What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Sep 10, 2017 at 1:56 PM
    #3241
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Waiting for my new coil overs to come in. Question, do they really settle much? if at all? Don't want to get alignment yet if they do...thanks
    RobP62 likes this.
  2. Sep 16, 2017 at 5:43 AM
    #3242
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    can I add a tuff country aal to stock rear suspension for xtra load capacity? or do I need to upgrade rear shocks?
    thanks
  3. Sep 17, 2017 at 12:23 PM
    #3243
    dyna962007
    dyna962007 Well-Known Member
    Edwardsville IL near Saint Louis MO
    Tacoma 2016 TRD OffRoad / Previously 2007 4wd
    3" lift kit. 17" wheels and tires, custom grill, full technology package, Early model running boards, Push bar.
    How high can you raise the rear without having to buy new shocks? 2016 TRD off road 3.5
    sorgon82 likes this.
  4. Sep 21, 2017 at 1:25 AM
    #3244
    fnhi808
    fnhi808 Member
    sheldon
    17 dblcb trd 4x4
    needa know this answer and only because ive been getting mixed answers....2017 dbl cab 4x4 trd....if I add a 2in leveling it in the front, would it come level or would I still have a back to front rake??
    second with that 2in leveling kit for the front, am I able too run 275 70 17 without it rubbing?? please and thank you very much for your time and answer...
    I am very greatful..
  5. Sep 21, 2017 at 6:17 AM
    #3245
    20tacoma17
    2017 DCLB Sport AT
    I have 2.5 front and 2 rear and it's only very slight rake. If you go only 2 front I think it will be slightly lower in rear. With 2.5 front I'm running 275/70/17 ko2 no rubbing but very close. Some tires are slightly larger than others so I can't guarantee another brand of same size won't rub. :notsure:
  6. Sep 21, 2017 at 8:36 AM
    #3246
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    With 2" lift in the front you will most likely have a bit of the "bro lean" or as you say, front to back rake. You should also install an add a leaf (AAL) or, even better, install a full OME Dakar leaf pack in order to avoid the reverse rake.
    As far as the 275/70/17 rubbing issue... I have 2.5" of front lift and 2.75" of rear lift and have no rubbing. However, when I had a recent alignment done the tech adjusted the Castor to factory spec (2.7 on each side) and I had terrible rubbing on the cab mount. I had to take it back and have them increase the castor to 3+ in order to stop the rubbing. That said, your alignment will play a huge role in whether you have rubbing or not.
    sorgon82 and 20tacoma17 like this.
  7. Sep 21, 2017 at 9:19 AM
    #3247
    fnhi808
    fnhi808 Member
    sheldon
    17 dblcb trd 4x4
    thanks guys Imma go with the bilsteins 5100 route seems to be a lot better in everybodys opinions...I appreciate the feed back
    sdsurfer[QUOTED] likes this.
  8. Sep 26, 2017 at 4:46 AM
    #3248
    sorgon82
    Ont. Canada
    at what height are extended brake lines needed?
  9. Sep 26, 2017 at 5:25 AM
    #3249
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    I believe if you lift more than 2.5” it is a good idea to go with extended break lines. If you won’t be flexing much or doing significant off roading you can get away without extended break lines. But if you plan on flexing much it’s always a good idea.
    Gramps and sorgon82[QUOTED] like this.
  10. Oct 2, 2017 at 8:32 AM
    #3250
    FLdub
    FLdub Well-Known Member
    SRQ FL
    2016 Black Tacoma TRD OR 4x4
    Great thread! Just have a few questions.
    Ive got a full ADS kit (2.5 shocks with external reservoirs) with Total Chaos UCAs and an All-Pro leaf pack ill be installing pretty soon.
    Is there anything else that you all might recommend doing as well?
    I was considering doing the clamshell bushing replacement. Not sure if im missing anything else.
  11. Oct 4, 2017 at 5:24 AM
    #3251
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Quick question for you guys.
    With Bilstein 6112 adjustable front shocks the coil that comes with them is approximately 14" long and has a 600# spring rate.
    My question is can the 6112 be used at the lowest setting height with a 16.00"x 3.0" 700# coil spring in place of the ones provided?
    In theory this is no different than running OME coils on 5100s at the lowest setting. You still achieve the desired lift without the preloading..... Am I correct or am I off in my thinking?
    https://m.summitracing.com/parts/eib-16003000700s
  12. Oct 4, 2017 at 7:04 AM
    #3252
    Toytec Lifts
    Toytec Lifts [OP] Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Great question! I would imagine they would work but then again I can not promise nor guarentee that they will work and how much lift you will get from that setup...
    We personally do not recommend pairing up OME coil spring and Bilstein shocks here, yes they will work together just fine but they are not proven by manufacturer to work with each other.
    RedBeard1[QUOTED] likes this.
  13. Oct 4, 2017 at 9:26 AM
    #3253
    RedBeard1
    Red
    Y'all mind doing some R&D?
    Seems to me that it would work better than preloading the 600# coils to the upper couple of grooves. In the top groove under full compression it is pretty close to coil bind. Even with extensions on the bump stops.
    I am going to have to change spring rates anyway because the 600# springs don't like the weight of the armor. I figured I'd ask if anyone has done this. Don't really want to upgrade to Fox or Kings with 700# springs.
  14. Oct 4, 2017 at 11:52 AM
    #3254
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Why not go 14"
    Why not go with a 700lb 14" spring? Thats what I run on my ICONS with very little preload.
  15. Oct 4, 2017 at 12:14 PM
    #3255
    RedBeard1
    Red
    On the 6112 the 14" 600lb is to close to coil bind at full bump for my comfort when they are at the upper adjustment grooves. That is why I was wanting the longer coils at the lowest groove.
    If I had a set of tradition coilivers that is the route I would go. Thanks for the insight.
  16. Oct 4, 2017 at 12:20 PM
    #3256
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    I have a question. A while back, someone here said, it's not the shocks that gives the lift to the truck, it's the springs that gives the lift. Is this statement still true? Because my purchase depends upon it.
    Thanks
    TRDOBSESSED likes this.
  17. Oct 4, 2017 at 12:22 PM
    #3257
    JerryTaco
    JerryTaco Well-Known Member
    correct, shocks do not lift the truck, springs do.
  18. Oct 4, 2017 at 12:25 PM
    #3258
    bacon_st
    San Diego
    16' Taco TRD sport
    Great. I wanted softer shocks, not stiff ones. I am not going to off-road anywhere, my truck is a pavement truck.
    So is it possible for me to use stock OR shocks with some longer/taller springs/coils to give the lift? Or do I need 'longer' shocks to go with 'taller' springs?
    And if so, which springs/coils should I be in the market for? I am looking for approx 2" lift.
  19. Oct 4, 2017 at 12:27 PM
    #3259
    JerryTaco
    You will need longer shocks. Putting longer coils on the front would max out those shocks causing premature failure.
  20. Oct 4, 2017 at 12:31 PM
    #3260
    bacon_st
    San Diego
    16' Taco TRD sport
    oh. crap. oh well. fine. somebody I know is selling his Bilstein 5100s for just $130 bucks. Just two of them, and if I buy those, which taller springs should I buy to give me the 2" lift?
    And in the back, I do not want another leaf. I just want a block, and which block do I get?
