What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Nov 24, 2015 at 10:56 AM
    #321
    Juhn421
    Juhn421 Member
    2016 DC 4x4 TRD Sport SB, 2003 DC 4x4 TRD Offroad (Sold)
    I just picked up 2016 4x4 to pull my 5000# boat. My 03 lifted 3in couldnt handle the weight. I was told lifted trucks aren't good for towing due to the gearing... any comments on how much regearing will cost on 3 in lift?
  2. Nov 24, 2015 at 11:27 AM
    #322
    \000/
    \000/ Well-Known Member
    Waimanalo, HI
    2016 DCSB 4x4 TRD Sport
    I thought about it but it sticks out enough that I'm happy with it
  3. Nov 24, 2015 at 12:45 PM
    #323
    Tacogram
    Tacogram Well-Known Member
    Apple Valley. CA
    Lift doesn't matter. Tire size will. If you stick with 265's you'll be basically stock
    0uTkAsT likes this.
  4. Nov 24, 2015 at 1:21 PM
    #324
    dmac808
    dmac808 New Member
    image.jpg image.jpg I'm running a 6 inch BDS lift. just don't know what to do with the camber bolts. the washer is too big for the recessed area on the cross member. any tips? grinding it down to fit in the slot? appreciate any help lol
  5. Nov 24, 2015 at 1:22 PM
    #325
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    I think guys were buying the earlier model ('05-'15) bolts/adjusters.
    Livinserene likes this.
  6. Nov 24, 2015 at 1:51 PM
    #326
    aweddle14
    aweddle14 Well-Known Member
    Anthony
    Phoenix, AZ
    16 Quicksand DCSB SR5
    I love these wheels except for the logo caps. are they removable? What do they look like without?
  7. Nov 24, 2015 at 2:40 PM
    #327
    JerryTaco
    JerryTaco Well-Known Member
    Definitely wouldn't grind that bolt since that's what is used for your alignment. Did BDS not supply you with a new eccentric bolt? i have limited experience in the drop bracket lifts, but I do know that alignment will be tough if you grind that washer.
    Edit: Judging by the photos you provided, it looks like the BDS supplied bolt is meant to go through the control arm and the factory bolt should remain in its original location, however that doesn't make much sense for alignment purposes.
  8. Nov 24, 2015 at 4:52 PM
    #328
    JAY8o8
    JAY8o8 Member
    Wahiawa, HI
    This should give you an idea. He is also running a 6" BDS lift kit. Here is the link to his thread.
    https://www.tacomaworld.com/threads/6-lift-on-2016-tacoma.396217/page-10#post-11220702
  9. Nov 25, 2015 at 12:26 PM
    #329
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Did you put on the Dakar leaf pack or is that something else?
  10. Nov 25, 2015 at 12:36 PM
    #330
    \000/
    Waimanalo, HI
    No pack just a 1.5" Deaver AAL
    proven21 and nevadabugle[QUOTED] like this.
  11. Nov 25, 2015 at 6:08 PM
    #331
    honey
    honey Well-Known Member
    Jeff
    Wisconsin
    16 tdr sport inferno 4x4
    leather, T.C. 6", King coilovers, TC uca's, Alcan, amp, Pro comp, bushwaker, bamf, magnaflow, afe.
    I think BDS should be able to make those mods pretty quickly and easily for us so we don't have to mess around with it. I would order the 6 inch from DBS right now if it was updated and my truck isn't even built yet.
  12. Nov 27, 2015 at 8:00 AM
    #332
    dmac808
    dmac808 New Member
    image.jpg got it all worked out
  13. Nov 27, 2015 at 8:01 AM
    #333
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    If I'm still rubbing after a 2.5" lift no mud fap with 275/70/17s what do I need to do,,, I have 1" spacers,, caster is set at 1.8ish ,,:/
  14. Nov 27, 2015 at 10:43 AM
    #334
    honey
    Jeff
    Wisconsin
    Dmac808, maybe I didn't see it but what list are you running, was there a lot of modification? Looks super nice!
