What U-bolts for a 2003 2wd 5 lug extracab?
Discussion in '5 Lug' started by gobyfish04, Jul 29, 2024.
  1. Jul 29, 2024 at 5:22 PM
    gobyfish04
    gobyfish04 [OP] New Member
    I've been searching high and low and can't come to a definitive answer. I have 2003 4-cyl 2.4L 5-Lug Extracab. Doing all the standard lift options (Fabtech spindles. fabtech shocks, Fabtech AAL, Lesjofors springs, spacers, shackles, etc...). I can't for the life of me figure out which U-bolts I need. The stock bolts are to short to accommodate the AAL so I need longer ones. According to the pics I have. I need 2.75" wide bolts?
    https://photos.fife.usercontent.goo...H6hzL6qieiTGkjvF=w442-h957-s-no-gm?authuser=0
    https://photos.fife.usercontent.goo...IWNWYN9cdpU3MMvM=w442-h957-s-no-gm?authuser=0
    https://photos.fife.usercontent.goo...cBtyEIzeB9Hwc1k=w1276-h957-s-no-gm?authuser=0
    Sorry in advance for the potato pictures.
  2. Jul 29, 2024 at 6:41 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Pretty sure the the 7.5 axle you need 2 5/8 wide 5/8 diameter what ever length you need (just cut them if they are long)
    it’s easy to verify. Just measure the distance from inside of the bolt to inside of bolt closes to the U. Or just measure the axles width.
