What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. May 24, 2016 at 7:39 PM
    #2321
    irishrye
    irishrye Well-Known Member
    Second that question.
    btw looks great!
    619HiluxLover[QUOTED] likes this.
  2. May 24, 2016 at 7:41 PM
    #2322
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Since you are putting a body lift on are you planning on custom front and rear bumpers? The body lift is a good idea to keep from having to trim body parts to fit tires. But the bumpers are connected to the frame so you will have a gap in both bumpers.
    arkywally[QUOTED] likes this.
  3. May 24, 2016 at 7:43 PM
    #2323
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    Good note, and I have it tucked away,
    I would like to get bumpers down the road so to speak, the body lift is always a variable that I do not like but semi...easily removed.
    Thanks for that inside dirt, much appreciated info!
  4. May 24, 2016 at 7:47 PM
    #2324
    Gramps
    Gramps
    07 TRD DC 4x4
    Also just to let you know with the body lift and BOSS 2.0's you could achieve 3.5"s of lift.
  5. May 24, 2016 at 7:55 PM
    #2325
    arkywally
    David
    2016 DCSB TRDOR
    Thats good news, looking to achieve a 3" lift with a mellow rake...
    What do you know about the 2"AAL, 2.0 rears with the stock overload, as far as how much will that settle under nominal load....after lift?
    I guess thats not a fair question but I am still short of my Toytec phone call to hash more details, if there are any.
  6. May 24, 2016 at 8:05 PM
    #2326
    Gramps
    Gramps
    07 TRD DC 4x4
    I don't have a good answer on that one. But call Toytec and dial extension 101. Dylan will be able to help you out on that part.
  7. May 24, 2016 at 8:15 PM
    #2327
    xTacoma16x
    xTacoma16x Well-Known Member
    TRD sport 2016
    If you want bigger tires 285 I would look in different rims stock 7" is not ideal and +30 offset is what will cause rubbing on ucas. 285 need 8.5"-9" rim and look for more offset +6, 0, -6, or -12 I think best looking wheel for 285 in Method NV lots of people have them.
    Also I would recommend progressive leaf pack over single 2" ALL
    Gramps and arkywally[QUOTED] like this.
  8. May 24, 2016 at 8:35 PM
    #2328
    arkywally
    David
    2016 DCSB TRDOR
    Method NV is exactly what I have my sights on, thanks for the offset info....Talking to Toytec tomorrow on the rear end set up...excellent feedback from all involved!
  9. May 25, 2016 at 7:36 AM
    #2329
    Toytec Lifts
    Toytec Lifts [OP] Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Hey,
    Go ahead and give us a call here at Toytec, maybe we can answer some more questions you may have.
    Justin
  10. May 26, 2016 at 8:49 PM
    #2330
    harley100
    harley100 Well-Known Member
    Phil
    Colorado
    2016 tacoma off road dbl cab short bed white
    too many mods to count
    Would like to know if I can use LRucas with King ext travel coilovers and be ok.
  11. May 27, 2016 at 7:25 AM
    #2331
    harley100
    Phil
    Colorado
    Why would there be a problem?
  12. May 27, 2016 at 7:41 AM
    #2332
    harley100
    Phil
    Colorado
    Thanks i am exchanging those for total chaos control arms today.
  13. May 27, 2016 at 9:33 AM
    #2333
    Gramps
    Gramps
    07 TRD DC 4x4
    The SPC BJ was touted as having the same travel as a uniball. Now I haven't seen a side by side comparison to verify that though. But a good uniball UCA would be better mated to a set of KINGS for sure.
    NV_Tacoma likes this.
  14. May 29, 2016 at 7:34 PM
    #2334
    Gramps
    Gramps
    07 TRD DC 4x4
    Your factory spring is rated at 712lbs. So I would definitely go with the 700lb springs.
  15. May 29, 2016 at 8:53 PM
    #2335
    SLACKBOY
    SLACKBOY Toyota For Life!
    Erich
    Washington State
    2016 MGM Toyota Tacoma OR 4x4
    Blacked Out Emblems Wet Okole Seat Covers Installed Tinted Front Windows Weathertech Digital Floor Liners for the Front Plasti Dipped OF Grill - Removed BAMF Grill - MGM Installed Icon Stage 2 Kit. TRD Pro Wheels - 17's Ko2s installed (275 70 17) TRD PRO Rigid Led Fogs N Fab 3" Step Bars TRD Pro Auto Shift Knob TRD Pro Tail Lights
    What are the icons rated at?
  16. May 30, 2016 at 5:38 AM
    #2336
    usmcadamsa
    usmcadamsa Well-Known Member
    Adam
    2016 Tacoma TRD Sport 6Spd
    Bone stock
    I have a few questions if you guys don't mind taking a few minutes to assist.
    1. Does anyone have pictures of their 16' tacoma with a 3 inch lift with a ruler next to it to see total height?
    2. What full lift kit is out there that does NOT utilize rear blocks?
    3. I like the king off road lifts but their website is not working for me to view the items. So any recommendations on lift kits that will give 3 inch lift? I will in next few years have a few toys to tow.
    4. Rim and tire size for a comfy fit at a 3 inch lift?
  17. May 30, 2016 at 5:00 PM
    #2337
    Gramps
    Gramps
    07 TRD DC 4x4
    Standard spring us 650lb. You can order them with a 700lb spring.
  18. May 30, 2016 at 6:20 PM
    #2338
    SLACKBOY
    Erich
    Washington State
    Oh good to know. Just ordered the stage 2 didn't pick.
  19. May 30, 2016 at 8:20 PM
    #2339
    mxtom203
    mxtom203 Member
    Thomas
    2016 BLACK TACOMA TRD SPORT 4X4
    IN THE WORKS
    I have SPC ucas and i installed them with the e setting for clearance. When i went to the alignment shop they changed one side to the d setting and left the other one set at e. The alignment is in spec, but i wasnt sure if it was okay that they were set differently on both sides. Any info is much appreciated.
  20. May 31, 2016 at 11:22 AM
    #2340
    grlwood
    grlwood Active Member
    Garrett
    OKLAHOMA
    2016 Silver DCSB TRD OR 4x4
    5100's 1.75, 1inch AAL, ECGS Bushing Falken Wildpeake AT3 265/75R16
    Im sure this is answered in this thread somewhere but haven't found it yet. Im about to install 5100's in the front. Im using the stock coils and plan to do nothing at the moment to the rear. Will setting them at .85 get me level or any noticeable difference or should I set to 1.75?
