What type of coolant for 1998? Red or Green?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Killer, Jul 6, 2010.
  1. Jul 6, 2010 at 7:34 AM
    Killer
    Killer [OP] Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    I do not have an owner manual for a 1998 Tacoma. I have a manual for a 2000 that says Toyota Long Life coolant (which I assume is red).
  2. Jul 6, 2010 at 7:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    People have flushed the entire cooling system, and used the green with no issues.
    koditten likes this.
  3. Jul 6, 2010 at 7:37 AM
    Killer
    Mobile, Al.
    Why is green more preferable? Is it because of cost, long life or availability?
  4. Jul 6, 2010 at 7:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cost.
  5. Jul 6, 2010 at 7:45 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I really don't think it matters.... as long as you get the proper 'mixture' of distilled water & coolant for the appropriate level of protection, you'll be fine.
  6. Jul 6, 2010 at 8:14 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I never mix or switch1
  7. Jul 6, 2010 at 9:45 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I would drain it and fill it with distilled water, run it, drain it again and then just fill with Toyota red mixed with distilled water.
  8. Apr 23, 2013 at 6:58 AM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    sometimes it is false savings to use the cheaper green stuff. I know that in the case of the older Mercedes, you stick to their mix. It was formulated for the metals in the engine block etc...don't know if this is the case with Toyota
  9. Apr 23, 2013 at 7:02 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I just did mine and the toy long life at my dealer is $40 a gallon.
  10. Apr 23, 2013 at 7:09 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    red is stock and what toyota wants
    just use prestone 50/50 for all vehicles all types
  11. Apr 25, 2025 at 9:48 AM
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    the green costs more than the red.
    JustADriver likes this.
  12. Apr 25, 2025 at 9:53 AM
    Blakeus Maximus
    Blakeus Maximus Well-Known Member
    Southwest
    2000 TACOMA TRD 4X4
    Im sure its way more expensive than it was 12 years ago when this thread was created. :boink:
    98_3RZ_NIC likes this.
  13. Apr 25, 2025 at 9:54 AM
    98_3RZ_NIC
    you’re not wrong
  14. Apr 25, 2025 at 10:06 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Why quibble over a 2-dollar difference? Use the red Aisin pre-mix from Zerex and be done with it.
    shankyjones likes this.
  15. Apr 25, 2025 at 11:03 AM
    shankyjones
    shankyjones Well-Known Member
    Richard
    Marina CA
    2003 Brown Tacoma Prerunner V6 3.4L TRD
    Toyota Maintenance youtube channel and Car Care Nut always say RED
  16. Apr 25, 2025 at 5:25 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Once you replace everything with non-OEM you get to use generic orange :luvya:
  17. Apr 25, 2025 at 6:52 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    IF you switch from asian.....its the devil to get it out
    even after 6 flushes over several weeks....it still keeps coming out pink
    the aluminum gets like a velveteen coating over time and age
  18. Apr 25, 2025 at 6:56 PM
    O'Silver_Taco
    MD
    IF you do use the red, or any, just dont try to stretch it 7yrs......thats just stupid
