What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Jun 10, 2016 at 12:22 PM
    #2401
    JerryTaco
    JerryTaco Well-Known Member
    They do attach using double stick tape, but I've never had a problem. Never trapped anything on the inside, on this truck or my 2012
  2. Jun 10, 2016 at 4:00 PM
    #2402
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    Cool, I'll check them out. Any experience with the neoprene sleeves? Ive used them on my Yamaha raptor and yfz450 in the past. They helped if you were following somebody throwing a roost very closely in the sand.I'm not sure the front coilovers on a pickup take the same beating?
  3. Jun 10, 2016 at 4:05 PM
    #2403
    JerryTaco
    I don't have any experience with those. But I'm sure sdhq will also have them in stock. Certainly couldn't hurt. Cheap insurance at the very least
  4. Jun 10, 2016 at 6:53 PM
    #2404
    Patrick16taco
    Patrick16taco Patriot Pride Honor
    Sandy Taco
    SoCal
    2016 Tacoma Crew Cab 4X4 Quicksand
    So I just lifted my 2016 4x4 offroad. Just did the bilstein 5100s adjusted to the top clip. The kit didn't come with the different drop kit. Would you guys recommend getting the drop down kit? Thanks
  5. Jun 10, 2016 at 7:15 PM
    #2405
    SLACKBOY
    SLACKBOY Toyota For Life!
    Erich
    Washington State
    2016 MGM Toyota Tacoma OR 4x4
    Blacked Out Emblems Wet Okole Seat Covers Installed Tinted Front Windows Weathertech Digital Floor Liners for the Front Plasti Dipped OF Grill - Removed BAMF Grill - MGM Installed Icon Stage 2 Kit. TRD Pro Wheels - 17's Ko2s installed (275 70 17) TRD PRO Rigid Led Fogs N Fab 3" Step Bars TRD Pro Auto Shift Knob TRD Pro Tail Lights
    Don't need it.
  6. Jun 10, 2016 at 8:08 PM
    #2406
    Patrick16taco
    Sandy Taco
    SoCal
    Great! Thanks for the reply!
  7. Jun 10, 2016 at 8:18 PM
    #2407
    Lord Humongous
    AZ
    I just lifted my taco with Icon coilovers. They are turned up about 2.25 inches over stock. The CVs looked pretty good but I still put the drop kit in. They look even better afterwards. My reasoning was it does make a noticable difference and it was only 30 bucks and 30 minutes of work. Here's an after pic. I forgot to take a before pic before I put it on.
  8. Jun 11, 2016 at 4:39 PM
    #2408
    Lord Humongous
    AZ
    Nice! Did you remove any leafs from the dakar packs?
  9. Jun 11, 2016 at 4:41 PM
    #2409
    JerryTaco
    Negative. We bolted them on just how they came. Ride height looks awesome
  10. Jun 11, 2016 at 5:39 PM
    #2410
    Lord Humongous
    AZ
    Yeah they look good! I heard they were a bit too high on the 16 but that looks great!
  11. Jun 11, 2016 at 6:53 PM
    #2411
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    Looks good, and you got the SPC's at $399 or so....no more, somewhere in the range of 465-485...
    What I really meant to say is about f...ing time!!! I am glad for ya. I just wish I could be as motivated. Looking forward to all that comes down the pike...
  12. Jun 14, 2016 at 12:09 PM
    #2412
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Hi Guys,
    Just got my tracking number from the group buy for my OME Suspension Kit with 887's and Dakar leafs the other day. So hopefully they will be here in a few days. I also got a set of Light Racing Upper control arms and a set of 4 stainless steel 2" extended brake hoses! And 2 new bolts for the upper control arms so I can just cut the heads off and pull them out!
    I got a few questions for you guys. I do all the work on my own vehicles and I'll be installing the kit.
    1. Just wondering when I install the Light racing upper control arms should I just center the ball-joint in the center of the oval slot where you adjust it back and forth for the camber?
    2. I'll be scheduling a alignment for the truck shortly after I get the lift installed but should I ride on the kit for a few days before the alignment if there is going to be any settling?
    Thanks!
  13. Jun 14, 2016 at 12:27 PM
    #2413
    moe2o4
    Corey
    Pittsburgh PA
    Awesome, Ya mise well add all 4 lines so I don't have to worry about changing the stupid rubber ones in the future. But I read the install instructions of the ball-joints on the control arms to be set at 0, I'll just center them the best I can and aim for getting an alignment the next day! Got the coils installed with new top hats so the front should be cake! Thanks Josh if I got any questions I'll let ya know!
  14. Jun 14, 2016 at 12:30 PM
    #2414
    moe2o4
    Corey
    Pittsburgh PA
    Gonna order some of that dry lube on Amazon right now! And I've read about the zip tie mod but where do I find that post to see where to put them. Can't remember where I saw it.....
  15. Jun 14, 2016 at 12:32 PM
    #2415
    steezemcqueen
    steezemcqueen 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
    Neither bolt needs to be cut. The passenger one takes a little more finagling but is still able to be removed and installed without cutting it
    KiteGuam and moe2o4 like this.
  16. Jun 14, 2016 at 12:32 PM
    #2416
    moe2o4
    Corey
    Pittsburgh PA
    I can always just install them from the back to the front and they will go right in!
  17. Jun 14, 2016 at 12:33 PM
    #2417
    moe2o4
    Corey
    Pittsburgh PA
    2 bolts cost me $20 on Amazon!
  18. Jun 14, 2016 at 12:33 PM
    #2418
    steezemcqueen
    Dylan
    Crawlarado
    Not really any worse of bending than the driver side.
  19. Jun 14, 2016 at 12:41 PM
    #2419
    Lord Humongous
    AZ
    I just cut both out. 4" Diablo torch blade on the sawzall took care of that in about 2 minutes. No bending of sheet metal or cringing! Torque wrench and loc-tite good to go!
    moe2o4 likes this.
  20. Jun 14, 2016 at 12:42 PM
    #2420
    moe2o4
    Corey
    Pittsburgh PA
    What's the torque on that bolt?
