What type gas to you use?
Discussion in 'Performance and Tuning' started by jimmy1963, Mar 3, 2013.
  1. Mar 3, 2013 at 12:52 PM
    jimmy1963
    jimmy1963 [OP] Well-Known Member
    Arkansas
    2013 4x4 Tacoma DCSB TSS
    Stock
    Low, mid or super?
    Here in AR the low and mid can have up to 10% ethanl.
    Several stations now have super with NO ethanol.
    I try to run the super in my small engines, but run all the others (depending on cost) in my truck and car.
    What do you run and why?
  2. Mar 3, 2013 at 12:54 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
  3. Mar 3, 2013 at 12:55 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
  4. Mar 3, 2013 at 1:00 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    The Lone Star Republic
    01 Tacoma TRD 4x4 v6
    Lots 'o stuff. Look at my build! -->
    regular, because it's cheap...er than the others
  5. Mar 3, 2013 at 1:00 PM
    Colton
    Colton Reagan/Bush '84
    Colton
    VA
    '08 4X4 TRD Sport Super white
    Pelfreybilt 3-hoop bumper, Bilstein 5100 F&R, OME 886 w/driver side top plate spacer, 1.5" AAL, 315/70/17 Hankook Dynapro AT, 17x9 Level 8 MK6, 20% tint, AEM Brute force intake, Alpine CDE-W235BT, Armortech sliders
    89-93
  6. Mar 3, 2013 at 1:03 PM
    jimmy1963
    Arkansas
    Stock
    I assume the gas in your area has ethanol in it.
    If so has it caused you any problems?
    I never had problems with my 96 tacoma and am not looking for any with my new one. :)
  7. Mar 3, 2013 at 1:09 PM
    jgwheeler17
    NC
    yes
    no
    previous owner put 80,000 miles on my truck on regular gas (all second gens are supposed to use mid or high grade... atleast the 4.0ltrs) but i decided not to change it after that many miles.
  8. Mar 3, 2013 at 3:52 PM
    CoalMedic
    CoalMedic Molon Labe
    Southern Illinois
    2011 PreRunner SR5
    AVS Rock Guard, in channel visors, Ranch topper, Alpine INA-900BT
    I run 87 in my 2011 4.0, nary a problem in 60,000 miles. I run it mostly because it's cheaper than the others and I usually fill up at least once a week. My record is 4 times in a week. Commuting over an hour to work sucks sometimes. My wallet jumps out of my pocket and runs away when I pull up to a pump.
  9. Mar 3, 2013 at 3:57 PM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    Run 91-93 simply because I need to with the mods I've got
  10. Mar 3, 2013 at 4:09 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Here
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, Volant cold air intake with ram air scoop.
    91. It's only a few bucks more per tank, so why not?
  11. Mar 4, 2013 at 1:42 AM
    01kingtaco
    01kingtaco Well-Known Member
    Kodiak
    Maui hawaii
    01 taco slightly modded
    Bigger tires, sound system, deck plate mod, fog light mod, straight pipe exhaust, blue led floor lights, ultragauge, 3 inch lift
    89 non ethanol all the way!
  12. Mar 4, 2013 at 4:10 AM
    Justus
    Justus fucks not given
    Brock
    Paso Robles
    stockish
    91, never ran anything less in 3yrs.
  13. Mar 4, 2013 at 7:32 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    Low.
    How many posts to this thread before someone says they use premium b/c it yields better gas mileage.
  14. Mar 4, 2013 at 1:55 PM
    jimmy1963
    Arkansas
    Stock
    LOL, I have heard that premium does yeild better gas mileage.
    Now as far as small engines go, the only reason I run super is because they set for a while and I read where ethanol in the low grade gas breaks down someway.
    I am by far no expert.
  15. Mar 6, 2013 at 10:38 AM
    TonyK14
    TonyK14 You're welcome
    Tony
    Nor Cal
    07 PreRunner TRD Sport
    Lifted, wheels
    stock motor = cheap stuff all the way
  16. Mar 11, 2013 at 10:35 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    An engine doesn't 'get used to' a certain octane. You can start using 93 if you want. I often switch between 87 and 91 depending on how much cash I have. Never had a problem. If your truck starts running funny from switching octanes then something isn't right.
  17. Mar 11, 2013 at 10:42 PM
    adio
    adio Do. Or do not. There is no try. -Master Yoda
    EWA BEACH, HI
    2015 INFERNO TRD PRO
    Bought, not built:-P
    87 cheaper
  18. Mar 11, 2013 at 10:47 PM
    bojinns
    bojinns Well-Known Member
    JB
    NOVA
    06 Taco TRD Sport
    AFE CAI | AFE Cat Back | URD MAF | ICON Stage I | Icon AAL
    93 octane sometimes 91
  19. Mar 11, 2013 at 10:48 PM
    MightyMouse-SCT
    MightyMouse-SCT Well-Known Member
    Gabriel
    O'SIDE CA
    MightyMouse-SCT - 2011 LT 4x4 Desert Runner
    Long Travel Total chaos kit, fox shocks, smp fab , dmz sua, glassworks, method wheels.
    Gas is up $1 a gallon , so low 87
  20. Mar 13, 2013 at 6:09 PM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
