What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Apr 17, 2017 at 6:56 PM
    #3141
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Ride quality should actually be better than stock. The fact that the Foxes are meant for a 2-3" lift should give you a bit more travel but I don't think they would necessarily be stiffer.
    whitedlite[QUOTED] likes this.
  2. Apr 17, 2017 at 7:03 PM
    #3142
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
  3. Apr 17, 2017 at 7:07 PM
    #3143
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
  4. Apr 17, 2017 at 7:13 PM
    #3144
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Correct future proofing a purchase.
  5. Apr 18, 2017 at 4:51 AM
    #3145
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    I would be concerned that the model number for a 2 -3" lift might be too long for stock height. You could end up bottoming out the shock and ruining it. I see on that page they also offer one for 0-1.5" in lift. That would be a better fit for yours.
  6. Apr 18, 2017 at 7:26 AM
    #3146
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Yes, that would be ideal the 0-1.5, but there's a pair of 2-3 for sale locally to me.
    That's why I'm asking, I didn't think about the bottoming issue, hmm, I wonder if the shock on stock height would take away an inch or two of travel.
  7. Apr 18, 2017 at 11:50 AM
    #3147
    Gramps
    Gramps
    07 TRD DC 4x4
    You w
    You would gain droop with the longer shock but the shock will become you bumpstop on the compression side unless you put in a longer bump stop to offset that. Then you will be limiting up travel quite a bit.
    schmack b likes this.
  8. Apr 19, 2017 at 5:42 PM
    #3148
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Hey guys,
    I'm running an Icon Stage 4 kit on my 2016 TRD OR. I'm trying to see if there is a way to tell if I have the standard or extended length coilovers. I'm running TC UCAs, so I'm assuming I have the extended lengths, but is there any way to confirm?
  9. Apr 19, 2017 at 7:02 PM
    #3149
    Gramps
    Gramps
    07 TRD DC 4x4
    All stage 3 and up ICON kits use extended travel coilovers. :thumbsup:
  10. Apr 19, 2017 at 8:01 PM
    #3150
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    My man! Good to know, that's kind of what I figured. Just wanted to make sure. I already need to swap out my rears so I didn't want to have to change it all out!
  11. Apr 19, 2017 at 8:17 PM
    #3151
    Gramps
    Gramps
    07 TRD DC 4x4
    Ok. Help me understand why your front coilover length has to do with your rear shocks?
  12. Apr 19, 2017 at 8:28 PM
    #3152
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    Oh, they're different situations. I'm upgrading the rears because I have an RTT inbound and a rear plate bumper, and I'll be running the Deaver U402 expedition springs. I wanted to make sure I didn't have to change the front out at all, as I'm adding a front bumper [and new 700# springs] and probably TC LCAs and didn't want to limit my downtravel.
    JerryTaco likes this.
  13. Apr 19, 2017 at 8:35 PM
    #3153
    tarandus
    tarandus Well-Known Member
    Montucky
    '17 TRD DCab OR Supah White
    ProComp/Headstrong leveling kit, AllPro rock sliders.
  14. Apr 19, 2017 at 8:38 PM
    #3154
    JakeDay009
    JakeDay009 Member
    Jake
    17 TRD OFF ROAD
    None yet... Temp tags?
    So what I am gathering the Icon stage 4 is a good starting block for a lift then add stiffness as you add plate? (been reading the convo for a bit)
    Gramps likes this.
  15. Apr 19, 2017 at 8:52 PM
    #3155
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    It's definitely more than a good starting block -- I'd say it's one of the better options. It's on par with the King Spring systems and I think the only significant advantages that the later Icon Stages add are the CDC valve that allows you to adjust how the ride feels. The Toytec Boss kits are also a good start if you're looking for a bolt-on higher end kit.
    JakeDay009[QUOTED] likes this.
  16. Apr 19, 2017 at 8:55 PM
    #3156
    JakeDay009
    JakeDay009 Member
    Jake
    17 TRD OFF ROAD
    Thanks, I'v been hunting "searching" for an answer like that. Would you say its a pretty complete set up? It seems almost too easy to me from an install point for it to have so few parts.
  17. Apr 19, 2017 at 8:58 PM
    #3157
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    It's about as complete as you can get -- it's rear AALs, rear shocks, front shocks, and upper control arms. The only things you will want to add is a diff drop to reangle the front diff, and bump stops if you'd like. I also found that my rear shocks didn't quite fit with the extended rezzies and I had to cut the frame shock mount slightly [like 0.75 in^3] to run the hose. Otherwise it's fairly straightforward to install.
  18. Apr 19, 2017 at 9:01 PM
    #3158
    JakeDay009
    JakeDay009 Member
    Jake
    17 TRD OFF ROAD
    Boom, Thanks for the help, excited to get this adventure underway! Now to for diff drop research!
    BEAR_KNIFE_FIGHT likes this.
  19. Apr 19, 2017 at 9:09 PM
    #3159
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    No prob, there are a ton of much smarter people than me in this thread. Toytec is where I ordered my stuff from and they have diff drop kits there. They're also super helpful and responsive, both via phone and PMs on here, Good luck man!
    Gramps and JakeDay009[QUOTED] like this.
  20. Apr 20, 2017 at 3:21 PM
    #3160
    Gramps
    Gramps
    07 TRD DC 4x4
    Ok that makes more sense now. That is quite an upgrade you are doing. Make sure to post up pics. I want to see it all when you are done.
