what type of plugs did you put back in
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09 tacoma trd, Mar 1, 2009.
what type of plug did you put back in
  1. denso copper
    28.5%
  2. denso iridium
    25.2%
  3. ngk copper
    9.1%
  4. ngk iridium
    24.8%
  5. other
    12.4%
  1. Mar 6, 2009 at 5:21 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    Where are you guys finding the Denso Copper's?
    Never mind found some
  2. Mar 17, 2009 at 3:40 PM
    MurphyZ
    MurphyZ Well-Known Member
    I HATE SPICYTACOS
    Alaska
    97 4runner, 08 Tundy
    89 SAS 3.4 1st gen 4runner- Sold 3.4 swap cut hood for clearance exhaust x-over and magnaflow muffler lockright in the rear SAS 83 toy axle (Wab-Fab) 4xinnovations sliders roof rack from 2nd gen for kayak.
    that is just a funny sentence haha
    i put in autolites and thet were great
  3. Mar 17, 2009 at 3:43 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    My Dad got me some NGK Iridiums for dirt cheap.
  4. Jul 16, 2009 at 9:30 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I will not use any other plug but NGK or Denso. I have heard of too many Autolite failures. Champion isn't bad but I have had great results with NGK and Denso. Losing spark on a cylinder isn't as bad as dropping a cylinder on a motorcycle. Especially if you have two or less.
  5. Dec 13, 2009 at 9:27 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Dunno about what happened to splitfire but I have NEVER used anything but denso for the most part maybe ngk a coupla times when store didn't have denso in any toyota since 1976. Anything else got chewed up and spit out in less than a month just like you never changed them.
    The craptastic autolites that the dealer left in my 05 during the "165 pt preowned certification" (which is bullshit ad gimmick) weren't even close to the denso iridiums that the 05 2.7l 4 cyl calls for as oem other than the thread pitch. They were at least 1/4 to 3/8ths" shorter than the densos & immediately upon replacement made the cold start idle uncrazy and motor ran noticeably smoother all the time. Denso or NGK FTMFW in japanese cars/trucks.
  6. Jan 2, 2010 at 7:48 AM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Just hit 30,000 miles and I installed 6 denso iridium plugs yesterday, new air filter (engine), new air filter (cabin), adjusted my head lights and installed the high lift jack in the bed. Took about 4 hours taking my time for everything but it works fine.
    The darn iridium plugs were ~$8 each (plus tax) but I had a $10 off coupon for Advanced Discount Auto Parts so it wasn't that bad.
    Thanks to Chris 4x4 for the step by step DIY or it would have taken MUCH LONGER for me to figure what had to be removed from the drivers side.
  7. Jan 2, 2010 at 7:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    :woot:
  8. Feb 10, 2010 at 3:14 PM
    TacoSupreme
    TacoSupreme Well-Known Member
    007 DC Cuatro Por Cuatro
    I replaced mine with denso copper. Got them for 2.75/ea from the dealer. I gapped mine to .041. I did notice the NGK plugs that I took out had a gap of .049? Any idea what that's all about? This is for a '07 DC 4.0 4x4.
  9. Feb 10, 2010 at 4:01 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    The gap will widen over time between the electrode and ground due to the sparking process, it's normal.
  10. Feb 10, 2010 at 4:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For some reason, The NGK's seem to not hold a gap as well as the Dneso plugs. I have noticed this on every Tacoma I have changed the plugs on, or have had people report to me.
  11. Feb 15, 2010 at 4:26 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Platinum and Iridium plugs keep their gap longer. I just got some Denso Iridium plug's for my truck. Just remember, for the Gen 1 3.4L, you need a twin ground plug (or at least its recommended in the user manual).
  12. Feb 15, 2010 at 4:39 PM
    mattcombs
    mattcombs Well-Known Member
    matt
    hazard kentucky
    SR5 tacoma 4wd
    3in revtec lisf westin step bars and westin bull bar and some other odds and ends
    anyone ever used those e3 plugs , , how are they?
  13. Feb 15, 2010 at 5:32 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    I put E3's in mine at about 30,000 miles, 7,000 miles ago. No better gas mileage. It runs strong. I tow a 4,000 lb camper and no problems. I'll probably pull them out at 50,000 and see how they look. I figured they had to be better than two different kinds from the factory.
  14. Feb 15, 2010 at 5:37 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    ive heard alot of good storys using them in chevys and stuff but hadnt heard how thay perform in toyotas . . im probly gona give em a try
  15. Feb 15, 2010 at 7:15 PM
    #35
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    6 denso coppers in my garage. they go in tomorrow. figured i'll stay with the 30k mile interval anyways, no sense stepping up from copper.
  16. Feb 15, 2010 at 8:34 PM
    #36
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    x2...installing mine this weekend!:D
  17. Feb 16, 2010 at 2:31 PM
    #37
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    I use Denso Iridum U-gaps. No difference in power or fuel economy the computer on the 2.7L will fight anything you do to it. Then when its fighting a loseing battle it goes into a type of "limp mode".
  18. Feb 16, 2010 at 2:37 PM
    #38
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    I wanted to try out the new E3 spark plugs, so I bought those and installed them. I like them because I didn't have to gap them and I got them a good deal on them because I have an account at O'Reilley's.
    Also, they're rated at 100,000 miles so I don't have to worry about swapping them out anytime soon.
  19. Feb 16, 2010 at 4:01 PM
    #39
    b10751
    b10751 Member
    Just put Denso coppers in my V6 this weekend..
  20. Feb 16, 2010 at 4:18 PM
    #40
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I put in Denso copper cores.
    IIRC, the plugs are supposed to be gapped at .041. The old Densos were at about .045-.046. The old NGKs were at about .055-.056.
