What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Dec 10, 2020 at 9:27 AM
    #3641
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Eh spacers aren't for quality rides anyway.
    Good point though. Still..... Rough Country. :puke:
    SevenofClubs[QUOTED] likes this.
  2. Dec 10, 2020 at 10:01 AM
    #3642
    SevenofClubs
    SevenofClubs Well-Known Member
    2019 Quicksand TRD OR DCSB
    I’m sure they’d find a way to make it cheap lol.
    but as far as dimensions, it should be similar and fit an f150? I know he’s just wanting to put it on for a few months until he can buy a real lift.
    CygnusX191[QUOTED] likes this.
  3. Dec 10, 2020 at 10:04 AM
    #3643
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    so here's what I would do if I was him, look up on rough Country site or wherever you bought it from, look up the part number for the same part for the Tacoma and for the F-150. If the rough country spacer part number matches then you'll know it'll fit.
  4. Feb 10, 2021 at 9:58 AM
    #3644
    TACO ALVY_24
    TACO ALVY_24 Taco Alvy - Dark Knight Edition
    Dan
    VA
    2017 Tacoma TRD Sport
    Looking back on your experiences, what things would you do different today, knowing what you know, about your lifts?
    And if you could start clean, what lift would you get today?
    I am running 265/70/R17 Duratracs. Wont be doing any extensive wheeling, but looking to build a solid overlander with a RTT.
    Want to keep as close to as is since the ride is so nice.
  5. Feb 10, 2021 at 12:59 PM
    #3645
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Since you are looking and carry some weight, you would best be served by avoiding block lifts. For your rear, some deaver leaves And maybe some upgraded Bilstein shocks would put you in a good place.
    As for the front, since you're not running a bumper or anything, any coilover with the spring rate of around 600 lb, such as OME would be a good bet. It'll keep the lift at 2 in or a hair less, which means you don't have to break the bank with UCA's or anything else.
    TACO ALVY_24[QUOTED] likes this.
  6. Feb 18, 2021 at 8:53 AM
    #3646
    Tacoma~Gal
    Tacoma~Gal Well-Known Member
    '23 LR OR
    Hello! I hope this is the appropriate place to ask this question.
    I have a 2018 SR5 that I'm wanting to eventually put 17's on. I don't do much off-roading, only forest service roads here and there.
    What is the best direction for me to go if I want a 2-3" lift?
    Thanks!
  7. Feb 18, 2021 at 1:17 PM
    #3647
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    If you just wanted to swap tires and wheels, you could put 17-in wheels and 32-in tires on your truck without touching the suspension.
    Sounds like you do some light off-roading, so you're going to want to avoid cheap block lifts.
    You can get complete suspensions from old man emu, eibach, and toytec for little under 1500 that include front coilovers, rear leaves, rear shocks, and all appropriate hardware and instructions. In that range you're looking at around 2 inches of lift, which isn't a ton but it definitely makes a difference with these little trucks. It's also a small enough lift that it won't compromise it's drivability and you shouldn't need expensive control arms etc.
  8. Feb 18, 2021 at 1:35 PM
    #3648
    Tacoma~Gal
    '23 LR OR
    Thank you! Our other truck is an F-150 so I like the higher ride height. I definitely want a lift, but nothing too crazy where I start messing with control arms, ect.
    It's good to know I can fit 17/32's on stock suspension.
  9. Feb 18, 2021 at 1:36 PM
    #3649
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    The other thing I forgot to mention is if you carry loads constantly, you want to look at a slightly heavier leaf spring depending on which suspension you're looking at. If you don't, sticking with light or medium duty will suffice.
    Also, add Dobinsons to your list of affordable suspension research.
    Tacoma~Gal[QUOTED] likes this.
  10. Feb 18, 2021 at 1:44 PM
    #3650
    Tacoma~Gal
    '23 LR OR
    Nope. She's a grocery getter. The ford is for beating up. Lol
    Thanks, I'll add it to my list.
