What UCAs is Everyone Running?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ThePanda, Apr 24, 2020.
  1. Apr 24, 2020 at 9:07 PM
    ThePanda
    ThePanda [OP] Well-Known Member
    Kaelan
    Colorado
    6-Speed Manual 2010 Magnetic Grey Tacoma SR5
    Procomp 6" Lift ARB Front Bumper Brute Force Fab's High Clearance Swing Arm Rear Bumper Relentless Fabs Bed Rack Gen 2.5 Face-Lifted Exterior and Interior (mostly) -Fleabay Headlights -Heritage Grille -Scooped Hood Alpha Rex 3rd Gen Pro-Series Taillights Joying 10.5" Android head unit URD Short Throw Shifter Advanced Fiberglass Front and 3rd Gen Rear Fenders 3rd Gen Tailgate RSG Metal-Works Sliders ARB Simpson III RTT Panels Lined w/ Closed Cell Foam (In Progess...) QTP Reverse Screamer muffler TRD CAI SPC UCAs S.S. Brake lines front and rear S.O.S. Performance rear Disk Brake conversion w/PowerStop performance calipers, rotors and pads KMC Tank 17" beadlocks wrapped in 35x12.5" KO2s Long Range Offroad Extended Range Fuel Tank ATO Dual Battery tray w/ 34D Optima Yellow tops and Blue Sea ML-ACR ClutchMasters Hydraulic Throwout Bearing
    I have a 2010 with a Pro-Comp 6" that I want to turn into a more offroad worthy truck. already have plans for coilovers and will soon be getting advise for the rear, but this thread is all about the UCAs up front. I've seen so many brands with their own arms and they all say they're the best. What's the general consensus with y'all? Which company deserves their shite on your truck?
    Biscuits likes this.
  2. Apr 24, 2020 at 9:25 PM
    ThePanda
    Kaelan
    Colorado
    Main reason I want to go with aftermarket UCA's is that I'm pretty much going to be upgrading the rest of the front suspension so it seems to reason to do a complete job. Mainly I'll be running this truck as a daily and on OHV trails weekly. The truck is the project so doing maintenance often doesn't bother me one bit, weekly is a bit of a stretch though. Don't mind squeaks (It's a 10 year old truck.) One thing I do have a bad habit with is going a bit too fast down the dirt road leading up to the trail...
    Biscuits and Island Cruiser like this.
  3. Apr 24, 2020 at 11:57 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    JBA upper control arms would do you well. 3 greasable zerks with poly bushings per arm. Uses a chevy 1500 balljoint available from napa bolt in. I could do one side in 10 mins on a lift, provides 2+ caster and better travel up and down. Worthy every penny I love mine.
    Tfs94gt, Biscuits and whatstcp like this.
  4. Apr 25, 2020 at 4:05 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Years ago I purchased Camburg ball joint type upper A arms. These were the earlier Camburg arms that used oem Toyota ball joints. I noticed recently Camburg now uses an aftermarket ball joint.
    No regrets with what I installed. Those JBA setups do seem nice. I have no details of where they are made, but the JBA or newer Camburgs would be my first choices in a ball joint upper aftermarket A arm.
  5. Apr 25, 2020 at 4:07 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Total Chaos.
    I like their lowers but holy $$$ :eek:
    JKU3000, whatstcp and lynyrd3 like this.
  6. Apr 25, 2020 at 4:31 AM
    lynyrd3
    Bill
    East Central Upstate NY
    I have Total Chaos uppers . Just keep them clean and lubed :thumbsup:
    JKU3000 likes this.
  7. Apr 25, 2020 at 5:03 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
  8. Apr 25, 2020 at 5:26 AM
    James710
    James710 Well-Known Member
    James
    Springfield, MA
    '14 Sport AC BRM
    Does JBA provide the same level of adjustability as say SPC?
    I’m in the market for some myself and my mechanic actually recommended pro comp- apparently the designer of these was a former TRD developer and they are supposed to be good as well- but those are Uniball.
  9. Apr 25, 2020 at 5:28 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    This.
    They do make noise, don't they?
    El Duderino likes this.
  10. Apr 25, 2020 at 11:14 AM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Jba is non adjustable. If you want adjustable spc is your bet.
    Kolter45 and James710[QUOTED] like this.
  11. Apr 25, 2020 at 11:16 AM
    2DaMtns
    2DaMtns Well-Known Member
    2011 TRD Sport DCLB in MGM
    Lift, tires, stuff
    I have Total Chaos on mine. They've only been on since September so I don't have a lot of life on them yet. No issues thus far.
  12. Apr 26, 2020 at 1:57 PM
    ThePanda
    Kaelan
    Colorado
    So what would be the benefits of some Total Chaos Arms or SPC since we already got JBAs up?
  13. Apr 26, 2020 at 2:01 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I am running the best ones on the market. OEM.
    Island Cruiser likes this.
  14. Apr 26, 2020 at 3:06 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    SPC, all i need is tires now
  15. Apr 26, 2020 at 4:00 PM
    ThePanda
    Kaelan
    Colorado
    Any other advantages aside from adjustability?
    Kolter45[QUOTED] likes this.
  16. Apr 26, 2020 at 4:06 PM
    Kolter45
    Denver, CO
    This is it! but its the most important perk when choosing ucas imo
    Great exchange program for older spc ucas & customer service seems to be great! I'm biased though being from Colorado.
    old55guy likes this.
  17. Apr 26, 2020 at 4:08 PM
    ThePanda
    Kaelan
    Colorado
    anyone have any opinions on DirtKings?
  18. Apr 26, 2020 at 10:30 PM
    xsvt
    xsvt Active Member
    I have the Dirk King ball joint lowers .. love them. Wish I had their ball joint uppers.
  19. Apr 26, 2020 at 10:33 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    My JBA’s have a lot of adjustment for caster. It’s a standard GM ball joint. Was able to get 3.5* of caster with 0 camber and 0 toe. Pretty adjustable if you ask me.
    Kolter45 likes this.
  20. Apr 27, 2020 at 12:19 AM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    the guy i quoted was referring to the actually balljoint placements not how much you can move the cams after install. Spc have a balljoint nut on top you can loosen and move in a channel on the UCAS frame. I got 3.6 out of mine, if i free up my cams i can probably get 4 degrees. My buddy runs 4.8 on his spcs with his 4runner on 35’s
