What type of offset?
Discussion in 'Street Trucks' started by Mr.Schertz, Apr 28, 2013.
  1. Apr 28, 2013 at 8:47 AM
    Mr.Schertz
    Mr.Schertz [OP] Well-Known Member
    TEXAS
    08 single cab 4banger
    tint,removed badges,custom letter chop and rephrase
    What offest should I be looking for to keep the tires from sticking out past my fenders? I have a 5 lug,2008
  2. Apr 28, 2013 at 8:49 AM
    Mr.Schertz
    TEXAS
    i assume anything with a 30 or 40 mm offset?
  3. Apr 28, 2013 at 8:52 AM
    Rock004
    Rock004 New Member
    Bartlett Tn
    tacoma
    3" lift
    the larger the backspacing, the less they'll stick out. for example, a 3.25 backspacing will stick out further than a 3.75 backspacing..
  4. May 7, 2013 at 10:46 AM
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers
    I was running a 30mm and it was almost flush, I ordered a set with 35mm hoping to get closer but I don't have them in yet to tell you if they are or not.
  5. May 8, 2013 at 3:04 AM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    +30mm and your about flush to the fenders. with a +35mm, you end up going 0.5" inside the wheel well more (my rims have a +35mm offset). This link helped me.
    http://www.willtheyfit.com/index.ph...er2=18&wheelwidth2=9&offset2=15&Submit=Submit
    going higher on the POSITIVE offset will put the rim inside the wheel well more, going toward the NEGATIVE offset, you will end up sticking out the wheel well.
