What would it take to convert to Bio-Diesel?
Discussion in '1st Gen. Tacomas (1995-2004)' started by hats009, Jan 14, 2012.
  1. Jan 14, 2012 at 4:22 PM
    hats009
    hats009 [OP] Well-Known Member
    09 4x4 TACOMA TRD
    I know a lot of you probably scoff at the thought and think it totally unnecessary - I am just wondering if any of you clever mechanic types out there could tell me what it would take to convert my beloved tacoma to a diesel so I could run it on Bio-Diesel.. or better yet some sort of a vapor engine in a perfect world.
    Why isn't there more people thinking/talking about this? :confused:
  2. Jan 14, 2012 at 4:37 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    It's a good idea, but it would be a huge project ordeal to swap in a diesel. Lot's of time and money involved.
  3. Jan 14, 2012 at 4:43 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Diesel engines blocks and just about everything else are beefed up to handle the much higher stress caused by diesel ignition.
    Swapping a diesel in would be the only way, but a high price to pay to run bio-diesel.
    Toyota has apparently decided no one in the US want one, unlike the rest of the world.
  4. Jan 14, 2012 at 4:47 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    To pay someone to do it would be about 10,000 for Diesel Toyz in AZ to do. DIY I would guess it would be about 7-8,000. As far as I know all you have to do is filter the oil, get a second fuel system and switch it to oil when the motor is warm.
  5. Jan 14, 2012 at 4:50 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Just take your spark plugs out, BAM! diesel.
  6. Jan 14, 2012 at 4:52 PM
    brp
    brp Well-Known Member
    You need a 2nd, heated, fuel system to run on vegetable oil (waste vegetable oil, svo). That is just for vegetable oil, you could eat the stuff. You can usually
    get it for free from restaurants after they fry with it. Then you filter in put it in the second tank.
    You can make biodiesel out of vegetable oil, some "brewing" needs to be done. That can be used in the diesel engine with no modification or second fuel system, other than synthetic lines, as mentioned earlier. Biodiesel and regular diesel can me mixed in any ratio.
    I have gone over 100,000 miles on free vegetable oil, it is really cool.
    My buddy has 205,000 miles on his greased F350.
    PM me if you have specific questions.
  7. Jan 15, 2012 at 6:08 AM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    I always wanted to get a 4bt and drop it in my truck. Might need to beef up the suspension to handle the weight and clearance though. It would be pretty cool!
  8. Jan 15, 2012 at 7:51 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I hear what you are saying but you would be better off ordering a Hilux from over seas and shipping it to the states. You would have nothing but a shit storm mess converting, IMHO.
  9. Jan 15, 2012 at 9:25 AM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    Good biodiesel is expensive. From experience if it's cheep bio be prepared to fix a lot of hoses and an occasional fuel pump. Thou if you can get 140 HP out of a 1.6 VW motor you should easily make 200 out of the 1.9. The cummins 3.9 is a great motor but it's very heavy.
  10. Jan 15, 2012 at 9:37 AM
    joes06tacoma
    Joe
    Central Coast, CA
    ^^ Yes
    Big money. You can't convert your current engine, it has to be replaced with a diesel. Engine swaps are all about little details to get them right. Even if you can do all the work yourself it is questionable whether it will ever pay off for you. If you have the money and this is about wanting to be green and reduce your consumption of foreign oil and you will keep the truck forever, then go for it. If it's about reducing your fuel bill, forget about it. 7-10K dollars buys a lot of fuel.
    OP, you might be thinking of WVO. I think that's what Warhorse is referring to as well. Biodiesel can be bought at a pump and isn't that much cheaper than regular diesel. WVO (waste vegetable oil) is different and can't be left in the injection system at shutdown. You get used fryer oil from a kitchen somewhere, filter it, and put it in a seperate tank. The vehicle has to be started on regular diesel, warmed up, then switched over. You then switch to diesel again to shut it down.
    I would love to have a diesel Tacoma, but I want it for lower cost of operation. There is no practical way to make that happen unless you can front 10K dollars to convert an existing vehicle, then drive it another 200K to maybe get your money back. That's assuming that the modified truck does not become a maintenance nightmare, get wrecked, etc.
  11. Jan 15, 2012 at 9:50 AM
    Warhorseforever
    Will
    Sand Lapper
    Dieseltoyz.com is the website I was talking about. They appear to do good work and explain wvo svo diesels.
  12. Jan 15, 2012 at 10:11 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Yes they are heaver and will the frame and suspension take the extra weight?
  13. Jan 15, 2012 at 10:15 AM
    Warhorseforever
    Will
    Sand Lapper
    lol Try 19,500 for the diesel manual tans that I would do to my truck, but hey if you got the money why not?
  14. Jan 16, 2012 at 3:46 AM
    Trapper6speed
    Stock
    I think it would be easier and cheaper to drop in a ls3 motor.
  15. Jan 16, 2012 at 2:32 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Actually, importing a diesel hilux would only run about 9k, sans the initial purchase price.
    shipping fee's ($3800), import/inspection fee's ($1400), customs fee's ($1100) and Taxes ($2300) for a total of $8600.
  16. Jan 16, 2012 at 2:37 PM
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
  17. Jan 16, 2012 at 2:42 PM
    worthywads
    And leather interior.
  18. Jan 16, 2012 at 2:45 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Here is the 3.0l diesel engine they put in the Hilux. :drool:
  19. Jan 16, 2012 at 6:50 PM
    Trapper6speed
    Stock
    Ok but right hand drive kinda sucks. You could deliver mail.
  20. Jan 16, 2012 at 8:15 PM
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    How do you get to the spark plugs.
