what/where is this sound coming from?
Discussion in '1st Gen. Tacomas (1995-2004)' started by morningwood, Oct 5, 2010.
  1. Oct 5, 2010 at 8:09 PM
    morningwood
    morningwood [OP] Active Member
    virginia beach
    99 4x4
    ome 882's and dakars and bilstien's. treadwright 285's
    i recently got a tacoma and since ive had it, it has has a continuous squeal/ whistle noise coming from what i believe is the front driver side tire area. the noise starts when the trucks starts moving and will stop when the vehicle stops moving and when you make a left turn and the weight is removed from that wheel. what could this be? i took it to the shop today and they said it was from the front left rotor being warped and that i needed front rotors and pads. so i did some searching around on the web and couldnt find anything relating that noise to a rotor? and my brakes feel fine. just dont want to spend on new brakes if thats not goin to fix the noise. any suggestions/advice is appreciated. thanks
  2. Oct 5, 2010 at 8:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Could be a rock stuck in the rotor, or the noise maker in the brake pads, indicating you need them replaced.
  3. Oct 5, 2010 at 8:15 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    dont skimp on brakes.....most important function of any vehicle man
  4. Oct 5, 2010 at 9:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    ^^^ x2 Loosen the brake shield on that wheel and see if anything falls out.
    How long has it been doing it? Had a similar experience after wheelin one time. Was a rock wedged between the shield and the rotor.
