 screws and a electrical plug. Cleaning the Throttle Body and the Idle Air Controller at the same time (Without taking it off of the Throttle Body) with Throttle Body Cleaner and a whole mess of Q-Tips.
    As for a sticky Gas Pedal, that either means you have something stuck on your pedal or the wire to the Throttle Body is bent or frayed somewhere, and that's a whole different ball of wax.
  8. May 16, 2014 at 5:16 AM
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    I got a CEL when mine went bad. Before the CEL my truck would stumble and it would jerk at different speeds, I thought it was my transmission at first so I took it to the dealer (it was still under warranty) and they thouroughly check my transmission and said everything was good. About a week later the TPS crapped out, once replaced it's been fine.
  9. May 16, 2014 at 5:17 AM
    Rons01TRD
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    What he said, I would make sure your throttle cable is not binding somewhere.
