What upgrades are needed to handle a Twincharger?
Discussion in 'Performance and Tuning' started by AHamsterPig, Sep 10, 2013.
  1. Sep 11, 2013 at 8:19 PM
    AHamsterPig
    AHamsterPig [OP] Member
    Tyler
    Midland, Tx
    '13 Regular Cab 2.7 4 Cylinder
    Hey guys! Sorry for the late reply, didn't expect so much interest, but happy anyway!
    My plan was to upgrade the engine after everything else, (I.E. Lift, Wheels, Tires, new suspension, etc.). My reasoning behind grabbing the added Turbo is to, like I said, also have the advantage of the Turbo's smaller gas consumption when the Super turns off. Also I just like spending money and seeing things go fast and have lots and lots of horses.. Guilty pleasure of mine :D
    So thanks for the interest guys, hope to hear back from y'all and please feel free to ask more questions :p
  2. Sep 11, 2013 at 8:34 PM
    TRDFORME
    TRDFORME Well-Known Member
    98 trd 4x4 limited
    I believe it's called compound charged.
  3. Sep 11, 2013 at 9:25 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    correct. or compound boost. Twin charged usually implies there are two superchargers.
    Anyways, it's not a very common practice and for good reason...expensive and complicated. Just doesnt make sense when URD already has a kit that does great with mpg and has the ability to push the power well beyond what the truck can handle.
    Remember... the 4cyl could potentially use the C38-91 Rotrex with a built engine:cool:
  4. Sep 11, 2013 at 10:05 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Turn off? What, do you think supers work like the one of of mad max's ford? And why not just superturbo it?
  5. Sep 12, 2013 at 5:14 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    That set up was common on Detroit diesels for more punch a turbo before the super charger been used for years, it works. One thing to remember in order to make HP it has to have fuel the forced induction helps by reducing the effort to get air into the engine but it takes BTU's to produce power.
  6. Sep 12, 2013 at 5:39 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    With the older Detroits they needed the blower just to run. They were 2 stroke and the blower was used to push air into the cylinders. Without the blower they could not even start. The Silver series then had a turbo on top of that for power.
    G
  7. Sep 12, 2013 at 7:15 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    No shit, I want to YouTube this. Any suggestions to search?
  8. Sep 12, 2013 at 9:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Supercharged Detroit Diesel.
    That would be from my 1GR turbo kit. :D I was going to post up the 2TR graphs, but Gadget beat me to it.
    OP, all around easiest to do a bolt on kit. The URD kit. Look at how much higher the tq is, with the blower, at the beginning of the map. Roughly 75 ft-lbs higher. Then continues to increase. Easiest most complete power adder for the 2TR.
  9. Sep 12, 2013 at 10:03 AM
    wildcats
    wildcats Well-Known Member
    13 DCSB Sport
    A turbo and supercharger won't help you save fuel. The combination will allow you use burn the most fuel possible. Early boost of the supercharger and higher top end of a turbo. The problem is it's very complicated and doesn't have many advantages. A properly sized turbo or supercharger will do almost as well.
  10. Sep 12, 2013 at 7:26 PM
    AHamsterPig
    Tyler
    Midland, Tx
    It actually gives about the same amount or even better when compared to a SuperCharger since it stops the supercharger from pressurizing when needed so the TwinCharger system actually has alot of advantages. The supercharger provides near-instant manifold pressure (eliminating turbo lag, from the turbocharger when it is not up to its operating speed). Once the turbocharger has reached operating speed, the supercharger can either continue compounding the pressurized air to the turbocharger inlet , or it can be bypassed and/or mechanically decoupled from the drivetrain via an electromagnetic clutch and bypass valve (increasing efficiency of the induction system).
  11. Sep 12, 2013 at 7:53 PM
    wildcats
    13 DCSB Sport
    How many situations are there where you need the immediate response of a belt driven blower but it can't provide the horsepower you need. A properly sized roots supercharger or turbo can provide all the power 99.9% of people would want and still providing adequate low rpm power. And I still don't see anyway a twin charger could possibly provide better fuel economy than a supercharger. And furthermore if your concerned about fuel economy both a supercharger and turbo are going to increase your fuel consumption, and you can't argue that.
  12. Sep 12, 2013 at 8:40 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Fuel consumption is all dependent on tune. Twincharging has been around for decades. Urd's working on a setup for big diesels to help fuel econ. This idea isn new and provides the gains he wants. He wants to go big, for a small liter vehicle this will achieve that with maximum efficiency.
  13. Sep 13, 2013 at 6:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Clearly the OP wants to do it. Sooooooo......the next question is, any idea of clearance issues of between the where the Rotrex mounts and where the turbo is supposed relatively mount?
  14. Sep 13, 2013 at 7:17 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    The urd charger mounts same side as header. And its on top, would be a tight fit
  15. Sep 13, 2013 at 7:22 AM
    #35
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I love the old Detroits! If they weren't leaking, they weren't running right and God help you if you were behind one at a light, you were going to be in a cloud of smoke for as long as you were behind one. And, of course, what a sound those engines made :drool:
  16. Sep 13, 2013 at 8:32 AM
    #36
    wildcats
    13 DCSB Sport
    Ok even if he wants to do it and i look past my problems with the idea, you definetly wouldn't want to use a centrifugal supercharger, they spool up slower than a turbo.
  17. Sep 13, 2013 at 10:36 AM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Does anyone make a roots/twin screw for the 2TR? o_O
    I don't think there is one. Doesn't mean one can't fit with some custom parts though.
    If there isn't, and I really don't think there is, then the bolt on S/C is the easier choice than a custom s/c and custom turbo kit.
  18. Sep 13, 2013 at 10:58 AM
    #38
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Ausi's make a bolt on turbo kit for the 2tr. Supposed to run 250-300 bhp on stock injectors, pump, and a flashed ecu. Kits 3k. Not much info in it though. Would like to know if it works with the us spec 2tr.
  19. Sep 13, 2013 at 11:22 AM
    #39
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Got my vote then. Lol
  20. Sep 13, 2013 at 11:28 AM
    #40
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Lol
