What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Apr 20, 2022 at 9:07 AM
    #3701
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Noice
    So uh..... Where is your pro suspension going.... Asking for a friend... :anonymous:
    hilighter likes this.
  2. Apr 20, 2022 at 9:33 AM
    #3702
    BKrup
    BKrup Well-Known Member
    NC
    07 Tacoma Sport / 17 Tacoma Pro
    On the market
    CygnusX191[QUOTED] likes this.
  3. Apr 20, 2022 at 11:15 AM
    #3703
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Hurry up and get to 50 posts (the proper way) so you can list it here instead :D
  4. Apr 20, 2022 at 11:18 AM
    #3704
    BKrup
    NC
    Been a member since 2014, alot of reading. Will post them up.
  5. Apr 20, 2022 at 11:30 AM
    #3705
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Consider me interested when you do
  6. Apr 24, 2022 at 6:27 AM
    #3706
    NCSWAMP13
    NCSWAMP13 Well-Known Member
    2019 cement gray Tacoma TRD off road
    I have a question, if your new rear shock absorber gives you 1" of lift and your new aaf gives you 1.5" of lift, do those combine for 2.5" or is it just the 1.5" that the leafs give you? Probably a dumb question but im new to all this. Thanks.
    CygnusX191 likes this.
  7. Apr 24, 2022 at 3:15 PM
    #3707
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    This is not a dumb question at all, good sir.
  8. Apr 25, 2022 at 2:40 PM
    #3708
    HTXTACO93
    HTXTACO93 LunarProHTX
    2021 Lunar Rock TRD Pro
    The extended travel tip was really useful!
  9. May 5, 2022 at 5:08 AM
    #3709
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    Some shock absorbers can accommodate additional lift but they don't provide any, that's the spring's job.
  10. Jul 19, 2022 at 1:32 AM
    #3710
    TacoAzul21
    TacoAzul21 Member
    21 Tacoma 4x4 Sport VooDoo
    Front Speakers, Pro Grille, Arm Rest Pad,
    Newbe here, 2021 Tacoma Sport 4x4. STOCK!. Truck needs some help in the looks department (Lift & Tires). Also, I'm in Hawaii and most of the beaches are about a 1-mile drive down a dirt/gravel roads with rocks, potholes, lava rocks etc... On some of the roads, I bottom out slightly. Before reading some of the previous pages in this section, I thought for sure, 4-inch lift. But now that I've read some, I'm thinking 2.5" lift and 33" tires. I don't want to do a big expensive lift and change the geometry a lot. I've heard a lot of people here suggest ToyTec suspension. Any other advice/ideas I may be missing? Do 2.5" lift and 33" tires provide much of a performance upgrade for Tacoma's? Thanks in advance
  11. Jul 19, 2022 at 9:15 AM
    #3711
    Taco & Salsa
    Taco & Salsa Well-Known Member
    Marcus
    San Antonio, TX
    2017 Black SR5 DCSB 4x4
    I am in similar situation and need some advice.
    I have a set of the new 17” TRD rims with Faken Wildpeak AT on them. Size 285/70R17. I’m looking at the lift kits from Rough Country for my 2017 SR5 and I’m not sure if the 3” lift will be enough for no rubbing issues, or do I need to get the 3.5” lift? Any advice you guys can give would be appreciated.
    TacoAzul21 likes this.
  12. Jul 19, 2022 at 1:19 PM
    #3712
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    2-2.5 is optimal for Tacomas. And yes, that'll fit 33s and they'll do quite nicely. If you're a manual, no sweat. If you're an auto, find some body to tune your truck. You can thank me later
    Toytec are rock solid. So is OME, esp in the budget department.
    Excellent tire choice, best on the market.
    Terrible suspension choice, worst on the market.
    Stick with proper suspension, like OME, Dobinson's, toytec etc. Don't cheap out on your truck, it's a 2 ton death machine. Keep the lift to 2-2.5 inches and you'll be fine.
    RCrumb and TacoAzul21[QUOTED] like this.
  13. Jul 19, 2022 at 1:33 PM
    #3713
    Taco & Salsa
    Marcus
    San Antonio, TX
    I’m not married to a manufacturer for the suspension, so I appreciate the suggestions. I’m not certain 2.5” lift would eliminate tire rub.
  14. Jul 19, 2022 at 2:35 PM
    #3714
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Some manufacturers (like Rough country) are known in the industry for shody craftsmanship and lack of quality.
    Companies like OEM are tried and true, across the outback and around the world, hence their high standings
    2.5 is plenty, esp with aftermarket UCA's that allow forward camber adjustment and wheels with around a -10 offset.
  15. Jul 19, 2022 at 3:35 PM
    #3715
    Taco & Salsa
    Marcus
    San Antonio, TX
    I believe these TRD wheels have 4mm offset
  16. Jul 19, 2022 at 9:24 PM
    #3716
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    The lift kit isn’t going to be the issue. If you rub, it will likely be on the cab mount at full lock.
    Our local Toyota dealer uses the same size tire because they don’t have customers complain about tire rub. I don’t think you will have an issue.
    If you go with an aftermarket UCA as @CygnusX191 mentioned above, then you will have adjustment options. You will want aftermarket, if you get a lift.
  17. Jul 20, 2022 at 6:53 PM
    #3717
    Taco & Salsa
    Marcus
    San Antonio, TX
    I spoke with Edgar at Toytec and he said since I’m running 285s I would need to have the 3” lift to avoid rubbing, and even then it would be close. Looking at getting the new Aluma 2.0 lift to get to 3” with the SPC UCAs. Will do the AALS and Diff drop also. I really like the red spring on the Toytec.
  18. Jul 20, 2022 at 7:30 PM
    #3718
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    3 inch lift wont matter. Depending on tire choice, youll rub something. Just go into it with that expectation.
  19. Jul 20, 2022 at 7:31 PM
    #3719
    Taco & Salsa
    Marcus
    San Antonio, TX
    Falken Wildpeak AT3. 285/70R17 on a TRD Pro rim with a 4mm offset
  20. Jul 20, 2022 at 11:37 PM
    #3720
    TacoAzul21
    TacoAzul21 Member
    Same Wheel/Tire package I was thinking of. Very cool.
