What year of 4runners are compatible to a 2nd gen Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rise007, Jan 27, 2020.
  1. Jan 27, 2020 at 7:17 PM
    Rise007
    Rise007 [OP] Well-Known Member
    2012 white Tacoma 5 speed manual
    I am wanting to take off a e locker axle from a 4Runner old model to make my rear diff lock what is compatible to my 2nd gen Tacoma
  2. Jan 28, 2020 at 6:39 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Anything is possible with enough cutting and welding!:sawzall::welder: Why a 4Runner? Rear disc brakes?
    Starting in 1989, 4Runners all have linked rear ends using coil springs (instead of leaf springs used in Toyota pickups and earlier 4Runners), so you'd have to cut and weld spring perches for leaf springs and shock mounts. 2003-current 4Runners use the same 3rd member (and I believe the same tack width) as 2nd Gen Tacomas but the 4Runner began using disc brakes on their rear axles starting then and you would have to figure out the e-brake, ABS and brake line plumbing in addition to the requisite cutting and welding.
    If you're not in to that amount of research and work, your easiest bet would be to just find a complete Tacoma e-locker rear end (because the housings are different between e-locker and open diff models; you can't put an e-locker 3rd member in an open diff housing without modifying it) or just put in an aftermarket locker and call it good.
    MAG GRY TACO15 and Muddinfun like this.
