what would be the difference between 4" and 4.5" backspace
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4421.frank, Feb 18, 2010.
  1. Feb 18, 2010 at 9:07 AM
    4421.frank
    4421.frank [OP] Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    ok, so after everything on the different wheels threads I went ahead with teh pro comp series 8069 black steel wheels. After agreeing ona price and other aspects of the deal, I thought evrything was moving ahead then today I got this email from the supplier:
    "Ok, so I just went out to the warehouse, and we're out of the type B with 4" backspacing. I have one set of type A's but they have 4.5" backspacing. Let me know if that will be ok, or if your running too big of a tire."
    Can I still run these with out any rubbing issues? I am planning on wrapping them in a 265/16 tire.
    thanks for the info
  2. Feb 18, 2010 at 9:12 AM
    Its_Taco_Time
    Its_Taco_Time Well-Known Member
    Yorba Linda
    07 Tunda DC TRD Offroad
    CST spindles, Magnaflow, TRD intake
    4.0 backspacing will sit a little further out on each side. I have 4.5 and wish I had gotten 4.0
  3. Feb 18, 2010 at 9:13 AM
    sockmonkey
    sockmonkey Well-Known Member
    Greg
    Benbrook, SW Fort Worth
    2007 White Dbl Cab Pre-Runner
    Volant Ram Air intake,URD MAF calibrator, Mr Marv 10" sub box, Alpine HU, Alpine Amp, fog light mod, scan gauge II, RAAMmat front and rear doors, Wet Okole seat covers, blacked out dash. blacked out front bumper. American Racing Mojave Teflons wrapped with 265/70/16 Pathfinder AT. NST Lite Pulleys
    .5 inch
    you had to know that was coming :D:D
  4. Feb 18, 2010 at 9:17 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'm glad you said it....cause I was going to!!
  5. Feb 18, 2010 at 3:18 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    X2
  6. Feb 18, 2010 at 4:22 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    you can run 265-75-16s on 4.5" backspace...
    if you later decide to run 285-75s or bigger, you will need to run wheel spacers...
  7. Feb 18, 2010 at 4:31 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Is the backspaceing that comes on the Offroad model factory wheels 4.5?
  8. Feb 18, 2010 at 4:33 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    ^ TRD off road rims have a backspacing of more that 5" IIRC
    EDIT: TRD Off-Road Wheels: 16x7, +32 mm offset, 5.25" backspacing
  9. Feb 18, 2010 at 4:44 PM
    OffroadToy
    Thanks blackhawke88...nice truck in you signature!!
  10. Feb 18, 2010 at 5:02 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
