What trail only rig would you chose? If you had to do it again-or for the first time...
Discussion in 'Off-Roading & Trails' started by stealthmode, Feb 12, 2020.
Whats rig of choice?
  1. Jeep Cherokee (prior to 2000s)
    6 vote(s)
    7.6%
  2. Jeep XJ
    15 vote(s)
    19.0%
  3. Ford Bronco II
    2 vote(s)
    2.5%
  4. Ford Ranger (solid front axle)
    2 vote(s)
    2.5%
  5. Taco Sauce Only
    51 vote(s)
    64.6%
  6. Jeep Grand Cherokee
    3 vote(s)
    3.8%
  1. Feb 16, 2020 at 3:38 PM
    #81
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Detroit locker is most definitely cheaper than the air locker. Air locker is great if your going to have kids and wives drive your shit on the open roads.
    I have had both auto and manual, all depends on what you are going to do with it. Most of my rock crawling vehicles have autos.
    The Suburban was a freaking great vehicle, we have had 3 of them, been driving them for over 30 years. Problem is like everything else, they break down. Wife lost a wheel at 80mph in this one, I am currently doing a SAS with 1 tons now. It's going to be a monster when I am done with it.20170531_081123.jpg
  2. Feb 17, 2020 at 9:05 AM
    #82
    stealthmode
    stealthmode [OP] Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Good info thank you. If I see anything in the ball park I'll keep this in mind. Long term durability is deffinately a bonus.
    Did you see the 1000 4 runner I posted above?
    Crawl box - you mean after market transfer case?
  3. Feb 17, 2020 at 9:10 AM
    #83
    stealthmode
    Alberta
    Yeah its nice to have the ability of keeping upward momentum with the autos.
    I was just talking to the wife about a 7 or 8 seater yesterday. Laying the ground work :bananadance:. Fun side project
    Mully[QUOTED] likes this.
  4. Feb 17, 2020 at 9:12 AM
    #84
    stealthmode
    Alberta
  5. Feb 17, 2020 at 9:15 AM
    #85
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    A regular cab powerstroke with a zf5 or zf6.
    stealthmode[OP] likes this.
  6. Feb 17, 2020 at 9:41 AM
    #86
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Yea it's a reduction unit that goes in between the trans and the transfer case multiplying the low range down stream. Meaning if you have a 4:1 crawl box you multiply that by the low range of the transfer case, allowing you to crawl really slow and multiplying the torque. Example being I have a 2.28:1 crawl box, 4.7:1 low range in the transfer case for a total of 10.71 in low low range. Comes out to a few thousand ftlbs of torque when you factor in the trans and diff gears.
    My advice is always wheel what you have stock ALOT that way you know what you want or need and you dont waste money on useless mods. Most of the Tacoma's you see here decked out with LED lights, roof racks, extra fuel cans etc fall into this useless mods category IMO. For the record I have to drive 8hrs on the highway one way to my closest wheeling area and I can fit everything I need in the bed or back of the extra cab for a week of wheeling/camping, in this thing:
  7. Feb 17, 2020 at 9:43 AM
    #87
    eon_blue
    Azusa, CA
    Would kill for a crawl box, to be able to actually crawl up obstacles without feathering the clutch sounds like heaven. Definitely on the to do list for the future
  8. Feb 17, 2020 at 9:44 AM
    #88
    slander
    Hickory, NC
    Best mod ever!!
    eon_blue[QUOTED] likes this.
  9. Feb 17, 2020 at 8:47 PM
    #89
    stealthmode
    Alberta
    So you would have to get a modified (shorter) drive shaft if you are adding onto the transfer case then ? That's a
    I've seen a video on TW with a guy who has some insane ratio. Cant remember what it was but was a white taco.
  10. Feb 17, 2020 at 8:48 PM
    #90
    stealthmode
    Alberta
    You crazy ! But that said I have my search filter set up for any trucks below 2500 and ALOT of diesels and miled out full size and 1 tons pop up.
    It is a possibility if I smash a case and squint really hard
  11. Feb 17, 2020 at 8:54 PM
    #91
    slander
    Hickory, NC
    Yea 8" shorter rear and 8" longer front.
  12. Feb 17, 2020 at 8:58 PM
    #92
    Mully
    CA
    Marlin Crawler's truck. Running 40s and a crawl box. Check out there site.
  13. Feb 18, 2020 at 11:23 AM
    #93
    stealthmode
    Alberta
    Did ya see the 2000 buck 4 runner? Would you wheel that?
    YES! That is the one. I watched the video of the Taco rock crawling...pretty nice set up.
    Seems like that's the mechanical equivalent to the fancy new electronically controlled crawl control. My choice would be mechanical if $$$ wasn't a factor. Others here with the Off Roads or with new 4 runners may disagree though
  14. Feb 18, 2020 at 11:25 AM
    #94
    slander
    Hickory, NC
    No just because I dont like that generation of 4runner. I have a friend who has one that same year ad the one you posted on 37s, solid axle, dual cases, exo cage and a 3.4 swap.
  15. Feb 18, 2020 at 6:33 PM
    #95
    stealthmode
    Alberta
    Screenshot_20200218-193623_Kijiji.jpg This evenings find.
    :pccoffee:
    Cheapest Yota I've seen. 1300
    @slander
  16. Feb 19, 2020 at 5:52 PM
    #96
    stealthmode
    Alberta
    Mully likes this.
  17. Feb 20, 2020 at 1:10 PM
    #97
    TACO ROCKO
    TACO ROCKO No Known Boundaries
    Western States
    Taco Sold/FJC Dead/Bowtie Boy
    Locked, 1 Ton SAS, 38"s, winch, swingout, OBA, LS Powah
    This is an open-ended question. If you told me I had carte-blanche to build a dedicated trail truck that was street-legal and could also be used to camp out of, I'd build a Jeep LJ on tons, 40s, ORIs, and Hemi-swapped with a 30 gallon GenRight tank. I'd pull a surplus trailer with a tent on it behind it.
    But to keep it realistic, of the stuff you're considering, it'd be hard to beat a Jeep ZJ with the 5.2L. It's actually got the cargo room to be a comfortable 5 night touring truck, and it's already got a solid axle. The Dana 30 is dog doo doo compared to heavier axles, but is still considerably stronger than any factory IFS offering from Ford, Toyota, or otherwise. So if you stuck with 33"s you wouldn't even need to source Waggys or Rubis and swap it. Find one with a 231 t case and you're set for under $7500 built.
    stealthmode[OP] and Mully like this.
  18. Feb 20, 2020 at 1:19 PM
    #98
    Mully
    CA
    Nice. Were building a WJ right now. Long arm, 3 linked, trussed Dana 44, V8. Having wheels powered right now. Got a 10K winch and a full steel plate bumper ready for it also.
  19. Feb 20, 2020 at 1:21 PM
    #99
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    That's rad as hell. Do people have 4wd VW's?
  20. Feb 20, 2020 at 1:23 PM
    #100
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Can you talk about some of the pros and cons of like an Eaton G80 vs the E lockers like on the Tacos?
