what type of plugs did you put back in
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09 tacoma trd, Mar 1, 2009.
what type of plug did you put back in
  1. denso copper
    28.5%
  2. denso iridium
    25.2%
  3. ngk copper
    9.1%
  4. ngk iridium
    24.8%
  5. other
    12.4%
  1. Apr 19, 2012 at 5:53 PM
    #101
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks. Sounds like the throttle body cleaning was what solved your problem - plugs were OK. Wonder what plugs look like from some one who didn't change them til 100k. Thanks for the reply.
  2. Apr 20, 2012 at 8:07 AM
    #102
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Oh e em
  3. Jun 18, 2012 at 11:56 AM
    #103
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  4. Sep 23, 2012 at 7:54 AM
    #104
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    NGK copper if you have the v6. Dont waste your money with the iridiums if you have the v6.
  5. Sep 23, 2012 at 8:45 AM
    #105
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    and what about a torque wrench? or do you guys just hand tighten them?
  6. Sep 23, 2012 at 9:02 AM
    #106
    Brandon H
    Newhall, CA
    07 DC Offroad
    I have always hand tightened them with a little bit extra on the ratchet. According to the FSM its 15 ft/lbs.
  7. Sep 23, 2012 at 11:00 AM
    #107
    samsung
    George
    Sugar Land, Texas
    15/ft lbs is not much. it's probably just hand tighten pretty hard?
  8. Sep 23, 2012 at 11:11 AM
    #108
    Brandon H
    Newhall, CA
    07 DC Offroad
    yeah thats usually what i do.
  9. Sep 23, 2012 at 2:58 PM
    #109
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I hand tighten, but I've been wrenching for over 40 years and have a pretty good feel for torque.
    I'd suggest using a torque wrench until you learn what 15ft/lbs feels like. Not tight enough and your plugs might vibrate out. Too tight and you'll strip the aluminum head, or break the threaded part of the plug off in the head when you remove them!
    Also, NEVER install plugs in a hot head. It might be easier to remove them if the engine is warm, but installing with the head hot will result in the head contracting and locking the new plugs in. Next time you remove them, the threads will come out with the plug.
    I always do my plug changes before the engine has been started that day.
  10. Sep 23, 2012 at 3:22 PM
    #110
    samsung
    George
    Sugar Land, Texas
    and what about anti sieze lube is it necessary?
  11. Sep 23, 2012 at 3:30 PM
    #111
    george3
    New Jersey
    Cold engine. Good advise. Thanks.
  12. Sep 23, 2012 at 3:49 PM
    #112
    Rich91710
    Rich
    Los Angeles
    08 Base
    I used it on aluminum heads.
    Very little... I'll put a pea-sized ball on a fingertip and that's enough for 2 or 3 plugs.
    It's all down in the grooves of the threads... nothing even flush with the top of the threads.
  13. Sep 29, 2012 at 9:42 PM
    #113
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
  14. Sep 29, 2012 at 9:47 PM
    #114
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    anti seize is anti seize. just dont go all the way to the bottom thread.
    installing mine tomorrow already got my plugs ready to go.
  15. Sep 30, 2012 at 3:07 PM
    #115
    Rich91710
    Rich
    Los Angeles
    08 Base
    One of the old coots in my neighborhood where I grew up used milk of magnesia for anti-seize on his header bolts.
  16. Oct 22, 2012 at 7:41 PM
    #116
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    There are different grades of anti sieze out there for specific applications, so anti sieze is not just anti sieze, but if you get it from an auto parts store, that will be the stuff you will need.
  17. Oct 22, 2012 at 7:49 PM
    #117
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    QFT
  18. Oct 22, 2012 at 8:08 PM
    #118
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Haven't changed mine yet, but when I do it will be Bosch or AC Delco plugs.
  19. Oct 22, 2012 at 8:42 PM
    #119
    Rich91710
    Rich
    Los Angeles
    08 Base
    Any particular reason you'd use those brands?
    You do know that your 2.7 requires Iridium.
  20. Oct 23, 2012 at 10:50 AM
    #120
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    NGK or Denso only for my Japanese brand vehicles........but I did go with autolites in the 05 Mazda Tribute v6 because it's has a Ford motor in it.
