What type of antifreeze?
Discussion in '1st Gen. Tacomas (1995-2004)' started by OldmanBob, Jul 6, 2018.
  1. Jul 9, 2018 at 5:52 PM
    #41
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    This thread has really gone off the rails, so I don't feel too bad in asking this. How *do* you dispose of your old coolant? Properly, I mean.
    Edit: What I'm really asking is this: What is the proper means of disposing of old coolant?
  2. Jul 9, 2018 at 6:44 PM
    #42
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Color is irrelevant, there is only 3 types of coolant. Iat, oat, and hoat. The biggest difference between them is service intervals, toxicity, and ability to fight hard water and scaling.
    Iat is the typical green that has been used since the beginning of time. Oat came about in the 90s and is what both Dexcool, and hoat is what most modern coolants are, I.e. Toyota red, pink, the universal stuff, etc. are and are a hybrid of both the iat and oat to get the best of both worlds.
    http://blog.chiltondiy.com/2013/06/which-antifreeze-is-right-for-your-vehicle/
    https://parts.olathetoyota.com/blog/ultimate-coolant-color-guide
  3. Jul 9, 2018 at 6:59 PM
    #43
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    My oem rad went out around 200k, replaced with a off the shelf from parts place. Just used the old green stuff and it cools just fine. However all other parts I use Toyota oem now. I’m wanting to get everything needed to replace my VC gaskets but after gunny quoted me I can’t seem to get ahold of him. Been over a week now with no response.
  4. Jul 9, 2018 at 10:26 PM
    #44
    Indy
    Indy Master of all I survey.
    I only wear green socks and I've gotten over 300k on mine.
    Wulf likes this.
  5. Jul 16, 2018 at 11:45 AM
    #45
    Bobothehobo
    Bobothehobo Well-Known Member
    1999 SR5 3.4l
    Don't mix types of anti freeze. My 99 was like that when I bought. Several flushes and radiator change later and the smaller lines were still clogged (heater control valve, iac valve and lines, heater core)!!!
  6. Jul 16, 2018 at 12:31 PM
    #46
    04tacoma trd
    04tacoma trd Well-Known Member
    A couple of years ago on Velocity channel I saw a resto-mod where they used a water-less anti-freeze product. I wonder if that stuff is still around.
  7. Jul 16, 2018 at 6:31 PM
    #47
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    I'm just wondering what people do their old coolant? In California I'm recommended to take it to the hazmat center...
    Is it recycled? Or end up in a barrel incased in concrete and layed to rest in Beatty, NV? Or are you guys poring into the used motor oil tub?:bananadead:
  8. Jul 16, 2018 at 10:21 PM
    #48
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    Where I live in the winter. I let mine warm up for about 15 minutes every morning when it's really cold outside. I try not to put it into gear until the scanaguage reads at least 100 degrees. In the summer? The same thing. Minimum of 100 degrees before I put it into gear. I like 120 degrees better but time sometimes doesn't allow for that. Not every time but 98% of the time. On really cold days "30 degrees or colder" I never turn the engine off even if I'm going to the local grocery store. Unless, I know I'll be in there fore at least 15 minutes. For short 5 minute stops at the local convenience store I never shut it off. I never shut it off when gassing up either since the Taco has the exhaust running down the opposite side of the truck. Starters are expensive and a PIA to install. Not only that, but "duty cycle" has a lot to do with longevity of any engine. Engines last longer running all the time than those that are stopped and started 5 times a day or more.. Witness the mileage they get out of Cabs and Police vehicles which are never shut off. You can go longer between oil changes that way as well.
  9. Jul 16, 2018 at 10:27 PM
    #49
    TRVLR500
    Wyoming
    You should always take it to a reclamation center which I always did until I moved to Wyoming. I will look around again when I change mine at the end of this summer. The last time, I went to every auto parts store in the area and none would take old anti-freeze. The local dump would but that's not possible for me due to my job. After 3 months of searching I just dumped it down the toilet. Not good. I'll continue my search so I don't have to do that ever again. Maybe I'll have a friends wife take it to the dump.
    In Kalifornia there is no reason whatsoever to NOT take it to an approved "dump center". Out there just about any auto parts store will take used anti-freeze.
  10. Jul 16, 2018 at 10:58 PM
    #50
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  11. Jul 16, 2018 at 11:10 PM
    #51
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    I'm in Wisconsin and I never wait that long warming up in the am. Start and wait a few seconds before I drive off just don't get on it heavy
  12. Jul 16, 2018 at 11:13 PM
    #52
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yup. Does not seem possible to simply answer the question. Have to debate every little goddamn thing lately.
    License2Ill and skeezix like this.
  13. Jul 16, 2018 at 11:20 PM
    #53
    Wulf
    Wulf no brain just damage
    rock raisin
    No we don't :luvya:
  14. Jul 16, 2018 at 11:22 PM
    #54
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Call in the cavalry!
    :deadhorse::deadhorse::deadhorse:
    ...Or something.
  15. Jul 16, 2018 at 11:24 PM
    #55
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    :facepalm:
  16. Jul 16, 2018 at 11:26 PM
    #56
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Can we all just start down voting old man river's videos, I swear that guy might have known something back when the pioneers were driving rocks, but he's just an old car xenophobe now
    Wulf likes this.
  17. Jul 17, 2018 at 7:29 PM
    #57
    TRVLR500
    Wyoming
    IMHO I can't see a problem with anyone who drains the minuscule radiator on a 2.7 and re-fills it with new coolant every oil change if they can afford it. I'm seriously thinking about draining my radiator and reservoir at the end of every summer.
  18. Jul 17, 2018 at 7:31 PM
    #58
    Speedytech7
    I take the damn thing apart often enough that I don't think if could ever go bad haha
    TRVLR500[QUOTED] likes this.
  19. Jul 17, 2018 at 9:34 PM
    #59
    tony2018
    tony2018 Well-Known Member
    walmart collects the coolant or check with your local trash collector.
    I stick to what I know works for longer periods, I'm not gonna shoot someone in the foot for doing something different from me. your ride, my ride.
  20. Jul 17, 2018 at 9:37 PM
    #60
    TRVLR500
    Wyoming
    Good Idea! I never went to WalMart. I'll bet they do. I'll check them out.
