what type of supercharger do you have
Discussion in 'Performance and Tuning' started by saltzbaseball, Oct 4, 2011.
  1. Oct 4, 2011 at 1:32 PM
    saltzbaseball
    saltzbaseball [OP] Member
    brandon
    01 sr5 trd
    I was just wanted to see some of superchargers fit the 4.0l v6 taco?
  2. Oct 4, 2011 at 1:36 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    are you asking about the 4.0L or your 3.4L?
  3. Oct 4, 2011 at 1:41 PM
    saltzbaseball
    brandon
    01 sr5 trd
    4.0 want to keep my 3.4 stock as far as a supercharger goes
  4. Oct 4, 2011 at 1:44 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    all they make right now are the TRD superchargers.
  5. Oct 4, 2011 at 1:45 PM
    saltzbaseball
    brandon
    01 sr5 trd
    URD is coming out with one right?
  6. Oct 4, 2011 at 1:49 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
  7. Oct 4, 2011 at 1:50 PM
    saltzbaseball
    brandon
    01 sr5 trd
    That's just what I heard from one of my friends.
  8. Oct 4, 2011 at 1:52 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    URD is already on their third generation MKII
    MKI - I put down 325 hp with this setup
    MKII - I put down 412 hp with this setup
    and Gadget is just releasing the MKIII kit I believe. Also a new kit for the new dual VVTI 4.0L in the new 4 runners
    TRD was actually second to market
    Justin
  9. Oct 4, 2011 at 1:52 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    :confused:
    There is already a URD kit for the 4.0L it's on their webpage
  10. Oct 4, 2011 at 1:52 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    I think the prototype is already out, and for the 2.7L you can up your HP and torque to above stock 4.0L levels.
  11. Oct 4, 2011 at 1:53 PM
    saltzbaseball
    brandon
    01 sr5 trd
    yea for 2005-2008
  12. Oct 4, 2011 at 1:53 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I'm currently running the URD MK1 stage 2 on my 07' 4.0L V6
  13. Oct 4, 2011 at 1:54 PM
    saltzbaseball
    brandon
    01 sr5 trd
  14. Oct 4, 2011 at 1:56 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    this is what I run on the Dcab
    The URD unit put down alot more power than this, but I wanted something more mild for this truck.
    Justin
  15. Oct 4, 2011 at 1:56 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Once i'm finish some final preps with the system to smooth everything out I'll get it custom tuned and a dyno.
  16. Oct 5, 2011 at 9:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Dude, if I read your posts then read them again, it still comes out the same. That you THINK there is a possible kit FROM URD for the 4.0 and that ONLY the TRD is out for the 4.0. The OP stated that he want to keep his 3.4 stock, and upgrade the 4.0.
    URD has had the MKI, the MKII, and now the MKIII out for the 4.0L Tacoma. The MKIII came out a few months ago. With certain select components upgraded, from the MKII. However, they are interchangeable. The MKI is a completely different setup from the newer versions.
    These kits have been out for years though. They are basically the only two S/C available for the 4.0L.
    Here is also another thing to note. At 8psi with headers, TRD cat back, on the TRD S/C, @ sea level, my friend made 315whp and 320 wtq. Not much compared to the MKIII at 8 psi which made 399 whp and 386 wtq. The URD system is a very efficient one.
  17. Oct 5, 2011 at 6:13 PM
    saltzbaseball
    brandon
    01 sr5 trd
    Thanks torspd u answered it.
  18. Oct 6, 2011 at 7:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any time, as best I can.
  19. Oct 7, 2011 at 11:29 AM
    KAWAIANIANI
    KAWAIANIANI Well-Known Member
    TRD BLACKED OUT
    Weather tech stone deflector, Craven speed stubby antennae,DTLT and rear O2 Sims, URD Y pipe, 40 series flowmaster w/ 3" piping. Urd maf calibrator, TRD supercharger, TRD CAI.
    Urd currently does not have a kit for the 09+ as the x-1 is not available due to ECU connector configuration. I know they are working on it if Toyota will release the connector housing.
  20. Oct 7, 2011 at 11:39 AM
    KAWAIANIANI
    TRD BLACKED OUT
