what type of plugs did you put back in
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09 tacoma trd, Mar 1, 2009.
what type of plug did you put back in
  1. denso copper
    28.5%
  2. denso iridium
    25.2%
  3. ngk copper
    9.1%
  4. ngk iridium
    24.8%
  5. other
    12.4%
  1. Oct 23, 2012 at 7:45 PM
    #121
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ford motor in a Mazda or a Mazda motor in a Ford?
    My '91 Escort was all Mazda.
  2. Oct 24, 2012 at 4:08 AM
    #122
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Ford 2.5l v6 in a 2005 Mazda Tribute. Basically a Ford Escape with different headlights, grill, tails, trim, badges, etc :D I remember this crazy 72 Ford courier my dad had got somewhere real cheap from a friend back in 76 or 77. It had a Mitsubishi 4 cyl in it and someone had put a header with a bigger exhaust pipe. It sounded like a crop duster and blew sooty condensation on the garage wall. We used to crack up laughing driving this thing around. Ford has done some "interesting" blends over the years, not that the header and exhaust were factory on that thing tho.
  3. Oct 24, 2012 at 7:45 PM
    #123
    Rich91710
    Rich
    Los Angeles
    08 Base
    The spooky thing is that Jaguar quality actually improved when Ford took over!
  4. Oct 25, 2012 at 4:53 AM
    #124
    ManMan
    ManMan Well-Known Member
    If you've never checked them... How do you know there hasn't been an issue?
    Verifying part condition prior to installation saves a LOT of time downstream. Just ask the tech who installed a brand new faulty turbo in my Jetta.
    And yes, I worked as an auto mechanic for several years. Now I work with aircraft where NOT taking shortcuts is even more critical
  5. Oct 25, 2012 at 8:24 AM
    #125
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
  6. Oct 25, 2012 at 7:30 PM
    #126
    Rich91710
    Rich
    Los Angeles
    08 Base
    No reason to use Iridium in the 4.0
    If you do, there's no reason to check them at 30k.
    Iridium plugs will go 100k. That is the ONLY reason to use them. They don't perform better, they don't improve mileage... they simply last longer.
  7. Oct 25, 2012 at 7:54 PM
    #127
    Failure2Comply
    Virginia, USA
    I run them in my Avalon XLS and since they last longer, even better. I almost bought double Platinum instead.
  8. Nov 6, 2012 at 11:45 PM
    #128
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
  9. Nov 10, 2012 at 4:02 PM
    #129
    Failure2Comply
    Virginia, USA
    Well I got around to changing my plugs today (installed Denso Iridium) and I am glad that I did. On the passenger side were Denso, and on the driver side NGK. Most of the plug gaps were way off from wear but the overall color of the plugs looked good with the driver side with just a very slight oil film. I assume this is because of the PCV valve. Also the only reason I can figure the factory uses two different plugs is for the heat range, maybe a little hotter on the driver side to offset the oil vapor getting through? Does anyone know why for sure? I kept the old plugs and could check the models heat ranges to compare. And naturally everything got anti-seize, there was none on the plugs I pulled. :mad:
    Oh, and after changing the plugs on my last truck, a 1998 Ford Ranger XLT (2.5 L 4 cyl) with eight spark plugs, this truck was a pleasure to do.
  10. Nov 10, 2012 at 4:11 PM
    #130
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I think it's just to keep a relationship with 2 different vendors so they will always have a supplier in case there is a problem with one or the other.. I could be wrong - I was wrong once B 4 - but I doubt it.
  11. Nov 10, 2012 at 4:20 PM
    #131
    Rich91710
    Rich
    Los Angeles
    08 Base
    That's my feeling as well.
    Rather than try to run Denso in some models and NGK in another model, which are going to fluctuate with changes in sales trends, just run the "V" engines 50/50.
    My '03 Tundra 4.7 was the same way.
    It makes it a bit easier to provide more solid production requirements/shipping schedules to the plug suppliers, and should there be supply problems with a supplier, or if overstock results from a drop in 4-banger sales, the V6 production line can absorb some of the flux.
  12. Nov 10, 2012 at 4:28 PM
    #132
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    I like the way you think Rich. You and your brain.....
  13. Nov 10, 2012 at 4:34 PM
    #133
    george3
    New Jersey
    Since U agree with me I have the utmost respect for your opinion ;)
  14. Nov 10, 2012 at 4:35 PM
    #134
    Rich91710
    Rich
    Los Angeles
    08 Base
    Freakin' genetics. Brother has a PhD, sister is a housewife.
  15. Nov 25, 2012 at 12:34 AM
    #135
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    In my '11 4.0 I used the Bosch Platinum FR 7 NPP30X at 3/each from my local auto parts store...90 minutes to change.
    Howard
  16. Dec 23, 2012 at 4:50 AM
    #136
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Bosch never more! Put them in the Contour V6, 30K later developed a miss, pulled the plugs, no easy task on two of the rear cylinders, 3 out of the six were leaking between the insulator and metal.
    Jim
  17. Mar 25, 2013 at 5:40 AM
    #137
    gearcruncher
    Canadain bumper technician
    Gotta do plugs in my 4.0
    am I going with copper anti seize or grey graphite anti seize ?
    I use to use the copper for sparkies .
    I am suprised that nobody is doing kilo-ohm inspections on the plug wires .
    I know for a fact that Chrysler and Jeep dont last 25,000 miles
    Most people are noticing better fuel economy after the plug change due to the fact that its time to change their plugs .
  18. Mar 25, 2013 at 5:46 AM
    #138
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    just ordered 6 Denso Iridium plugs... guy on ebay has them for 48 bucks shipped, so for 100k miles, it beats the opposition of paying 20-30 bucks every 30k miles. who knows, maybe these iridium plugs will turn my 1GR into a 2JZ with a supercharger, give me SAS, regear me to 4:56's, give me a front locker, and an ATO hybrid bumper with a Warn M12 as well....
  19. Mar 25, 2013 at 7:01 PM
    #139
    Rich91710
    Rich
    Los Angeles
    08 Base
    We don't have plug wires.
    Most Toyotas have been coil-on-plug for over 10 years.
  20. Mar 26, 2013 at 4:49 AM
    #140
    gearcruncher
    Thanks Rich . I should have known this lol .