  11. Feb 18, 2021 at 4:04 PM
    #3651
    Jcull35
    Jcull35 Member
    2018 Tacoma TRD ORLB
    At what lift should I be concerned about cv angles? I want to do a 2.5 front lift and 2 rear lift on my ORLB.
  12. Feb 18, 2021 at 6:23 PM
    #3652
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    2.5 is about the concensus for needing UCAs.
  13. Feb 18, 2021 at 6:36 PM
    #3653
    Jcull35
    Jcull35 Member
    So at 2.5 it won’t create bad cv joint angles?
  14. Feb 18, 2021 at 7:23 PM
    #3654
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    That's about where you're pushing it. Each truck is a little different, but general consensus is at 2.5 or above, you're better off upgrading your UCAs
  15. Feb 28, 2021 at 11:04 AM
    #3655
    RCrumb
    RCrumb Dumb as Dirt
    CANADA
    2020 TRD OR Premium-Auto
    Apologies if this has been addressed already. If I want to add a 2” lift to my 20 TRD OR, is there anyway to keep the Toyota Safety Sense system functional and the OEM grille? I don’t fancy the TRD Pro grille.
    thank for your comments.
  16. Feb 28, 2021 at 11:41 AM
    #3656
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yup. It'll still work.
    Worst case is the dealership can recalibrate the front sensors with the lift and no problemo.
    RCrumb[QUOTED] likes this.
  17. Mar 3, 2021 at 7:32 AM
    #3657
    NC Rick
    NC Rick Well-Known Member
    Rick
    Asheville, NC
    2019 TRD OR DC SB 4x4 Super White
    I'll apologize in advance if I missed a post with this information but I have a question which I haven't seen addressed. I like my Gen3 2019 Tacoma dc or. I don't care about changing the "stance" or "look" I wish to maintain OEM reliability and I don't want huge tires which will increase tire weight and upset the trucks gearing. What I do care about is excellent suspension for mild trail driving. I want very good quality both in durability and performance. I have added rock sliders and will add a front bumper for clearance and protection. I will likely upgrade the skid plates. I have a Diamond back HD bed cover. I haul gear but not a tent or "Overlanding" stuff. I occasionally pull a small (1700 lb loaded) trailer.
    an inch or two additional clearance would be helpful and I expect to upgrade my Duratrac 265/70 to a 265/75. My strategy isn't to reduce costs but to improve my vehicle for my use. So far the truck has been fun. Lowering my tire pressure to 20 psi takes away enough ground clearance that I notice on the trail. I want that clearance back and want performance on washboard roads and trail debris. Not jumping or driving fast just enjoy good suspension performance and I think my stock Bilstien suspension could be better. Front adjustable coil over shocks sound like what I want.
    advise and input would be appreciated !
    Rick asheville, NC
  18. Mar 3, 2021 at 7:41 AM
    #3658
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Sounds like you have a good plan. Any lift you go with, whether it be Toytec, Eibach, Dobinsons, OME etc, You keep it under 2 inches or right around 2 inches you wont upset much of your drivetrain and still keep your daily drivability of your truck without having to spend tons of cash on other upgrades to make it function.
    If you want to keep ride quality, skip lift blocks or coil spacers. Go with complete coil over setups, and actual leaf packs or add a leaf in the back.
    NC Rick[QUOTED] likes this.
  19. Mar 3, 2021 at 7:03 PM
    #3659
    NC Rick
    Rick
    Asheville, NC
    Thank you! So, riddle me this, why would a 1-2" or any lift increase tire clearance? If I add an inch or so of height I also want additional suspension travel of that amount. To me, the place the suspension bottoms would dictate tire clearance. Am I missing something? A local dealer told me I was wrong but didn't explain why.
  20. Mar 3, 2021 at 8:39 PM
    #3660
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    .....because you're then sitting 1-2 inches higher off your axle, thus gaining you 1-2 inches more space for your tires to fit into....
