What upper control arms for a 3 inch lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tanner.b16, Jun 20, 2024.
  1. Jun 23, 2024 at 12:29 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Absolutely! Need? No. Looks like OP is running 32s on his 2nd gen, so tire clearance shouldn't be a problem. With that lift, you're likely approaching the limits of the stock balljoints without binding them. Binding is where you start causing excessive wear/break things. As long as the align shop can get your numbers within spec (which appears to be the case), I wouldn't sweat it.
    I bought UCAs for my truck but haven't installed them yet and am not worried about it...more of a want (impulse buy) than a need. For reference, I'm running 33s and about 2 1/2" lift on stock UCAs without problems. YMMV.
    Tanner.b16[OP] likes this.
  2. Jun 24, 2024 at 6:36 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    I have SPC uca's.
    some people are reporting problems with them, but mine have been fine.
    I went with SPC's, because i stuffed 33in tires with 3" lift rancho coilovers.
    I didn't cut the cab mount and i only get rubbing if at full steering lock while running over a curb.
