What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Feb 15, 2017 at 5:18 AM
    #3041
    Toytaco2k17
    Toytaco2k17 Well-Known Member
    Kenneth
    Chapmansboro Tn
    2016 Nissan Titan XD Pro4x Diesel
    Stock
    I know the spring was fine before. I think i figured it out. It looks like the spring is clocked wrong according to some instructions I found on the 2nd gen forum. I am going to go rent a crappy spring compressor and reclock it since i'm not scared of it blowing apart now.
  2. Feb 15, 2017 at 9:03 AM
    #3042
    Toytaco2k17
    Kenneth
    Chapmansboro Tn
    Stock
    They are on the first notch "0".
  3. Feb 15, 2017 at 5:21 PM
    #3043
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Then as you stated in the post above it might be clocked wrong.
    Toytaco2k17[QUOTED] likes this.
  4. Feb 16, 2017 at 7:30 AM
    #3044
    Sweeniss
    Sweeniss Member
    Kyle
    2017 Cement TRD Pro
    Hey ToyTec, was considering lifting my TRD pro 2.5" (which according to the original post I would only need a 1.5" I believe) and was wondering if you had any insight on how to do so with the TRD pro suspension. I'm colorado based so I would like to do it through you guys in denver if at all possible. Thanks in advance for the feedback!
  5. Feb 16, 2017 at 8:40 AM
    #3045
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    I have been looking at getting an OR but there is just no way I can swing that kind of dough. So I'm looking at a SRAC in a manual. I realize that I loose a lot of cool upgrades in the OR but I really won't use them that much. What I will miss is the suspension on the OR as I live on one of the worst roads in Tuolumne County (and that was before the 30ish inches of rain this year).
    So what are your thoughts on getting that soft ride out of the SR? Not really looking at a lift as I will not be going beyond a 265/75/16.
  6. Feb 16, 2017 at 8:42 AM
    #3046
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Buy my OR suspension that's sitting in my garage.
    Nah, you can go for the 5100 route or look into one of the Toytec or Icon kits.
  7. Feb 16, 2017 at 5:08 PM
    #3047
    MrSmithsTaco
    MrSmithsTaco Well-Known Member
    Oklahoma City, OK
    2016 Super White Tacoma TRD OR
    Me in the driver seat.
    That's good to know.
  8. Feb 16, 2017 at 5:30 PM
    #3048
    Toytec Lifts
    Toytec Lifts [OP] Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Hey
    So as of now we do not have anything for the pro suspension. We have been in the works of designing a top spacer for the system so you can keep the pro ride quality. As of now it is not available, but we can get the Daystar spacer if you don't want to wait.
    Definitely let us know
    Thanks
  9. Feb 16, 2017 at 6:05 PM
    #3049
    Sweeniss
    Sweeniss Member
    Kyle
    2017 Cement TRD Pro
    I definitely would like to wait for that. Would it be possible to give you my contact information so you guys can give me a heads up when you are putting the finishing touches on that new deisign?
  10. Feb 16, 2017 at 8:00 PM
    #3050
    OH-_SNAP
    OH-_SNAP Well-Known Member
    San Diego, CA
    2016 WHITE LIMITED 4x4 DOUBLE CAB
    ARE V Camper Shell, FiberGlass Hood w/ Functional Skewp. ICON 2.5" Front (ordered)
    Gramps likes this.
  11. Feb 17, 2017 at 12:15 PM
    #3051
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    Question about brake lines.. on a 2-3" lift, I read that an extended brake line is required for the rear, but not necessarily the front.
    Do I need extended brake lines front and rear or just rear?
    Thx.
  12. Feb 17, 2017 at 12:49 PM
    #3052
    Gramps
    Gramps
    07 TRD DC 4x4
    Just rear. Only way you would need front would be if you went with long travel.
  13. Feb 17, 2017 at 12:53 PM
    #3053
    tacitos
    16 TRDORDCLBJBL
    Thanks Gramps, gonna swap the front out with standard length steel lines then.
    Gramps[QUOTED] likes this.
  14. Feb 17, 2017 at 12:58 PM
    #3054
    tacitos
    16 TRDORDCLBJBL
    I should of asked this earlier.
    For those of you with a 3rd gen that swapped out your rear or front lines. What brake fluid did you use when bleeding the new lines?
  15. Feb 17, 2017 at 1:12 PM
    #3055
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    Dot 3 or 4 will work
    Gramps and tacitos[QUOTED] like this.
  16. Feb 18, 2017 at 3:25 AM
    #3056
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    im interested also, front needs to be alitte higher
  17. Feb 18, 2017 at 4:32 AM
    #3057
    Gramps
    Gramps
    07 TRD DC 4x4
    Yeah. I have front stainless a well. Firmer pedal for sure with stainless line. I like it.
  18. Feb 19, 2017 at 7:04 AM
    #3058
    bucktowntaco
    bucktowntaco Well-Known Member
    New Orleans
    2017 MGM DCSB TRD Sport
    ATE Dot 4 was my favorite.
  19. Feb 19, 2017 at 9:33 PM
    #3059
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I don't think your supposed to mix dot 4 with dot 3. So unless your planning on flushing the whole system. I just picked up a bottle of OE Toyota brake fluid for $7 at the dealer. I believe it's dot3
  20. Feb 21, 2017 at 8:21 AM
    #3060
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    This may be a stupid question, but is bleeding the brakes on a 3rd gen the same as it always is? I've heard you need to hook it up to the tech stream so that is pulses the brakes because of the ABS? I could see if you let a ton of air in there and had to bleed the whole line to the ABS pump but I figured the normal process would work fine. Any one have any input on that? Thanks
