What would cause the 6spd shifter knob to turn and spin?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TrailJunkie, Sep 14, 2016.
  1. Sep 14, 2016 at 10:37 AM
    TrailJunkie
    TrailJunkie [OP] Member
    Blueridge Mountains
    2005 TRD OFF ROAD 6 SPD DOUBLE CAB
    Blacked out lettering Blacked out grille Secondary Air Filter Removed
    Ok last night I stopped at a gas station and noticed reverse was extremely hard to get into.. It went with a little extra effort and after I backed up where I needed to be... I shifted into 1st to try reverse again.... reverse was gone.... I tried it a couple of more times and my entire shifter turned like a steering wheel and could turn alot... It makes a srange noise when i move it around.... like a ziptie does when it's being tightened. What could cause that? It was shifting perfect until last night at the store.
  2. Sep 14, 2016 at 10:39 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Just the shift knob or the whole shaft?
  3. Sep 14, 2016 at 10:39 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Youre talking about the shifter itself and not the knob, correct? Possibly the linkages are broken.
    If yiure talking about the shifter knob, its just screwed onto the shaft.
  4. Sep 14, 2016 at 10:46 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    There is a locking collar that holds the shifter shift in the trans. Maybe the collar broke or unhooked?
  5. Sep 14, 2016 at 11:06 AM
    TrailJunkie
    Blueridge Mountains
    It's not the knob, it's the entire shifter knob and all lol .... It even pulled the shift boot loose when i was trying to figure out what happened lol
  6. Sep 14, 2016 at 11:09 AM
    TrailJunkie
    Blueridge Mountains
    I tried to pull straight up on it to see if the shifter would pull out.... guess I might as well pull everything off around the shifter and see ifs it's something simple.... I know there's not much in there so maybe I'll figure it out
  7. Sep 14, 2016 at 11:41 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    You have to take the center console off and then the front center console can come out. Just take a look at it there is not much has we can do from here
