What wiring kit
Discussion in 'Audio & Video' started by Blaise22, Jun 12, 2009.
  1. Jun 12, 2009 at 1:52 PM
    Blaise22
    Blaise22 [OP] Well-Known Member
    Blaise
    California
    09 prerunner trd offroad
    Camburg 4.0 race spindles, coilovers, 285/75/16 Yokohama Geolanders mounted on 16" KMC Hoss wheels, Aero Turbine 2525
  2. Jun 13, 2009 at 8:08 AM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
  3. Jun 13, 2009 at 11:32 AM
    Blaise22
    Blaise
    California
    That looks perfect, im buying it. thanks for the response.
  4. Jun 13, 2009 at 7:31 PM
    Blaise22
    Blaise
    California
    The description for the alpine amp recommends 8 gauge wire but do you think I would be fine using the 4 gauge or should I just get what is recommended?
  5. Jun 13, 2009 at 7:47 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    If you are going to route it so that you have a major length of wire, go 4. But otherwise you can use 8 no problem
  6. Jun 13, 2009 at 9:30 PM
    Blaise22
    Blaise
    California
    So if im not running any major length of wire could I go with the 4? Would there be any difference between the 4 and the 8?
  7. Jun 14, 2009 at 6:45 AM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    cost. Just make sure you are getting a QUALITY 8 gauge wire. They are not all created equal. Remember, the smaller the number, the larger the wire.
    I've seen some manufacturer's 4 ga be no larger than a quality 8. It was all a thick wire jacket appearing to be much larger than it really was. Diesel Audio was the offender in this case.
    Any of the reputable (it will be more expensive) wire will be true to gauge.
  8. Jun 14, 2009 at 7:07 AM
    Blaise22
    Blaise
    California
    The 4 gauge was only 10 bucks more so I just went with that. Thanks for all the help so far goblue:cheers: Im probley going to have a lot more questions once everything gets here and I start wiring it up.
  9. Jun 15, 2009 at 6:59 PM
    Blaise22
    Blaise
    California
    1. I bought the kit listed above by knukonceptz, the groung wire is only 3 feet but im going to need at least 4 feet. Does the length of the ground wire matter? I was looking on their web site and all there kits include a three foot ground wire, is there a reason for that?
    2. Can I run the ground wire next to the power cable, or will that cause interference?
  10. Jun 15, 2009 at 7:50 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    The shorter ground wire, the better.
    You can run it where you need to no problem. There is zero chance of getting interference if you run it next to the positive wire.:thumbsup:
