What type of UCA
Discussion in 'Suspension' started by c0b2a, Sep 19, 2011.
Which UCA for best quality / performance / value
Poll closed Oct 19, 2011.
  1. Camburg Performance 1.25″ Uniball Upper Arms $700
    3 vote(s)
    11.1%
  2. Camburg Performance Ball Joint Upper Arms $400
    3 vote(s)
    11.1%
  3. Total Chaos 1" Uniball Upper Arms $650
    9 vote(s)
    33.3%
  4. Light Racing Upper Control Arms Ball Joint $450
    12 vote(s)
    44.4%
  1. Sep 19, 2011 at 9:43 AM
    c0b2a
    c0b2a [OP] Well-Known Member
    Planning for my upcoming lift, getting OME 886 full kit. Just wondering what best quality and value for UCA. I am not opposed to spending the money, I just want to figure out which of these is the best for the money.
  2. Sep 19, 2011 at 10:31 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I have the full OME lift kit , but with the 885x springs , I went with LR UCA's because for my winter driving conditions , I wanted a sealed balljoint .
  3. Sep 19, 2011 at 10:40 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    If you wheel hard and need as much wheel travel as possible, go with the uniball option. Otherwise you'll be well-served by the Light Racing ball joint UCAs. Practically no maintenance with those things compared to uniballs.
  4. Sep 19, 2011 at 10:41 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    LR FTW
  5. Sep 19, 2011 at 2:09 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
  6. Sep 19, 2011 at 5:35 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Uniballs, pick a color. The extra travel is worth it, not to mention them being a much stronger joint compared to ball joints.
  7. Sep 19, 2011 at 5:36 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Camburg or TC.
    I have the Camburg ball joint uca's with geasable Moog ball joints. They've handled everything i've thrown at them so far and they allowed my truck to be aligned correctly.
    Go uni if you have the money tho.
  8. Sep 19, 2011 at 5:48 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    The 1.25" uniball UCAs provide more travel than the 1.0" uniball or ball joint UCAs.
    UCAs by geometry see far less load than LCAs. Unless the arm physically hit a rock, strength is not an issue with any of the UCAs. The ball joint boot, though, can tear easily. I tore the boot in one of my swaybar links while installing the lift; never figured out how it happened.
    If you go with uniball, be sure the uniball is stainless steel. It'll last longer in corrosive environments.
  9. Sep 19, 2011 at 5:50 PM
    jandrews
    Chrome steel UBs work fine in non-rust-belt environments.
    As far as larger uniballs offering more droop, I'm not convinced on that. I think it's very very configuration sensitive.
  10. Sep 19, 2011 at 5:53 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    x2. I hear the 1.25" Camburgs hit the coils at full droop.
  11. Sep 19, 2011 at 5:56 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    No complaints with my TC uca's
  12. Sep 19, 2011 at 5:57 PM
    jandrews
    Yeah. Assuming everything else is equal and they have the clearance to droop fully, I can see how the math works. I'm not convinced that ever takes place in the real world; or, if it does, that it does for everyone to an equal extent.
  13. Sep 19, 2011 at 6:04 PM
    KenLyns
    Belly of the Beast
    My 1.25" All-Pro UCAs don't hit the coils (Icon Extended Travel) at full droop. I can also see the bearing race getting very close to the conical spacer neck. I believe a 1.0" uniball would bind in my situation.
  14. Sep 19, 2011 at 6:06 PM
    jandrews
    What's actually binding to stop your droop? Because I have extended travel Icons as well, and my 1" TC UCAs do not bind at full droop. The shock bottoms out first.
  15. Sep 19, 2011 at 7:07 PM
    KenLyns
    Belly of the Beast
    The shock is bottoming out in my case, too. You may be right. Or there may be more travel available in my UCAs (good for a 1/4" trim spacer perhaps).
  16. Sep 19, 2011 at 7:20 PM
    jandrews
    Quite possible.
  17. Sep 19, 2011 at 7:55 PM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    I made the same decision at OZ , uniballs have too much exposure to run on salted roads
  18. Sep 20, 2011 at 6:44 AM
    mjp2
    NJ
    On our trucks the additional wheel travel comes on compression, not droop, and requires that the bumpstop be modified to take full advantage of the 1.25" uniball. Almost a necessity when running jounce shocks, but it'll never be used with the stock bumps.
  19. Sep 20, 2011 at 12:36 PM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    I put LR UCAs on my Taco. Like others, I needed a "protected" ball joint, as they salt the crap out of our roads during winter in St. Louis.
  20. Sep 25, 2011 at 7:41 AM
    Thesilversurfer
    Thesilversurfer Member
    Rich
    Calgary, Alberta, Canada
    2011 TRD Long Box
    Toytec ultimate lift kit UCA's Pro Comp Rims Dakar rear springs Centre bearing drop Bilstein 5100's BF Goodrich TA's Leer topper TRD Panel filter
    I have Light Racing for the sealed ball joint in poor weather. No complaints
