What transmission fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GreggyG, May 15, 2022.
  1. May 15, 2022 at 2:55 PM
    GreggyG
    GreggyG [OP] Well-Known Member
    I have a 2011 4x4 TRD off road. The manual says Toyota type I-IV for 4 speed and Toyota WS for 5 speed. Is there a way to tell besides trying to count gear shifts?
  2. May 15, 2022 at 3:52 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you have the 2.7L 4cyl engine you have the 4spd A340F transmission, if you have the 4.0L V6 you have the 5 spd A750F transmission.
    The A340 has a dipstick, the A750 does not and has a fluid level check procedure.
  3. May 15, 2022 at 3:54 PM
    Bishop84
    Bishop84 Well-Known Member
    Also shift will show D 4 3 2 1 on a 5 speed D 3 2 1 on a 4 speed.
    Ricardo13x and Robnik like this.
  4. May 15, 2022 at 3:56 PM
    GreggyG
    Thank you very much!
  5. May 16, 2022 at 6:54 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    On the 5 speed you can use WS or Valvoline Maxlife.
  6. May 16, 2022 at 6:59 AM
    GreggyG
    excellent, thank you
  7. May 16, 2022 at 2:28 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    For around 10 years, I have been running Mobil 1 ATF in my 2010 Prerunner. V6 which should have the 5 speed.
    07 sport 4x4 likes this.
  8. May 16, 2022 at 2:55 PM
    GreggyG
    Thank you
  9. May 16, 2022 at 10:25 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    This
