What would happen???
Discussion in '4 Cylinder' started by toyota4wd, Jan 17, 2013.
  1. Jan 17, 2013 at 7:37 PM
    toyota4wd
    toyota4wd [OP] Well-Known Member
    Grant
    OME 887s Dakar Leafs, SPC UCAs, Spidertrax wheel spacers, Kenwood touchscreen, diff breather mod, Magnaflow 22in. muffler, AFE Pro dry S air filter, secondary charcoal filter delete. Soon to come Warn M8000 winch on a a Westin winch trey, full retros with demon eyes
    What would happen If I worked up the nerve to take my lil 4 banger past 4500 rpm??? Would it go back to the future? Would it blow up?(never) or would it just sound really cool when that vvti kicks in? THE WORLD MAY NEVER KNOW!:D
  2. Jan 17, 2013 at 7:52 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Isn't redline at 5500?
    Nothing bad will happen. The ignition system has a rev limiter that will hold RPM.
    Biggest concern is accidentally downshifting at too high of a speed... rev limiter can't protect against that.
    Back in the 90s when electronic controls were phased into automatic transmissions, I was told by a Ford service manager that the TCU would not allow the trans to engage if it would result in an overrev... not sure that I'd trust that.
  3. Jan 18, 2013 at 4:33 AM
    toyota4wd
    Grant
    The red line on mine is 6000 but I think that it would be screaming at that. I've only had it up to 4500 and that was only stationary revving it. I shift at around 3500
  4. Jan 18, 2013 at 4:57 AM
    adrstout
    adrstout Well-Known Member
    Adam
    Indiana
    '12 4cyl SR5 4x4
    2.5" lift, 265/75r16 Cooper AT3, All Pro Front Skid, KBVoodoo bed rack, a bunch of other random stuff
    Nothing. I rarely hit mine but do from time to time. 5500 froma 4 banger? Pretty sure they were conservative anyway.
  5. Jan 18, 2013 at 9:25 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Yes I agree the 5500 redline is probably conservative, as Toyota is with many other things (e.g. speedo error) although this is a large 4-cylinder. Anyway, I drive my truck gently 99% of the time, and since there's a brief, steep uphill climb in my weekly routine, it's a great excuse to "clear out the carbon" by completely flooring it every week in my 4cyl automatic until it decides to shift, usually around 5000-5500 RPM. I've been doing this for years, no problems whatsoever.
  6. Jan 18, 2013 at 9:38 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Ah, to be 18 again.
    Hitting the rev limiter ain't good for any vehicle. Would recommend not to do it. Get a civic if you want an engine that likes high rpm's.
    You can definately blow your motor if at the limiter. If it is only once for a split second, chances are not too much damage will be done.
  7. Jan 18, 2013 at 9:41 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Nothing will happen if you do it for short spurts, but I would not recommend it. Why take chances ruining your engine.
  8. Jan 18, 2013 at 9:44 AM
    Boerseun
    Ferdie
    Sarasota, Florida
    If you want to rev it, it's actually better to rev it while driving it and having some load on the engine than just free revving it. Free revving will cause rapid accelleration and decelleration which puts more tension on all the parts than gradual controlled tension while driving.
  9. Jan 18, 2013 at 1:31 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    It's not the typical 4 cylinder like you'd find in a passenger car, it's designed for torque not horsepower. Compare the piston diameter and stroke to other 4 cylinders you'll see what I mean.
    5500 rpm redline on this engine is as conservative as 6500 rpm redline on my wife's Honda.
  10. Jan 18, 2013 at 5:07 PM
    trooper12
    trooper12 Well-Known Member
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    maxtrac 4" lift spindles, wheelers 1.5" 3 leaf pack. nothin special...
    I redline my truck about 2 or 3 times a week, and it hasnt blown up yet. its a 4cyl they like to be reved. When im driving on the highway up to school i put cruse control on at 75 mph and the rpm's are 3,250+ for hours and ive had no problems with it
  11. Jan 18, 2013 at 5:14 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I redline my little 3rz probably weekly, when trying to merge into freeway traffic on uphill onramps. Only hit rev limiter a couple times but thats rare, usually when snow wheeling.:burnrubber:
  12. Jan 18, 2013 at 8:24 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You want to shift at peak HP.
    Going too high on the power curve is as bad as going too low, it's just easier to recover.
    My motorcycle's rev limiter is at 5500, but if I shift above 5200, there is a VERY noticeable loss of pull before the limiter hits.
    If you hit the limiter, you've already lost the race if the other guy knows how to drive.
  13. Jan 18, 2013 at 8:43 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Word of warning.
    Revving like that under no load (in neutral or park) can damage your crankshaft. It's not the final velocity of the crank that damages it, it's the sudden acceleration that can screw things up.
  14. Jan 18, 2013 at 8:46 PM
    The Traveler
    SoCal
    And, just because I used to race high power muscle cars on big tracks, I have to say this...
    Not exactly. Many times, it's a better idea to shift higher than your peak HP RPM because the next gear will fall right into the power band, giving you an advantage in the next gear up. That all depends, however, on how badly your HP/TQ drops off after the peak. If it's not too bad a cliff, I'd keep going and then shift throwing you right into the powerband on the next gear.
  15. Jan 18, 2013 at 8:55 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    About what an 81 Z28 would do off the showroom floor.
  16. Jan 18, 2013 at 8:59 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It does depend on your gearing.
    On my Vulcan, the low end is pretty strong so it's no killer if I shift 500 before peak.
    My dirtbike is a WR250F, and the wide-ratio trans does make for some interesting gear choices when the trail gets tight.
  17. Jan 18, 2013 at 8:59 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I used to rev my AE86 to 8k at least weekly, made that 100hp seem fast :laugh:
    You'll be fine.
  18. Jan 18, 2013 at 9:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ran my 2.7 on the limiter often. Many times, even when supercharged, I floor boarded the throttle, and let it go! Never had an issue.
  19. Jan 21, 2013 at 12:11 PM
    pigger
    pigger Well-Known Member
    Greg
    Rio Rathole
    04 tacoma 4x4 reg cab
    Detroit True-Track rear limited slip, steering rack bushings, shell, SAF decals, Wheelers 5-leaf & Bilstein 5100's, some nice LED lights from Chris, big-ass bumpers, older-than-dirt owner
    You can feel the power roll off above 4800rpm, IMO; not much point in exceeding that in most situations. I have hit the rev limiter a few times in times of overexuberance, though; glad it was there.
    I don't normally take mine over 5000 rpm. I do shift from 1st to 2nd at around 4800, when I'm trying to get up to speed; these trucks are not fast by any means. They don't really accelerate; they just gather speed.
  20. Mar 13, 2013 at 7:40 PM
    Poodle Head Mikey
    Poodle Head Mikey Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    The "redline" is what exactly? The maximum SAFE engine speed. So you could keep the engine running 100 RPM below the redline all day long and be fine.
    Stop worrying. You could probably run the engine at 150% of the redline for a good long while and nothing but maybe a higher wear rate would happen.
    I used to run small block Chevy and air cooled VW engines at 150% of the redline routinely and nothing bad ever happened. These Toyota engines aren't delicate little babies - they are tough, hell-for-stout Machines.
    Yes; I would normally try to avoid exceeding the redline - but if I did go over; nothing bad would happen for a good long while. The redline is not some magical threshold - it's more of a suggestion.
    PHM
