What UCA did you go to after SPC and why ??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fohu, Apr 18, 2024.
  1. Apr 18, 2024 at 3:43 PM
    r3k
    r3k Well-Known Member
    havent repalced any parts as nothing looks damage or broken and replacement parts are cheap, https://jbaoffroad.com/replacement-parts.html
    also got a good alignment, 0.03/0.05 camber, 4.8/5.2 caster and 0.02/0.03 toe.
    am really happy with my jba that's why am hesitant to get the ironman foam cell stage 2 with the UCA for suspension upgrade, their UCA might suck and i cant get the same alignment i have with the jba.
    i asked around if the ironman front coilover/struts would not rub on the uca at full dropp but havent gotten any reply from someone runnign the set up.
    i currently have falkens 285/70/17 on 17x9 -12 wheels with eibach stage 1 suspension and icon aal. no rubbing at all and i've wheeled it in moab although only on easy and moderate trails.
  2. Apr 18, 2024 at 3:52 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    I would wait for long term results on the foam cell shocks.
  3. Apr 18, 2024 at 4:35 PM
    r3k
    my sister lives in australia, she has foam cell since 2012 on her landcruiser and jimmy. no problems.
  4. Apr 18, 2024 at 5:59 PM
    Fohu
    Fohu [OP] Well-Known Member
    Glade park Colorado
    2019 trd or access cab
    Ended up just going with the tubular dirt kings. Good price and easy to replace parts at home
    71tattooguy likes this.
  5. Apr 18, 2024 at 6:32 PM
    Fohu
    Glade park Colorado
    Thanks for your advice and thoughts.
  6. Apr 18, 2024 at 6:37 PM
    TacoTuesday1
    FL
    I have JDfab.
    -it was better priced than anyone else
    -beefy
    -support company that is local and does cool Tacoma stuff nobody else does
    -match other parts I have from them like Pivots that address known Tacoma issues that nobody else makes
    -matching geometry
    -quiet durable bushings and ball joint
  7. Apr 18, 2024 at 7:07 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Play in what direction? I ask because the ball joint has play in the vertical direction by design. The inspection procedure described by SPC says to only check radial play. This has confused some people in the past.
    https://www.spcalignment.com/partFAQ/25003_FAQ.pdf
  8. Apr 18, 2024 at 7:43 PM
    Dryvah
    Dryvah Well-Known Member
    MA
    2019 Tacoma TRD
    Another happy JBA user here. For anyone with their old style ball joint the updated version is way better. No more grease everywhere. I replaced mine while I had them apart doing my spindle gussets. They weren't worn or anything, I just wanted the upgraded ones. I ordered them on a Monday and had them Wednesday. Awesome company!
    Inyo_man likes this.
  9. Apr 18, 2024 at 7:45 PM
    r3k
    when did they came out with the new one?
  10. Apr 18, 2024 at 8:05 PM
    Dryvah
    MA
    2019 Tacoma TRD
    Not exactly sure. A couple years ago maybe.
  11. Apr 18, 2024 at 9:45 PM
    Southwest Tacoma
    Southwest Tacoma Well-Known Member
    Southwest
    2020 Super White SR DCSB
    I bought the Freedom Off Road UCA's. I'll report back after I've had a chance to install.
  12. Apr 18, 2024 at 11:03 PM
    Foggygoogles
    Foggygoogles Active Member
    PNW
    Army Green 2022 TRD Sport 4WD MT
    Just replaced the RC that were on the truck. Went with Dirt Kings. Waaay better but I guess that's not saying much.
  13. Apr 18, 2024 at 11:13 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    JD Fab. All you need to do is hold one in your hands and the superiority is clear. OEM rubber bushings and beef tits EMF joints. Basically bomb proof as long as you squirt a little grease in them.
    My happiest day with the SPCs was when I returned them.
  14. Apr 19, 2024 at 9:35 AM
    JJshib
    JJshib Well-Known Member
    14 Tacoma DC Off Road
    I like the look of those JD Fab UCA's... looks very similar to the sealed Dobinson's ones, just cheaper.
  15. Apr 19, 2024 at 9:44 AM
    #35
    216to404
    216to404 Well-Known Member
    2006 RC prerunner
    I’ve read through the JD fab thread. Seems like there been several reports of blown EMF joints, sheared pins, and just “broken” stuff. Also it sounds like JD fab has substituted the EMF for some other kind of joint and are sending them out to folks to prevent more issues …
  16. Apr 20, 2024 at 8:17 AM
    #36
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    They callout for Moly because the bushings are not rubber.
    JBA bushings are synthetic elastomer.
    JBA stats. from their website:
    WHAT INCLUDED
    1 Right UCA
    1 Left UCA
    2 JBA Max 90 ball joints
    8 synthetic elastomer a-arm bushings
    1 Bushing washer kit
    4 steel bushing sleeves
    Installation Instructions
    2 JBA sticker 6 x 1
    Cheers
  17. Apr 20, 2024 at 9:26 AM
    #37
    pp2small
    pp2small Well-Known Member
    Brian
    Socal
    2022 TRD Offroad
    I refer to elastomer based bushings as "rubber" for lack of better term. It is my all encompassing term for these types of bushings. Just like "metal" bushings is used as a generalized term. There is of course bronze bushings, steel bushings, aluminum bushings, etc. which all fall under the metal bushing umbrella. Depending on modes of contact, such as sliding vs spinning, "metal" bushings will require different types a grease to get the best efficiency and longevity out of the bushings. This generally holds true for "rubber" or elastomer bushings but these type of bushings only see a rotational movement along its longitudinal axis. Hence, making it easier to call out the grease needed.
    Natural rubber, silicone, nylon, butyl, nitrile, and urethane are examples of an elastomer. JBA calls out this on their website:
    What is synthetic elastomer?
    Synthetic Elastomer is a long-chained polymer with many urethane constituents.
    Since JBA does not have a material call out the exact synthetic elastomer, I am going to assume it is a urethane based elastomer based on their description. Considering polyurethane and urethane is made up of the same chemical compound (poly has chains of urethane), the most ideal grease to use on Poly bushings is a SILICONE based grease. If I can be so bold, a silicone based grease is the favorable grease for all types of elastomers, or as I like to use the general term "rubber".
    Really, these bushings are a wear item that needs to be replaced over the life of the UCA. All this "lithium vs silicone" debate is theory from what I learned in school but I've also seen it in practical applications both from my line of work and car hobby. We can probably agree using the correct grease is probably not as important as routine greasing. However, if you are going to go through the effort to greasing routinely MIGHT as well use the correct grease.
  18. Apr 20, 2024 at 9:33 AM
    #38
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Anyone have any insights how well the uniball type hold up in the salt belt? I'm not looking to change mine any time soon, but salt and brine spray are used in my area, and the brine spray seems to be able to find every small nook and cranny it can and cause very fast corrosion compared to salt slush.
  19. Apr 20, 2024 at 1:14 PM
    #39
    Inyo_man
    U.S.A.
    Thanks for the great brake-down, pp2small.
    Cheers
    pp2small likes this.
  20. Apr 20, 2024 at 7:23 PM
    #40
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    i have jbas on one tacoma and icons on the other. neither had had any issues. the jba bushings can be greased without loosening uca bolt. ive thought about cutting relief slits in the icon bushings to allow this too
