what would be a good 3" lift for an 04 dbl cab?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04TRD4x4, Dec 25, 2009.
  1. Dec 25, 2009 at 3:27 AM
    04TRD4x4
    04TRD4x4 [OP] Active Member
    OC california
    04 limited TRD 4x4
    bumpers, rock sliders, rims, more to come
    I have a 04 double cab and I want to lift it 2-4" but still keep it very practical or daily drivable. What is my best choice. not the cheapest.... the best working and most reliable choice?
  2. Dec 25, 2009 at 6:09 AM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    Most people around this site like to get Toytec Lifts. Just type that in on google and you'll find some exellent lifts. The Toytec Ultimate Lift is a very reputable lift as well, if money isn't an issue. Becuase i'm poor, I went with a Rough Country lift for on $200.
  3. Dec 25, 2009 at 6:39 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Yeah I would say the toytec if you have the funds for sure. I didn't fork out for it I went with the Billstien 5100's up front and an add a leaf in the rear, but I'm planning to use a toytec coil over in the front with my 5100' soon.
  4. Dec 25, 2009 at 7:51 AM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    check my thread, i just did a 2.5/1.5 and love it
    if your going for 3" id suggest more than blocks thats for sure, at that point your strut will run low on stroke and the ride will suffer.
    A lot of people swear by the bilstien setup, usually about $300 for the front and get 2.5" lift or so and add a leaf to support to bilstien shocks back there or even a block.
  5. Dec 25, 2009 at 12:35 PM
    04TRD4x4
    OC california
    04 limited TRD 4x4
    I'll check out the toytec lifts. thanks alot for the info guys
  6. Dec 26, 2009 at 10:13 AM
    Dasler
    Dasler Bobby D
    Bobby D
    New Jersey
    04 Double Cab
    Toytec Ultimate Lift 3"
    ive got the 3 inch Toytec ultimate lift with AALs. very practicle, my ride actually got better and cant notice a difference with the gas mileage. easy install, took 6 hours, but could have been less. i put on 285/75/16 BF Goodrich AT. worth the money. the guys that work there are great. directions are very clear cut.
  7. Dec 26, 2009 at 10:33 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    dasler love the truck man, i see your running your stock upper control arms. Do you have any alignment issues, or get that wandering steering. Im going to be buying the same coilovers but i am thinking about getting some camburg uca's at the same time. What do ya got for backspacing on those dick cepek rims btw?
  8. Dec 26, 2009 at 10:39 AM
    Dasler
    Dasler Bobby D
    Bobby D
    New Jersey
    04 Double Cab
    back spacing has to be 4.5 or less. you dont need the uca's unless u got the extra dough to blow. Toytec tells you what to set the machine up at when u get your alignment. it rides better than stock. u wont believe it.
  9. Dec 26, 2009 at 1:19 PM
    04TRD4x4
    OC california
    04 limited TRD 4x4
    your truck is the perfect height. thanks for the info. I'm going to get the same lift you have. your truck looks just how i want mine to look. :)
  10. Dec 26, 2009 at 7:47 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i think i got dasler hooked on tw. before you know it he will have 10,000 posts.
  11. Dec 26, 2009 at 8:33 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
  12. Dec 26, 2009 at 8:51 PM
    2004Taco
    2004Taco Well-Known Member
    Long Beach,CA
    04 PreRunner SR5 Trd
    Magnaflow and Deckplate Mod Billet grille
    I like my coil spacer lift. I bought it from toytec.
  13. Dec 27, 2009 at 11:58 AM
    Dasler
    Dasler Bobby D
    Bobby D
    New Jersey
    04 Double Cab
    Ok mr "senior member". paintdiddy.. im only a "junior member" i am trying to catch up to you.
  14. Dec 27, 2009 at 7:25 PM
    4421.frank
    4421.frank Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    Check out my profile
    recently had bilstein 5100's installed on all four wheels as well as the Toytec AAL witha 1.5" block in the back. The fronts are set at the highest(2.5"). I really like the extra clearance and the over all look of the truck, ride is fine but I clearly need a new alignment.