  15. Nov 27, 2015 at 3:39 PM
    #335
    TRDPro4x4
    TRDPro4x4 Well-Known Member
    Jerry,
    Did you do UCA's on this build? What setting was the 5100's set at and how would you describe the ride?
  16. Nov 28, 2015 at 6:17 AM
    #336
    BCJimmyZ
    BCJimmyZ Member
    Kelowna, BC
    white '16 TRD DCLB
    audio, Nfab Steps, method NV w KO2, debadged, derped grill, raider cap, tint, clear bra, going broke!
    Nice thread so far! Lots of good info
    -just want to wrap my head around a few things regarding the ´16 ride height and spring rate. I talked to Tanner at Toytech (thanks!) but still a bit confused and probably overthinking it.
    -I have an 2nd gen with Fox non-res front coilovers set at 1.75" lift, and the rear fox shocks with no lift. The plan is to move my Fox setup over to a new 16 DCLB that I will buy this week as Toytech says it will just bolt right on. (So far, so good) I will probably add a progressive AAL as per toytec's recommendation (and because \000/'s truck looks RAD with his shocks/aal setup, and is how I want the stance on the new one)
    so walk me through it...
    -the new truck will go up .75" in the front with current fox settings of 1.75"? I am kinda slow sometimes!
    -If I do the rear AAL then I can increase my front coil height to 2.75 - 3" or so for level / slight rake ride? I was hoping to avoid UCA's but is this pushing it a bit too far?
    -as I am understanding it from reading here: the '16's sit higher in travel due to a different spring rate (?) - so then will my ride / sag / spring rate not be right with the Fox coilovers? I am 100% happy with my current lift and ride and am hoping I dont need to change the springs in the front coilovers.
    Thanks for any advice!
  17. Nov 28, 2015 at 10:45 AM
    #337
    Eric NJ
    Eric NJ Well-Known Member
    New Jersey
    Yesterday, I stopped by a local shop (they specialize in truck mods) and was quoted $550 to replace the FRONT ONLY shocks with 5100's. That price included the shocks and alignment. Seemed high to me. Would like some feedback. Thx
  18. Nov 28, 2015 at 12:10 PM
    #338
    mudcheck
    mudcheck Well-Known Member
    2016 DCLB TRD OR
    I got about the same price from 4Wheel Parts in Sparks,Nevada,$2241for the complete OME setup,$1060 for the billstein 6120 ,which is the shock and coils ,or so I was told that's what it was.I was going to buy the bundle kit from HeadStrong and have my local Lester Schwab do the install but they said they cant do it since they don't carry those brands and they can't guarantee it.They are still trying to see if they can just get the billstein 5100's.
  19. Nov 29, 2015 at 1:49 PM
    #339
    ortacotx
    ortacotx Well-Known Member
    2016 trd offroad
    Hello, I am fairly new to the toy lifestyle. I wanted to get some input on what set up to run... i currently just have a 1.5" level but would like to get a more complete kit with out breaking the bank. I do offroad at least once a month.....
    Tacoma2GR likes this.
  20. Nov 29, 2015 at 8:34 PM
    #340
    azlyle
    azlyle Well-Known Member
    Lyle
    Tempe, AZ
    2016 Tacoma Double Cab TRD Offroad 4x4
    3" Toytec lift with UCAs and AAL, Goodyear Duratrac 285/75r16 on 16x8.5 MB Wheels, RPMFAB steel rock sliders, RCI aluminum skids, Pelfreybilt Aluminum Winch Bumper with Smittybilt X2O winch, Yaesu FT-8800R dual band ham radio, Mobilnkd bluetooth TNC for APRS
    Just finished installed the ToyTec 3" Boss Suspension lift. Took us, weekend hobbyists, about 7 hours, with a trip to the hardware store for more sawzall blades to cut through both factory upper control arm bolts (glad I ordered two new bolts too). I have to say, I really like design of the SPC UCAs. I went with add-a-leaf on the back and learned it would have been easier to do both at once (instead of jacking up only one side at a time). I too had to cut the new bolt for the leaf spring packs to get the bumpstops to fit. All-in-all, not too bad. Great ride so far, now to get it aligned.
    usmcadamsa, DGOTRD, warthog10 and 5 others like this.
