What UCA did you go to after SPC and why ??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fohu, Apr 18, 2024.
  1. Apr 18, 2024 at 12:31 PM
    Fohu
    Fohu [OP] Well-Known Member
    Glade park Colorado
    2019 trd or access cab
    My spc ucas ball joint went out so I replaced that. Simple enough process and when I went back to get an alignment. They showed me that my bushing on the passenger side have gone out as well.
    After looking for new bushing it looks like it's pretty hard to find new bushing and seems as tho spc might be going under ??!?
    So rather than spend even more money on a dying brand.and just delaying the process of switching arms What would you recommend for upper control arms.
    So far I'm leaning towards total chaos
    https://sdhqoffroad.com/products/05-current-toyota-tacoma-prerunner-4wd-upper-control-arms
    Also considering the icon Delta joint
    https://www.iconvehicledynamics.com...-accessories-05-up-tacoma-tubular-uca-dj-kit/
    What are y'all's recommendations. On something that has and will stand the rest of time.
    My current setup is extended travel ads shocks with spc ucas
    And 265/75/ r16 ko2s
    Thanks in advance.
    71tattooguy likes this.
  2. Apr 18, 2024 at 12:44 PM
    pp2small
    pp2small Well-Known Member
    Brian
    Socal
    2022 TRD Offroad
    I have the icon delta joint. Just like with any UCA that uses poly bushings on the eyelet part of the UCA make sure you know how to grease it properly. Have to loosen the UCA bolt before pumping grease into the bushings. If you dont the bushing will swell up and cause the UCA to shake on the highway. this is probably common sense but oops ask me how i know. Other than that the icon UCA are fine i didnt have any issues running that with 33s but once i put the 35s on i wished I ironically wished i went with the SPCs as they allow more alignment adjustment. If you arent picky about your alignment then the icons will work perfectly for you
    Fohu[OP] likes this.
  3. Apr 18, 2024 at 12:47 PM
    Fohu
    Glade park Colorado
    @pp2small thanks. I'm not picky about alignment. And probably won't ever go up in tire size. How many miles have you got on your icons?
  4. Apr 18, 2024 at 12:49 PM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    I went with OME UCAs, they seemed to be less finicky than some of the other options and the price point was there. I got the additional amount of caster needed and have had zero issues with them in almost two years of having them.
  5. Apr 18, 2024 at 12:51 PM
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    I'm running JBA High Caster UCA.
    Well made in the U.S.A., and they have zerk fittings to lube without loosing any bolts.
    Alignment was spot on!
    https://jbaoffroad.com/jba-a-arms.html
    Cheers
  6. Apr 18, 2024 at 12:51 PM
    pp2small
    Brian
    Socal
    2022 TRD Offroad
    thats perfect. given your 2 choices i would lean towards the icon. Mainly because the delta joint is much less work to maintain and its pretty strong IMO, i think your spindle will bend before the delta joint fails. Plus you can find them for pretty cheap when they go on sale.
    I had about 15k miles on them before i had to replace the UCA pivot eyelet bushings. Put about 1k miles since then with no issues. My steering shake went away after putting in the new bushings
  7. Apr 18, 2024 at 12:53 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    4xThad and Fohu[OP] like this.
  8. Apr 18, 2024 at 1:03 PM
    pp2small
    Brian
    Socal
    2022 TRD Offroad
    the bushings are pretty cool where they are designed you dont have to loosen the bolt. from a maintenance perspective this is a huge win plus the pricing on these UCA are great.
    BUT please please do not use petroleum based lubricant on rubber bushings. Use a silicone based lube. Not sure why JBA has a callout of MOLY EP LITHIUM GREASE.
    Toy_Runner and atc250r like this.
  9. Apr 18, 2024 at 1:17 PM
    Fohu
    Glade park Colorado
    Did you go with the boxes or tubular
    And heim joint or uniball?
    71tattooguy[QUOTED] likes this.
  10. Apr 18, 2024 at 1:23 PM
    Fohu
    Glade park Colorado
  11. Apr 18, 2024 at 1:49 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    4xThad likes this.
  12. Apr 18, 2024 at 2:10 PM
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    Fohu[OP] and 71tattooguy[QUOTED] like this.
  13. Apr 18, 2024 at 2:11 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Hell yeah bro. My SPC’s lasted a while as well but was done with them. Definitely stoked I moved on
    4xThad[QUOTED] likes this.
  14. Apr 18, 2024 at 2:11 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
  15. Apr 18, 2024 at 2:12 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Definitely bro I’m with you
  16. Apr 18, 2024 at 2:25 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    For your use case I would probably stick with the stock UCA. I don’t see any benefit of aftermarket UCA unless I cannot get the truck into alignment due to a lift, my tire is rubbing, or I’m doing something radical to the suspension that requires a different UCA.
    Where did you hear SPC is going out of business?
    How did you determine your balljoint was toast? What inspection method did you use?
    There is some good info about UCAs in these videos.
    https://www.youtube.com/watch?v=huMztKaHsUE
    https://www.youtube.com/watch?v=InQnp42pfts
  17. Apr 18, 2024 at 2:37 PM
    Fohu
    Glade park Colorado
    @gudujarlson complete free play in the ball joint. Was my method of inspection lol. And I have extended travel shocks I don't think stock is my best option.
  18. Apr 18, 2024 at 2:38 PM
    JJshib
    JJshib Well-Known Member
    14 Tacoma DC Off Road
    TacoZmtn and Fohu[OP] like this.
  19. Apr 18, 2024 at 2:43 PM
    r3k
    r3k Well-Known Member
    i have jba std high caster, 30k miles, no problem. greased every 5k miles. have 4.8/5.2 caster. been to jishua tree, death valley, mount rainier, utah mighty 5, moab doing trails, everglades, shenandoah, new river gorge etc, treated me well, no problems whatsoever.
  20. Apr 18, 2024 at 3:36 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    30k is really good and what I expect when I spend money for aftermarket UCAs. I have SPCs and just replaced bushings and ball joints with about 20k miles. The parts are not cheap either but upgraded to the X-axis bushings so I will see how long these last. SPC definitly has the best versatility for getting a good allignment with their adjustability. Ran Icons several years ago with 33's and just barely got enough clearance. Talked to Icon recently and they said they have updated theirs but didnt get that far in discussing what. The old Icons I had were adjusted by loosening bolts on the arms near the bushings. No harder than disconnecting the ball joint on the SPC and changing the setting on the plate. That said SPC had quality issues a couple of years ago (covid?) but my new bushings and ball joints seem fine and they answer the phone when you call. Have not heard anything about them going under but we are all in the most disfunctional economy I have ever seen. Everything I buy is heavily based on robustness, longevity and future avaliability. What size tires are you running and type of suspension?
