What wheels would I order... See link attached
Discussion in 'Wheels & Tires' started by NiceTaco, Sep 30, 2012.
  1. Sep 30, 2012 at 4:43 PM
    NiceTaco
    NiceTaco [OP] Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    Can someone tell me what 18x9's I would need to order from the page below. Hopefully this link works.. I plan on starting with billies at 1.75 in the front. Looking for what backspacing I should order I see a few options for our trucks.
    I would like tem to stick out a bit but not crazy.
    2012 dbcb TRD sport
    http://www.mhtwheels.com/cms_pdf/D536-537-538 Maverick 1pc.pdf
  2. Sep 30, 2012 at 6:03 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    What size tires do you want to run?
  3. Sep 30, 2012 at 6:08 PM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    I would like to run 275 65 18's there seems to more options in that size but I don't want to trim Anyhing so I may just go with 265 65 18's.... Untill I decide to go higher but like you I don't want to have to buy new UCA's.
  4. Sep 30, 2012 at 6:13 PM
    TexasTacoma37
    You would want to the ones with the +1 offset
  5. Sep 30, 2012 at 6:30 PM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    So the +1 with the 5.0 BS... Whoever responds from fuels Facebook page said the ones at the bottom the -12 OS and the 4.5 BS..
    This is why people need to ask these questions on here. What would the difference be as far as how they fit/stick out?
    I like your look when you had the 265 and I like your 275's too....
  6. Sep 30, 2012 at 6:40 PM
    TexasTacoma37
    Whoa I didn't even see those. Amazing that this page isn't sorted by lug pattern :facepalm:.
    Those would work also. The -12 with stick out 0.5" more than the +1. Either will work.
  7. Sep 30, 2012 at 6:53 PM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    Ya I don't understand why it isn't sorted properly... So looks like the ones at the bottom are my best bet if they will stick out like yours I am happy..
    Thanks KPT... As always helping me out man!
  8. Sep 30, 2012 at 6:54 PM
    TexasTacoma37
    Youre welcome. They will stick out an inch more than mine, my wheels are +10
  9. Oct 1, 2012 at 4:55 AM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    Hmmm.... An inch, Think that's to much? I don't want them to stick out to far.
    Will I have good clearance if the uca's?
  10. Oct 1, 2012 at 6:23 AM
    TexasTacoma37
    Yes, either wheel will be fine for UCA clearance.
